Wtd:- Bike Loading Ramp for Van - Borrow and return for cash
Ninja
Caption Abuser
PostPosted: 18:28 - 14 Feb 2005    Post subject: Wtd:- Bike Loading Ramp for Van - Borrow and return for cash Reply with quote
Hi - I'm after borrowing a bike ramp to accomodate a 240kg bike and me into a van - so total load weight to be no more than 360kgs (oy!) ...
Post to me and I'll post back (I'll meet costs)
OR if you're on the route (see map)
I can pick it up on the way through to getting the bike (FRi PM) and drop it off on the way back (Sat PM)
[edit]no more map[/edit]
Cheers James
(I'm not after buying one at £80 a pop for a one off or cobbling something iffy together if I can borrow one!)
James
4 wheels transport the Body ... 2 wheels transport the SOUL
PostPosted: 20:51 - 14 Feb 2005    Post subject: Re: Wtd:- Bike Loading Ramp for Van - Borrow and return for Reply with quote
You're unlikely to be able to push the bike while standing on the same ramp for most bike ramps, as they are usually only a bit wider than the wheels.
If you're wanting to do it cheapish, some thickish planks of wood should do.
For my van I've got a plank of wood for walking up and a custom made ramp for my van (sorry, only properly fits my van though).
How high the back of the van is, is important. LDVs are pretty high (mine), so wood probably wouldn't work so well, others are lower, so should be ok.
ING
PostPosted: 23:30 - 14 Feb 2005    Post subject: Reply with quote
GET A 6X3 INCH LENGTH OF TANALISED TIMBER, IT WILL WORK A TREAT.
IT'S THE TIMBER USED FOR DECKING JOISTS.
Sparks!
Sir Tart-a-lot
PostPosted: 23:33 - 14 Feb 2005    Post subject: Reply with quote
I use a fold out ramp that my grandad had for his mobility car thingy.. (to put it in the shed) they fold up nicely, light weight and do the trick nicely, doubt they are all that expensive?!
Oh and I last used it to get a supermoto onto the back of an L200 pick up which is ferking high up!!!
Craggles
PostPosted: 00:11 - 15 Feb 2005    Post subject: Reply with quote
If you're renting a van, it may be worth paying the extra for one with a tail lift. Then you needn't worry about a ramp, or collecting/picking up the ramp.
(or even if you have a van, it may be worth just renting one with tail-lift)
Craig
If this signature is blue, you're riding too fast
gsxrboy
PostPosted: 00:26 - 15 Feb 2005    Post subject: Reply with quote
As G said use wood, if you want a grippy surface use a good thick paint to cover the wood then sprinkle sand on it, you dont need much and it will be like walking on sand paper, its what I use at work and my feet are covered in oil.....
www.predatorsport.co.uk Paintball arena located between Northampton and Milton Keynes
Bendy
Mrs Sensible
PostPosted: 00:51 - 15 Feb 2005    Post subject: Reply with quote
We didn't have much luck getting the trailer ramp to work with a van, the van being so much higher than the trailer meant the angle was all wrong. Plus there was nowhere to attach the ramp to, so it slid off impressively and we had to catch the bike in mid air.
Long strong wood for a friendlier angle should work better... our issues were with four people trying to get a vfr400 up it, so a 240kg bike just isn't gonna happen on a short steep ramp.
binge
Emo Kiddy
PostPosted: 09:11 - 15 Feb 2005    Post subject: Reply with quote
I know it sounds dangerous. But if you have a plank of wood which is able to hold 250kg then surely it would beable to hold an extra 70 or so.
If it does, can you not lay one big fat lump of wood from the center, and put another plank about a foot in distance from the middle one. THat way you can ride the bike up, and put your feet on the planks of wood at each side.
Thats what my uncle does to get his Moto Guzzi into the back of his DAF van.
Just mind your head on the way in Laughing
<|Ben|>
Ninja
Caption Abuser
PostPosted: 10:05 - 15 Feb 2005    Post subject: Reply with quote
Thanks all - the back of the van is fairly high and I had reservations about using a 'standard' bike ramp - as Bendy said, the angle would potentially be too acute to safely get up.
2 or 3 big old sleeper style planks will have to do it.
Thanks for looking. Thumbs Up
James
Kris
PostPosted: 14:57 - 15 Feb 2005    Post subject: Reply with quote
Depending on the van, scaffold planks should be long enough to use and take a fair bit of weight. I've used them twice now getting a ZXR750 (heavy old bastid') into vans. Don't be tempted to ride it in though - it will hurt if it falls Shocked
www.prisonplanet.com
Sparks!
Sir Tart-a-lot
PostPosted: 15:05 - 15 Feb 2005    Post subject: Reply with quote
When I picked up my KTM, the person I bought it off rode it from back garden down to the trailer, where my mate jokingly said "go on then, ride it on".. well the bloke selling it thought he was serious so rode up the ramp, got half way up then fell off Laughing
Ninja
Caption Abuser
PostPosted: 15:18 - 15 Feb 2005    Post subject: Reply with quote
I've bought two major planks of wood from my local merchants - 3.6metres long and about 10cm thick by 25cm wide - as well as two boards of hefty plywood - enough to have a comfortably wide and strong ramp.
James
The last post was made 21 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 72.79 Kb
