suzuki marauder not starting
m4rk3y
PostPosted: 14:17 - 15 Feb 2016    Post subject: suzuki marauder not starting Reply with quote
it wont start,
iv checked the run switch, the killswitch, all the other little switches (clutch and kickstand and neutral).
iv replaced the starter solenoid. the starter motor turns when i arc accross the top of the solenoid. i do get continuity through the switch and i get some kind of signal, on the multimeter, in the harnes that goes to the solenoid, when i press the start switch.
i made some videos to help explain this... hopefully im allowed to share them.
https://www.youtube.com/watch?v=EOaEoWhS5qU
showing solenoid on other bike working
https://youtu.be/457fqDgB69I
any help would be amazing, thanks
talkToTheHat
PostPosted: 03:47 - 18 Feb 2016    Post subject: Reply with quote
Is that a late model fuel injected one? Looks and sounds like the buzz is fuel pump, if not, its a relay buzzing. Identify.
Are you getting enough voltage to cycle the starter solenoid?
Try with a known good battery?
tried cycling the solenoid with a jump lead direct from the positive terminal?
i suspect you have a bad connection or a broken cable that will give you voltage nut fails when you need some current.
Bandit. does. everything.
The last post was made 10 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 31.68 Kb
