Fuel leaking out of carbs - 600f2/3 1995
blinky
PostPosted: 00:18 - 19 Feb 2016    Post subject: Fuel leaking out of carbs - 600f2/3 1995 Reply with quote
Hi guys,
Fired up this bad boy yesterday, putting the biggest grin on my face... Mr. Green Mr. Green
...but not for long...
Took it around the block but it then started to flood gasoline all down my leg so i had to pull over fast, ha! So, turned the tap off but it then wouldnt even start, so i had to push it back... boooo! Evil or Very Mad
However it then started 10mins later... where i was able to find the hose leaking fuel.
Bike has been sitting outside for more than 2years sadly...
Pretty sure its carb 1 or 2 flooding... hmm due to float stuck (from stale petrol etc.)??
is there a quick/temporary fix for this please?
Seafoam??
Blasting any crap out of the carbs by not taking them out of the bike?? hmm either by compressed air (after removing tank of course), or by revving the engine more high??
((i really dont want to have to take the carbs out! **gulp** ))
OR im guessing one of the hoses could be 'worn'/pinched/routed badly?
Maybe i seated the airbox badly? (il double check that tomorow).
breather or overflow hoses from tank related?
is there a fuel pump i should check/open/inspect?
Safe to 'clamp' the leaking hose?? to increase pressure in the carb (or will this damage it)
PHOTOS ATTACHED (red line=leaking)
Rolling Eyes
I started with replacing the battery, emptying the tank completely then put 4L inside, opened and wd40'd both left and ride hand switches, incl throttle and choke cables...
Drained the carbs (dark green fuel came out, ew!), checked the air box, filter and throttle valves to see if theyre moving together in line.
Sprayed carb and brake cleaner down each intake hoping some will get into the carbs!
*didnt take carbs out.
*didnt check spark plugs.
*didnt check regulator or electrics, but they seem ok!
*didnt change oil (not yet).
++ Bike fired up with half choke and little throttle, but needed constant tinkering with idle and choke. (little stubborn)
limited tools, but i can do most jobs myself and am a keen learner. i have a manual but still unsure if this model is f2 or f3. doesnt matter imminently.
cheers very much Thumbs Up
Better to ask forgiveness than permission!
Oh i miss my first love, the lovely lil CG!
Rouser 135 2012... Enfield 25... Hornet 600 2002... CG125 2000
mudcow007
PostPosted: 09:17 - 19 Feb 2016    Post subject: Reply with quote
take carbs out, clean em
check float needles for wear (mine leaked from there)
check floats move easily etc
reset/ check float height
might be worth sniffing the oil too, it "might" be full of motion lotion
refit carbs...bobs your auntys nephew
blinky
PostPosted: 21:38 - 20 Feb 2016    Post subject: Reply with quote
Ok cheers mate! Thumbs Up
There really isnt anything else i can try before i go that route?
I just put some redex fuel cleaner in the bike last night and idled it whilst clamping the hose to flood that carb, so it might work... but pushing my luck eh! Laughing
Will check it tomorrow.
If i do remove carbs, i then need to make sure i can get 'original' (new or 2nd hand) parts beforehand right?
such as, like you said, a new float... but also possibly carb boot/s and various carb seals/o-rings..
This is my first time, so forgive my hesitance! Confused
I should come up with a nice degreasing dip to soak the carbs in too right? i recall many debating over the best mix.... what would you suggest? diesel mixed with carb cleaner spray??
Do i really need compressed air? The same stuff used for Computer/electronics cleaning? Theyre like £14 or $20 a can! Shocked
temeluchus
PostPosted: 22:32 - 20 Feb 2016    Post subject: Reply with quote
Large can of carburettor cleaner will do for blowing out the various small passageways. Acetone can also be purchased quite cheaply for soaking stuff in. Remove all plastic and rubber bits beforehand obviously.
I'd suggest replacing the various seals and gaskets whilst you are at it. Almost certainly worth replacing the float needles.
Carefully inspect the float valve needles.
https://www.3cyl.com/mraxl/manuals/carbtune/wornneedle.jpg
any sign of a line like the one on the left, replace them.
genuine
https://www.fowlersparts.co.uk/parts/view/16155MBZK31
pattern
https://www.ebay.co.uk/itm/Honda-CB600F-CB600-Hornet-1998-2006-Carburettor-Float-Needle-Valve-x-4-/171322148788?hash=item27e39887b4:g:olAAAOxyOalTaVEp
mudcow007
PostPosted: 20:59 - 21 Feb 2016    Post subject: Reply with quote
Me personally I wouldn't bother trying anything else except cleaning the carbs out - one of the joys of owning a carb running bike....
Carb or brake cleaner for doing the insides of your carbs - its cheap
As above poster said, you can use acetone but it swells seals etc so best to avoid rubbery bits)
My bike was manky when i got it (still is) carbs were blocked solid with old fuel an general crap, a few bottles of carb/ brake cleaner an it was good to go - its good practise taking them to bits anyways
Ideally use an airline from a compressor is how I do mine - know a mechanic or anyone with a garage?
oh an get some pictures up
good luck
blinky
PostPosted: 05:36 - 22 Feb 2016    Post subject: Reply with quote
Ok cheers guys... Laughing
Mr. Green Fowlers! THats Bristol's main dealer... Cool! Not the cheapest place, but if i need original parts quick, theyre the best place.
Il get right on the search for acetone then i guess.... hmm i wonder if i can put the whole carbs as a whole into the acetone? ..or is there rubber seals i would need to remove?
or i give to a shop or someone to ultrasonically clean them.... but i have to fully dismantle the carbs if i go that route... im still deciding on this.
PostPosted: 19:49 - 22 Feb 2016    Post subject: Reply with quote
No. because a) Yes there are rubber bits and b) The moving parts you need to clean are inside the carburettor so cleaning the outside is a pointless exercise.
Acetone can be handy but I'd just go with ordinary brake/carb cleaner spray if I were you.
Commuter_Tim
PostPosted: 19:54 - 22 Feb 2016    Post subject: Reply with quote
I've read horror stories of rubber seals on carbs perishing when brake cleaner is used?
It could all just be a big scam, but considering there are also recommendations to not use Brake Cleaner on Oring chains, personally I wouldn't risk it to save £5.
I ride a Bandit 600... badly.
blinky
PostPosted: 23:16 - 18 Mar 2016    Post subject: finally back again! Reply with quote
hi guys... finally got back to sorting the bike. (life distractions here)
right....
I got the carbs off eventually (had to borrow a crowbar from a friend to get them off!!) ...anyways, carb no. 1 and 3 were nasty inside, but needle valves seem ok... so i dont know why carbs are flooding! ....soo i will still go ahead and clean them!
unfortunately the screws on the float bowls and diaphrams were overtightened/old so when i tried to open them the soft metal just melted/came away... so il have to buy new screws all-round, and also an air filter as it fell apart when i checked it.
1. ive got the metal parts (3 jet bits for each carb) soaking in carb cleaner for 2days now, and the rest (floats n pin-valves) in fresh petrol.
2. the carb body ive actually left it in 8L of cola and lemon juice.... apparently this is a good cleaner and obv wont affect rubber parts.
3. I will then remove the carb body from there and use carb cleaner on important metal parts...
4. Then i wasnt sure if the carb cleaner will evaporate off enough, so i was then going to soak the carb body in hot water w strong washing up liquid, for a night.
...then change the water for PLAIN water to flush any contaminants out.
...air dry for a couple days or more.
...reassemble carbs and put back on bike (praying no problems here).
Hope my procedure of cleaning is ok. Mr. Green
i do have pics, but i think you guys understand everything hehe!
il report back with results shortly!
ERRR can i ask, i loosened the 4 diaphragm caps only, but didnt open them yet.... is it ok to leave them alone generally? (i dont want to risk getting them out/damaging them).
Oh, and can i apply carb cleaner to these?? (i think it would harm the plastic surely?) Rolling Eyes
cheers muchos! Thumbs Up
pompousporcup...
PostPosted: 07:43 - 19 Mar 2016    Post subject: Reply with quote
Did you leave the diaphragms/needle in when dunking the lot in cola?
If they're now covered in a sticky cola mess they will need to come out and cleaned.
blinky
PostPosted: 04:01 - 24 Mar 2016    Post subject: Reply with quote
ERMM something a little troubling has come up!
my jets that i removed from each carb (3 bits), ...no. 1 and 4 should be one size, and 2 and 3 should be another, right??
it was only when i went to the local bike shop to blow air through them that someone mentioned this to me... and was astonished to find that ALL of my jets are the same size!! (checked the serials on each)
is this a big deal?
...maybe just decreases performance slightly??, but cant be that bad, as i was riding it a few years ago with no serious problems. Thinking
pompousporcup...
PostPosted: 14:08 - 24 Mar 2016    Post subject: Reply with quote
did it run right with those yets in? If yes then there isnt an issue and you can just reassemble carbs.
I think some carbs have different size jets to account for intake manifold design where 2 cylinders are linked and one of those cylinders gets more air than the other *
*just a guess there
PostPosted: 19:43 - 24 Mar 2016    Post subject: Reply with quote
is this a big deal?
This can vary even between different versions of the same model.
The centre pots get hotter so they'll sometimes run them slightly richer so they are cooler. Some areas have more stringent anti-pollution rules than other so richening up two of the pots isn't always possible. An engine in a higher state of tune will also be more likely to have different jetting. The 600F is in a relatively low state of tune.
Ultimately, you'd need to check the parts lists for your exact model but I think it's unlikely someone would have gone out of their way to screw with the jetting to such a tiny degree (it's never a big difference anyway).
blinky
PostPosted: 03:17 - 25 Mar 2016    Post subject: Reply with quote
Yup, it was a little rocket back when i bought it a few years ago... i think its had at least 15 owners (according to the log book!!)... which suggests anyhting could have been done to it frankly. Rolling Eyes
i picked it up ridic cheap back then, and got to test it before buying. it ran well and went in a straight line.... so was a steal for what i paid Wink
anyways, already reassembled everything, and will test it on Tuesday... now for a nice looong easter weekend away! Mr. Green
cheers guys, happy riding, and happy easter! Thumbs Up
blinky
PostPosted: 01:43 - 31 Mar 2016    Post subject: Reply with quote
Great news!! just to update everyone.....
BIKE IS RUNNING OK NOW!!!
...and sweeter than ever... like a little rocket on steroids. I'll actually have to get used to this bike all over again. Not the most comfortable but still a nice blast whilst getting around.
Next up, the MOT!! Confused
cheers mate... i was considering getting the in-line filter... but just washed out the tank twice and shook it furiously over a drain instead hehe.... will see how it goes.
Thanks again guys, you rock!! and Happy riding! Very Happy Thumbs Up
The last post was made 10 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.41 - MySQL Queries: 15 - Page Size: 100.86 Kb
