Help? cg125 replacement con-rod wrong size
dsharman1
PostPosted: 10:19 - 24 Feb 2016    Post subject: Help? cg125 replacement con-rod wrong size Reply with quote
Hi, i have a bit of a situation here. First of all i will state that the engine is not the one that is registered to the bike so all parts have to be ordered by the engine number,the engine number matches to a 2001- CG125M1 .
So what happened is the big end bearing needs replacing so i stripped it down myself and ordered a con rod kit going by the model which the engine is from ,I then took just the con rod kit and the crankshaft to a bike garage to have them split it and put the new bearing in. However i have now been informed that the con rod i have supplied is 2mm too short so i dont know how im going to be able to find the correct one. I dont even know if the one i supplied is the correct length and that it had a different one in before since i dont really know much about the history of the bike , any help would be much appreciated.
Aprillia rs 50 2000
derbi city cross 125 2007 (RIP 08/2015)
Honda CG 125 2001
dsharman1
PostPosted: 10:06 - 25 Feb 2016    Post subject: Reply with quote
anyone ?
Aprillia rs 50 2000
Honda CG 125 2001
Suntan Sid
PostPosted: 12:02 - 25 Feb 2016    Post subject: Re: Help? cg125 replacement con-rod wrong size Reply with quote
Have a look at this site:-
https://www.mitaka.co.uk/ROAD_CON_RODS.htm
It lists various con rods, with dimensions, it shows there are 2 different length Cg125 con rods, 103.5mm and 105.5mm!
Return the one you bought and order one of the correct length!
dsharman1
PostPosted: 13:47 - 25 Feb 2016    Post subject: Reply with quote
right, if only i had seen this reply a bit sooner but what i have gone for instead is i have now bought a xr125 bottom end off ebay which had a good big end and main bearings, also the little end takes the same size gudgeon pin which my piston takes so i was going to put my top end onto that
Aprillia rs 50 2000
Honda CG 125 2001
Suntan Sid
PostPosted: 15:40 - 25 Feb 2016    Post subject: Reply with quote
Well, at least you have the correct one now!
Can you get a refund on the new one you bought?
Robby
Dirty Old Man
PostPosted: 17:11 - 25 Feb 2016    Post subject: Reply with quote
Isn't the XR125 an OHC engine, where the CG is OHV?
Suntan Sid
PostPosted: 17:33 - 25 Feb 2016    Post subject: Reply with quote
The XL is OHC, the recent Xr125's have CG engines!
davebike
PostPosted: 08:46 - 26 Feb 2016    Post subject: Reply with quote
Early XR were overhead cam later used Overhead valve CG type engines
I had an XR200 with the early engine super fun
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 10 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 56.34 Kb
