| A.FreeMan |
 A.FreeMan Derestricted Danger
| whitedevil |
 whitedevil World Chat Champion
| Vincent 2 |
 Vincent 2 Nova Slayer
| A.FreeMan |
| MarJay |
 MarJay But it's British!
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:55 - 15 Feb 2016 Post subject: |
I've had two bikes with the airbox removed because racebike. Putting the box back on improved them.
Fuel = energy = power. If you can find a way to improve power output while using less fuel then Volkswagon will have a job for you in the Emissionenscammenchipwaffe.
Unless you have (at least) a dynamometer, an exhaust gas analyser and some way of measuring the combustion chamber (and piston) temperature in real time then you're as likely to make the bike worse rather than better. ____________________ Biking is 1/20th as dangerous as horse riding.
| A.FreeMan |
 Posted: 15:08 - 15 Feb 2016 Post subject: |
Thanks for all the replies guys.
I am aware that this probably isn't the most useful project, however it was set by my supervisor simply as a feasibility study. If it doesn't work then I can simply conclude that and give reasons for the failure!
Reading around it doesn't look as though efficiency has really been in the minds of motorcycle engineers as there isn't much demand for it? Unlike car manufacture that has a million new regulations every day, forcing them to tweek and tweek and tweek with MPG in mind!
I have access to a dynamometer in a mechanics garage.
Having just had a look at the bike, it is clear the airbox has been squeezed into the design (fairly ingeniously I must say) but the intake is under the seat (presumably fairly common). I was going to test the effect (if any) of re routing the air intake to the front of the bike, aiming to increase the pressure at the intake and reduce the temperature of the air.
To test this I was planning on doing some dyno tests and potentially a 40 odd mile trip down the motorway at as constant a speed as possible with the original airbox and the new airbox to compare the fuel economy. Thoughts? |
| Vincent 2 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:30 - 15 Feb 2016 Post subject: |
Ah, OK, I didn't realise you had access to moon-technology.
Then sure, ram air, but that's to get more air through which lets you get more fuel through.
For fuel efficiency you have to run lean, which means running hot. You'd be looking at fiddling with the jets and needles and seeing how high you can get the air/fuel ratio before you burn though a piston.  ____________________ Biking is 1/20th as dangerous as horse riding.
| iooi |
 iooi Super Spammer
| spottedtango |
 spottedtango Trackday Trickster
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 21:21 - 15 Feb 2016 Post subject: Re: airbox |
| spagiratwink wrote: | Hi , I can`t see a way of improving economy thro the Airbox , except by getting a better filter (K&N), ... |
What exactly makes you think a K&N filter is better than the OEM filter that the engine was tuned and designed with?
| spagiratwink wrote: | Have a look at bikes with ram air , a lot of bikes have this , it`s air intakes at the front of the bike (mainly on the fairing) to force air in at speed |
Ram air intake is a nice thing ONLY when you've got a clever DFi units that can adjust the mixture on go. If you run carburetors, the odds are the air/fuel mixture will be rather rich to keep up with the amount of air being forced through at high speeds. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Vincent 2 |
| RhynoCZ |
 Posted: 21:52 - 15 Feb 2016 Post subject: |
I did read it, I'm gonna post my thoughts right after I ask you once again. Do you really think that about K&N filters or are you a retailer of their products? For my particular motorcycle a K&N filter costs about 5x more than the OEM one and both are made of foam. The filter gets filthy pretty soon with the ram air intake and all the water getting there when riding in wet conditions.
Here are my thoughts:
OP, talking about efficiency is not just about fiddling with the fuel and air. It's also about reducing all the resistance in the engine itself and things that have a negative influence on the engine's power output.
You might know, that when the vast majority of manufacturers talk about kW and Nm, they always tell you the netto value. Meaing the engine is tested on a dynamometer, with external fuel pump, external coolant pump, external charging of the battery and even external oil pump and other things directly or even indirectly powered by the engine.
So, to make an engine more efficient, you have got to make all the parts lighter and achieve less rolling resistance of all the moving engine and gearbox components. Then you're gonna talk about wheels, tyre pressures and brakes drag. Worn bearings in the wheels, low tyre pressures, dragging brakes cause some of the energy produced by the engine is being wasted. The last bit you should worry about is the aerodynamics, because I can't see a reason for having a perfectly aerodynamic body shell, with all the components above having a negative influence on the efficiency of the vehicle.
I've also had a chance to see all this in practice, even changing the wheel bearings on your motorcycle makes significant difference. Now imagine you rebuild the engine, put a less restrictive oil filter there, get rid of the charging system, etc. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Snod Blatter |
 Snod Blatter Crazy Courier
 Posted: 21:57 - 15 Feb 2016 Post subject: |
Carburettors have airways to use the "ram air" pressure to pressurise the float bowl, to help sort the fuelling out in the turbulence.
Anyway! I'm with spottedtango, try lengthening the tubes from the carbs into the airbox and after that I'd perhaps try "filling" the airbox with something to reduce its capacity, to see if changing the speed at which the pressure waves reflect back inside the airbox can help. To deal with a 180 degree firing order you may have to increase the size of the airbox for that to work, though, so that the waves take longer to reflect due to the lower revs you want to use.
Vaguely interesting? Definitely testable though. You could also check out the ER-5 and KLE500, same engine but less top end horses - could give you an idea of where to go with it. ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
| weasley |
 weasley World Chat Champion
| A.FreeMan |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:04 - 16 Feb 2016 Post subject: |
By the way, good on you for having a go. Everyone's a critic, but all progress comes from determined individuals ignoring the nay-sayers who claim it can't be done. ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
 Posted: 13:09 - 16 Feb 2016 Post subject: |
You couldn't possibly have picked a worse bike to try to do this with.
The airbox on a GPZ500 is very intelligantly designed. Kawasaki employed accoustic engineers to design the airboxes of their bikes in the late 80's/early 90's. That's how they managed to produce so many class-leading motorcycles and hung onto the "fastest production road bike" crown for so may years (GPZ900R then ZZR1100).
This generation of airboxes utilise pressure waves to force air into the engine. Their better efforts are reputed to be able to flow 10% more air than the capacity of the engine. The GPZ500 is largely based on the tech used in the 900R and that was the first production motorcycle todo 150mph out of the box.
As you have noticed, they built the GPZ500 round the airbox, rather than fitting an airbox into the bike.
I really can't see this being improved on. I can see attempting to convert a pressure-wave airbox to ram air resulting in a bike that wont run at all well. From my previous experience of messing about with various incarnations and combinations of the kawasaki 500 twin, I predict it almost certainly wont rev over 7,000 rpm at all. The lack of midrange pressure you cause by destroying the pressure wave will prevent the throttle valve from lifting. If it does manage to bog, cough and stutter past this point and you hit 9,000rpm, it'll set off like the hounds of hell are on it's tail. Now you need to decide if your abilities and licence can afford for you to keep it there.
That said, they are tuned for peak power. If you want to tune it for fuel efficiency, fit an ER5 airbox, main jets and throttle needles. You'll experience a roughly 10% drop in horsepower and a saving in fuel.
All the above notwithstanding, if you ride a GPZ500 at or around the speed limit and don't wring its neck, it'll return 60mpg. It's twisting your right hand that makes it inefficient.
I'm not saying don't try, I am saying you're messing with something that is already extremely well designed. My advice is don't do anything that cannot be easily reversed. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 10 years, 258 days ago. Instead of replying here, would creating a new thread be more useful? |
