marauder GZ 125cc
BoroBoy1965
PostPosted: 19:43 - 22 Feb 2016    Post subject: marauder GZ 125cc Reply with quote
Hi guys need some advice i've have the two dash signal indicator lights not working since i got the bike so i've changed the bulbs and visually the wires look ok Also the back brake right comes on when I pull the brake lever but when i use the foot peddle to brake it stays off. i looked at the fuses near the battery but im not sure. I took photos for you to see and also notice a fuse was missing but i've heard some are due to European bikes need it so its there for that. I'm a noob on this so i could do with some advice if possible.
cheers
talkToTheHat
PostPosted: 03:22 - 24 Feb 2016    Post subject: Reply with quote
Rear brake has a separate switch, operated by a second cable coming from the pedal, follow this back to the switch. Try pulling the operating rod further out of the switch than the brake pulls it, if this gives you brake lights then turn adjusting screw on switch until it is set properly. If that fails, trace wires from switch back to the connectors. Short both sides of the connector together with a paperclip or a spare bit of wire. If you have brake light now replace brake switch. Pattern ones are about a fiver. Remove paperclip.
as for your idiot lights, get a 5 pound multimeter and learn how to use it. Get wiring diagram from haynes or similar.
Tracking down electrical faults is a ballache. One of my marauders had a hacked alpart loom and took some sorting. My xv had aging cables in the loom. Patience and a multimeter.
Bandit. does. everything.
BoroBoy1965
PostPosted: 17:32 - 24 Feb 2016    Post subject: Reply with quote
Thank you very much excellent advice I can follow this easily, Ill repost the results later. Cheers
The last post was made 10 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 36.36 Kb
