Dropped Kerb Shenanigans
Quote Me Happy
PostPosted: 09:46 - 12 Feb 2016    Post subject: Dropped Kerb Shenanigans Reply with quote
Dear denizens of BCF,
I have a hankering for a dropped kerb in front of chez Joe. I have a small front garden type thing that Mrs Joe uses to grow plants and things, obviously this would be better used to park a motorbike on, so that's my plan.
It's not a big area - not big enough for a car really but plenty big enough for a bike. From my limited reading from the internet the rules for being successful in your application varies from council to council. The guidance notes for Surrey can be found here
https://www.surreycc.gov.uk/__data/assets/pdf_file/0006/53583/18th-VCO-Guide-Notes-April-2015.pdf
From what I can see the rules state, apart from don't be near a tree or street lamp :
"You must have sufficient room on your property for a vehicle to be parked without it overhanging the public highway."
Yep, not a problem, it goes on to say
"The minimum requirement for a car to be parked on the owner’s property at right angles to the road is 4.8 metres deep by 3.2 metres wide. A minimum width of 2.4 metres may be considered in some cases. The width may need to be increased at the highway officer’s discretion to ensure safe entry and exit."
Not parking a car, can I ignore this? (My front garden isn't quite that big)
As each council has their own seemingly arbitrary rules as to what's allowed, I had a quick look at S184 Highways Act 1980 and can see no mention of minimum areas in there.
I did email my council for clarification and received an automated email basically saying we're too busy, don't expect and answer any time soon.
Does anyone else have experience of having a dropped kerb installed specifically for motorbike access?
lihp
PostPosted: 09:56 - 12 Feb 2016    Post subject: Reply with quote
You're going to pay over a grand for a dropped kerb? For a bike?
Quote Me Happy
PostPosted: 09:57 - 12 Feb 2016    Post subject: Reply with quote
Yes. It has the added benefit of effectively creating a parking space outside my house for my car as well.
ajag
PostPosted: 10:27 - 12 Feb 2016    Post subject: Reply with quote
But you just said you only wanted it for your bike. Are you trying to argue with them that it is only for your bike as it is not enough for your car, but then intend to park your car there?
Street Triple
bugeye_bob
PostPosted: 10:33 - 12 Feb 2016    Post subject: Reply with quote
I think OP wants a dropped kerb to stop others parking in front of his house, and making it easier to get his bike on the front garden.
lihp
PostPosted: 10:35 - 12 Feb 2016    Post subject: Reply with quote
I'm guessing he wants the dropped kerb to park his bike on front garden, and then block his own dropped kerb with his car.
Quote Me Happy
PostPosted: 10:44 - 12 Feb 2016    Post subject: Reply with quote
Theoretically I could park my bike in my front garden now, whether or not I'd be able to get my bike out again when someone blocks me in is another matter.
I would probably then park my car in front of the dropped kerb although I have said to the missus that we would tell the neighbours to feel free to park in front of the kerb so long there is enough room to get the bike out.
iooi
PostPosted: 12:56 - 12 Feb 2016    Post subject: Reply with quote
You need to also check house deeds/planning regulations. As many will state you can't park in front of the house line.
Andy_Pagin
PostPosted: 13:26 - 12 Feb 2016    Post subject: Reply with quote
When I get blocked I just ride along the pavement until I find a gap.
zark
PostPosted: 15:21 - 12 Feb 2016    Post subject: Reply with quote
i would hazard a guess that the regs mention dimensions suitable for a car - so if you sell your house (with a dropped kerb) the buyer may assume that he could fit a car on it in the future?
Here in Herts - they also specify that there must be a drain installed so surface water doesn't flow across the footpath, as well as some guff about foliage and vegetation and sight lines etc, before giving permission to have a dropped kerb
I'd probably just throw a lump of timber in the gutter for easier access if the kerb is that high
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
Nobby the Bastard
Harley Gaydar
PostPosted: 16:17 - 12 Feb 2016    Post subject: Reply with quote
Surely the dropped kerb would only be big enough for a bike as well? A foot wide dropped kerb is clearly not big enough for a car
Triumph Sprint ST 1050
t121anf
PostPosted: 16:20 - 12 Feb 2016    Post subject: Reply with quote
How, from what I've read it is only illegal to park there if you cause an obstruction to someone wanting to drive onto the road, it's fine if there isn't a car on the driveway to block.
Seems to be a gentlemans rule more than anything (for example i wouldn't park across a dropped kerb)
BTTD
PostPosted: 16:40 - 12 Feb 2016    Post subject: Reply with quote
Varies by council. For example, Portsmouth is a crowded city so if a dropped kerb is not in regular use for vehicular access, then anyone can park across it. If it is in use, then the owner can phone up the council and get a parking womble round to issue a ticket. Owner will have to prove that the access is in regular use ie if the garage is full of junk and it's obviously not being used for parking a motor, then a ticket won't be issued and the owner can f off. Police will not enforce - they will direct you to the parking wombles.
I had exactly this argument with a neighbour who cannot fit a car into the triangle shaped storage shed on the side of the end-of-terrace house he rents, but was threatening to have my wifes car towed away for parking there because dropped kerb = his personal parking space. Knob.
If you want reserved parking in front of your house, get a house with a driveway. Otherwise, wheeling along the pavement until you find a gap is what you're stuck with. Consult your local council / parking wombles for your area specifics.
yen_powell
PostPosted: 19:44 - 12 Feb 2016    Post subject: Reply with quote
The 4.8 comes from the standard size for a parking bay that is end on (4.8x2.4m).
When I used to say yes or no to dropped kerbs for drive ways I had to make sure the car wasn't going to overhang the public footway (hence the 4.8m) but also the car mustn't block the front door of the property for obvious reasons.
There are rules nowadays that mean you have to have a permeable drive to stop all the nasty flooding for northerners.
I would get a request for a crossover. A quick visit to see if there was enough space and the vehicle could physically turn out of the drive, so no parking spaces opposite that would make the road too narow for instance. Then look at the stats boxes, BT or fibre would need to be moved or strengthened, water/gas valves can stay where they are usually. If there was a lamp post, traffic sign or parking bay, could they be moved?
I would knock up an estimate and send it to them. If they hadn't fainted from the cost and paid up, I wouldn't start work till they had removed any wall or fence and put down their surface to make sure they were at the correct footway level and not draining any of their rainwater on to the highway.
XT1200Z and a DR350 in bits
Quote Me Happy
PostPosted: 09:58 - 16 Feb 2016    Post subject: Reply with quote
Thanks for the info. I still haven't heard back from the council but will continue to look into it. I'm not bothered about being able to park the car in front of the house, that's just an added bonus. I just really want to be able to get the bike out onto the road from my front garden without having to ride up and down the pavement and potentially pissing off my neighbours.
arry
PostPosted: 10:10 - 16 Feb 2016    Post subject: Reply with quote
The fact you wouldn't block it and there's others like you answers your own question
defblade
PostPosted: 10:57 - 16 Feb 2016    Post subject: Reply with quote
So, push or paddle along the pavement when necessary and don't start the bike up until you're on the road. Spend the at least £1000 you saved on new shiny bike stuff Smile
Quote Me Happy
PostPosted: 10:59 - 16 Feb 2016    Post subject: Reply with quote
I'm not pushing a 300kg bike up a hill, I'll have a heart attack.
angryjonny
PostPosted: 11:05 - 16 Feb 2016    Post subject: Reply with quote
Use the next dropped kerb up the hill, rather than down.
sickpup
Old Timer
PostPosted: 11:07 - 16 Feb 2016    Post subject: Reply with quote
No it doesn't. Its an offence to park across a dropped curb.
Quote Me Happy
PostPosted: 11:12 - 16 Feb 2016    Post subject: Reply with quote
S86 Traffic Management Act
The second exception is where the vehicle is parked outside residential premises by or with the consent (but not consent given for reward) of the occupier of the premises.
arry
PostPosted: 12:41 - 16 Feb 2016    Post subject: Reply with quote
I can see the 5-0 limbering up for this one. Their online intelligence team has already gathered significant evidence
Actually it is the kind of shit they likely would pull - depressingly
defblade
PostPosted: 14:25 - 16 Feb 2016    Post subject: Reply with quote
So, spend the £1000 on gym membership instead, wuss Wink
Or, go with (the opposite of??) what Angryjonny says... go a tiny bit out of your way to work with gravity.
sickpup
Old Timer
PostPosted: 16:05 - 16 Feb 2016    Post subject: Reply with quote
But you missed the secondary civil offence.
Most councils have a blanket bylaw/TRO that restricts parking within 1 metre of a dropped curb for disabled access.
Unfortunately as the council own the road and kerb regardless of your wishes your new dropped kerb (assuming you get one) will no doubt be treated in this way.
BTTD
PostPosted: 11:02 - 17 Feb 2016    Post subject: Reply with quote
Not true in all cases.
It depends entirely on the local bylaws / council enforcement. OP needs to either find it on the council website, or get the information from them directly if the website doesn't have the detail.
It might be worth just applying for a dropped kerb and asking the guy who comes to do the survey (if he even gets out of his car once he sees you can't get a car up there). Probably fees involved in application?
The last post was made 10 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 132.75 Kb
