Drilling holes in airbox
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
smallfrowne
PostPosted: 13:01 - 19 Feb 2016    Post subject: Reply with quote
That's a good one. Sounds like something we'd do at work, fix a leak by drilling more holes Very Happy
It will likely mess up the carb fuelling yes, can you not get a proper intake hose if that one is definitely leaking?
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
PostPosted: 13:04 - 19 Feb 2016    Post subject: Re: Drilling holes in airbox Reply with quote
Fidge wrote:
Will drilling a few holes in the airbox fuck up the airflow and make the bike worse?
BINGO! Mr. Green Thumbs Up
Don't do it. Laughing Laughing
PostPosted: 13:24 - 19 Feb 2016    Post subject: Re: Drilling holes in airbox Reply with quote
Fidge wrote:
The bike has an intake leak at the moment despite being a fairly new pipe
That blue inlet "rubber"? What is that, a piece of drainpipe?
PostPosted: 13:26 - 19 Feb 2016    Post subject: Reply with quote
Dab of grease here n there wouldn't go amiss.
PostPosted: 13:45 - 19 Feb 2016    Post subject: Re: Drilling holes in airbox Reply with quote
Fidge wrote:
My SR 125 seems to have the shitiest looking air intake ever, it is also a slow bike.
https://i.imgur.com/ylGR7ao.jpg
The bike has an intake leak at the moment despite being a fairly new pipe, I think it is due to the very small air intake holes. Will drilling a few holes in the airbox fuck up the airflow and make the bike worse?
Yes, that blue pipe is an abortion of a bodge.
It looks, among other things, far too long and inlet stub length is important.
You need a new "joint, carburettor 2" part number: 5H0135960000
Look what your uncle stinkwheel found you for only £8.07!
Or pay three times as much on ebay.
Buy a couple of new hose clamps to suit while you're at it. The parts supplier will do you proper (but expensive) hose clamps or you can buy some jubilee clip type ones like you're using, just need to be a bit narrower to fit in the groove.
I preferr the t-bolt type clamps rather than jubilees for this kind of application.
EDIT: Wow. Silicone coolant hose with varouriosed petrol in it! What could possibly go wrong?
I'm amazed it hasn't totally shit itself by now. That stuff is entirely inappropriate for what you're doing.
Triton Thrasher
PostPosted: 20:44 - 19 Feb 2016    Post subject: Re: Drilling holes in airbox Reply with quote
You'd be surprised how long black rubber radiator hose can last in that application.
Rrrrrrrrrrrrrrrrrr
PostPosted: 21:08 - 19 Feb 2016    Post subject: Re: Drilling holes in airbox Reply with quote
Yeah, but that's silicone. It'll go all floppy then split when exposed to petrol.
Triton Thrasher
PostPosted: 22:46 - 19 Feb 2016    Post subject: Re: Drilling holes in airbox Reply with quote
I kind of naively assumed it would be "better."
Rrrrrrrrrrrrrrrrrr
haroman666
PostPosted: 23:05 - 19 Feb 2016    Post subject: Reply with quote
Yamaha probably spent a fair sum of development cash creating an air intake design that benefitted the induction for all-round good performance at all levels of airflow.
Drilling holes may seem like a great idea for gaining many horsepowers with the increased airflow, but you'll probably create a shitty low to midrange performance and you might end up suffering from water based problems riding in heavy rain or spray.
Ebay will be a great place to find a new carb rubber. Definitely change that!!
stevo as b4
PostPosted: 23:06 - 19 Feb 2016    Post subject: Reply with quote
Nomex hose would have been better, but the issue is sealing the manifold and carb, as proper joiners have a lip or ridge inside to locate the parts usually.
redeem ouzzer
PostPosted: 23:11 - 19 Feb 2016    Post subject: Reply with quote
Put it in a skip, attached to the bike
Be a REAL MAN!
spannermonkey...
PostPosted: 15:43 - 26 Feb 2016    Post subject: Reply with quote
It's slow bike to start with compared to other 125 Yamaha's of the era. I've ridden one, something of the 90's a four stroke chopper.
Every year folk drill speed hole into air boxes, fit high flow filters and see very little performance in a misled belief.. All you will get is more induction noise and less power. Unless you tune the engine and play with fuel and timing, intake/exhaust sizes and bores.
Stop reading all the rubbish on products on websites that if you bolt it on instantly you will have fire breathing horse power it's all sales hype. Their is more to tuning than a drill and bolt on mods
Speed holes in your air box will mean. The carb will run leaner. More air into your engine but the same fuel as you haven't re-jetted. Less fuel in, less bang, less go. Resulting in your engine running hotter and leaner.
Don't bother, as long as you have a good spark, clean fuel, clean carb and air filter then just enjoy it. Then move onto something bigger at a later date.
Current machines - Aprilia RS250. Kawasaki H1A 500. Past machines - Kawasaki ZX7r P6, Yamaha RD250E (the one that got away), BSA Racing bantam (revs over 10'000 sweet as), Yamaha RXS100, Suzuki GP100, Suzuki GS500K2 - best all year machine ever - come rain, sleet and snow just epic.
Fin
PostPosted: 22:17 - 01 Mar 2016    Post subject: Re: Drilling holes in airbox Reply with quote
It has gone floppy Laughing, Bike cut out on way to college, started again and noticed the intake pulsates with the engine, it sucks in and then releases. Still waiting for the correct intake to dispatch, think I'm going to have to put a 3rd pipe on but make it a bit shorter this time.
Fin
PostPosted: 10:45 - 10 Mar 2016    Post subject: Reply with quote
https://i.imgur.com/W6V7K7v.png
Fucking perfect, wait 20 days before telling me Evil or Very Mad
PostPosted: 11:38 - 10 Mar 2016    Post subject: Reply with quote
Sort out that corroded connection on the battery, it will cause you issues.
Fin
PostPosted: 19:25 - 10 Mar 2016    Post subject: Reply with quote
I did, and it did cause small issues such as the engine not firing at times and the worst was missfiring/ ignition timing going out while screaming it going down a hill round a corner.
About the intake/inlet pipe, it runs quite well at the moment with the one that is too long on there, If I grind off the alignment pins and get some pipe that won't disintegrate when exposed to petrol and make sure it is the right length, clamped on tight enough and the carb is level then I should be fine. All the correct joints are around £20 and the one I have at the moment works fine and has done for almost 1000 miles, If I get one a bit shorter then it should be better (getting to top speed consistency and trying to pull away fast).
edit: also found out I was being very very special and the little notches weren't the air intake :Embarrased:
The last post was made 9 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 107.65 Kb
