NOT ENOUGH FUEL COMING THROUGH
Stevie58
PostPosted: 15:47 - 12 Feb 2016    Post subject: NOT ENOUGH FUEL COMING THROUGH Reply with quote
I've already posted about this but I'm absolutely desperate now!! I can't work without this bike and I've been of work for 1 week !!
Big thanks to all that commented before
The bike is growling after about 3000rpm.. there is a massive lack of fuel coming through. . Plugs are bone dry and slightly white..
Here's what I've done already..
New fuel
Taken out fuel tap and cleaned
New fuel filter..
Completely cleaned carbs and took out jet and pilot jet and took apart floats and blowed through..
The carbs are filling up properly with fuel..
Checked diaphragms and needles and took of air box to see that they are rising properly..
New manifold rubbers
New plugs and good spark
(If it was coils or plugs the plugs would be wet but they are bone dry)
Check the tank breather and took off tank cap to make sure there wasn't a vacuum stopping the fuel leaving the tank
Fuel pump is working great and priming fine and feels like there is good pressure
I LITERALLY CAN'T THINK OF ANYTHING ELSE
I'M SO DESPERATE ANY HELP WOULD BE GREATLY APPRECIATED
I've only got 1 local dealer that I could limp the bike to but he is fully booked for 2 weeks
The bikes a cbr600 1987
When I put new manifold rubbers on the bike was running absolutely fine so i turned her off.. went and put my leathers on.. come back and now hardly any fuels getting through
SMS
Vincent 2
PostPosted: 16:07 - 12 Feb 2016    Post subject: fuel strvation Reply with quote
have you tried a gravity feed from tank straight to carbs cutting out the pump
https://www.youtube.com/watch?v=hsgTyyZ1JVo
Stevie58
PostPosted: 16:13 - 12 Feb 2016    Post subject: Re: fuel strvation Reply with quote
Not yet I'm just in the process of doing that now.. I'm just making up a bottle..
It seems more like the problems between the float chamber and the piston..
I willing to try anything at the minute lol I'll let you know how the gravity feed goes
Many thanks
SMS
Vincent 2
PostPosted: 16:33 - 12 Feb 2016    Post subject: fuel strvation Reply with quote
like a lot of these things its a process of elimination , cutting out the pump with the gravity feed can eliminate a stage at a time , is the tank itself creating a vacuum ( breather pipe blocked)sorry matey just read your previous
yen_powell
PostPosted: 18:48 - 12 Feb 2016    Post subject: Reply with quote
The pumps are a known problem area, shared with the Africa Twin. I have about 4 old knackered ones buried in the garage plus a Mikuni vacuum replacement (also played up in the end) and finally ended up with a solid state aftermarket replacement.
XT1200Z and a DR350 in bits
Robby
Dirty Old Man
PostPosted: 19:46 - 12 Feb 2016    Post subject: Reply with quote
Humour me. Check the charging system. Multimeter on the battery, how many volts are you seeing at around 3000rpm?
Stevie58
PostPosted: 21:57 - 12 Feb 2016    Post subject: Reply with quote
I'll check the charging system first thing in the morning.. I have just put a new battery on it 2 days ago and I did have a problem with the alternator that just turn out to be that I had accidentally un plugged it whilst working on the bike..
SMS
Stevie58
PostPosted: 22:04 - 12 Feb 2016    Post subject: Reply with quote
Saying that I do believe buried in a box I'm got a good fuel pump of a f3 I once had.. I'll give it a try
SMS
The last post was made 10 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.84 - MySQL Queries: 13 - Page Size: 55.97 Kb
