| aidy_b |
 aidy_b Two Stroke Sniffer
| barrkel |
 barrkel World Chat Champion
 Posted: 19:10 - 12 Feb 2016 Post subject: |
Is the throttle stiff - i.e. is it binding? The cables may need lubrication if so.
Is the grip fouling on anything (heated grips in particular easily get stuck when rotating in muffs (ahem)).
Chase the other end of the throttle cables - you'll be able to see them actuate a little wheel just under the rear of the tank, on the right hand side; ultimately the throttle rotates flaps (inside the airbox) that control the air going into the engine. The idle adjust knob is also on the end of a stiff cable that leads to it (specifically, it controls where the wheel stops). There's a spring on that mechanism that could be broken or not attached correctly. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| aidy_b |
| davebike |
 davebike World Chat Champion
 Posted: 07:43 - 13 Feb 2016 Post subject: |
Heated grip become unglued from throttle tube common problem ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| aidy_b |
 Posted: 11:26 - 13 Feb 2016 Post subject: |
Thanks Davebike - the heated grip came away from the tube when I gave it a tug.
The throttle tube itself is working fine (after spending an hour trying to put the housing back together while keeping the cables in place ).
Will go out later and buy whatever glue google suggests, then back in the saddle.
Thanks all |
The last post was made 10 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
