Looking for a small but hopefully very bright torch
i1301243
PostPosted: 19:39 - 15 Feb 2016    Post subject: Looking for a small but hopefully very bright torch Reply with quote
I'm looking for a two mode (On and off) which would clip onto my uniform much like the millions that flood ebay. I want on and off. The ones I keep finding have Off/On/Dim/Strobe. I read about how to modify the board to disable the flashing, using a pencil etc but I find them glued in so I can't get to the boards to try.
I've never found myself thinking "a great torch, but I wish it was just a little dimmer" or "great torch, but I wish it strobed".
Anyone recommend a small, cheap, bright as possible torch please?
Ben90
PostPosted: 19:49 - 15 Feb 2016    Post subject: Reply with quote
https://www.amazon.co.uk/UK-DIRECT%C2%AECREE-Lumens-Flashlight-Zoomable-Torch/dp/B00QKG7EKC/ref=sr_1_4?ie=UTF8&qid=1455562030&sr=8-4&keywords=led+torch
Well reviewed and stupendously cheap.
Yamaha FZ6 S2
i1301243
PostPosted: 19:54 - 15 Feb 2016    Post subject: Reply with quote
Literally exactly the same as the one I bought, except the ones on ebay don't differentiate between 1 mode and 3 mode.
If I had the Karma to give you I would. Smile
grr666
PostPosted: 20:05 - 15 Feb 2016    Post subject: Reply with quote
Ordered, Ta Ben. Thumbs Up
Hahadumball
PostPosted: 20:10 - 15 Feb 2016    Post subject: Reply with quote
the ones ben linked are pretty good tbh.
zooms good too.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
ninjabob
PostPosted: 20:19 - 15 Feb 2016    Post subject: Reply with quote
Order these to go with it:
https://www.amazon.co.uk/gp/product/B00V4LGSVE/ref=od_aui_detailpages00?ie=UTF8&psc=1
Fisty
PostPosted: 20:30 - 15 Feb 2016    Post subject: Reply with quote
I use LED lenser torches, very bright and you can pick them up on ebay cheap.
https://www.ebay.co.uk/itm/LED-Lenser-P6-High-Performance-Torch-/262290466173?hash=item3d11bae57d:g:KT0AAOSwB4NWuNkw
Fatter and faster than Fret
Quote Me Happy
PostPosted: 20:35 - 15 Feb 2016    Post subject: Reply with quote
LED Lenser P7.2, cracking torch.
iooi
PostPosted: 21:48 - 15 Feb 2016    Post subject: Reply with quote
I got 2 of them.
Great little torches for the cash.
Usual shame they have to come from China....
HTF they can make and deliver for less than UK postage of same device is a sad indictment of how wrong the UK is...
uberkron
PostPosted: 06:24 - 16 Feb 2016    Post subject: Reply with quote
S15 baton from olight.com
Costs more than many but very practical.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
defblade
PostPosted: 11:06 - 16 Feb 2016    Post subject: Re: Looking for a small but hopefully very bright torch Reply with quote
You haven't got any properly bright torches, then Twisted Evil
If you've got, or don't mind getting, 18650 batteries and charger, the BLF A6 is properly bright, for a single emitter, about £16 with the forum code from BLF. It has a rather complicated UI to start with, but can be set into memory mode so that it does what you've asked and just come on at the last brightness, and go off with a click.
weasley
PostPosted: 11:34 - 16 Feb 2016    Post subject: Re: Looking for a small but hopefully very bright torch Reply with quote
I have, however, occasionally thought "great torch, but it is very dark here, miles from anywhere - I hope the batteries don't die". Bump it into 'dim' mode, still see plenty good enough and extend the battery life.
PostPosted: 13:46 - 16 Feb 2016    Post subject: Reply with quote
I'm rocking an Ultrafire UF-H2.
Kick arse torch. Too bright, never use it on full power, it's like a fucking night-sun. Infinately dimmable.
Conical beam means it's brilliant for walking about with, evenly lights up a big circle in front of you.
It remembers where you set the dimmer function next time you power it up. There is a strobe function but it's difficult to do, you have to mean to set it to strobe. It's just the one button, click on, click off. Click and hold to cycle through the dimmer.
Waterproof.
Magnetic base, pocket clip (and can be used while clipped to clothes due to the 90 degree head) as well as a head-mount.
Runs on a 14500 3.7v rechargeable OR an AA (which is a bit dimmer).
Downside is it has a small current draw due to the dimmer memory so your battery will eventually go flat.
orac
PostPosted: 07:00 - 18 Feb 2016    Post subject: Reply with quote
I got me one of these in 9000 lumen variant
https://www.ebay.co.uk/itm/6000-10000-LM-3-9-T6-3-9-x-CREE-XM-L-T6-LED-Flashlight-Torch-Lamp-3Mode-18650-/201494377730?var=&hash=item2eea003502:m:m1S0YUGXmrHx0IoglC6VWxA
it bright enough to get cars to think there is another coming along the road and dip there head lights when walking to shop (I live in the sticks).
mine came with 4 batteries and a charger. batteries last ages, can even run off just one with no affect on brightness (although it will go flat faster)
but it does depend on how small and how bright you need to go, 9000 lumens is about the same as 150w incandescent bulbs.
my torch has also been to the bottom of 3 feet of water and still worked while there, and still works now
The last post was made 10 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 86.72 Kb
