How to: Front Wheel bearings - Picture heavy
haroman666
PostPosted: 18:30 - 28 Feb 2016    Post subject: How to: Front Wheel bearings - Picture heavy Reply with quote
So off the back of my What wheel bearings do you prefer? thread I decided I'd document the process of changing them in detail.
It's an easy job (Depending on bike age, corrosion, % of Bodyguard disease) and instread of throwing £30 - £60's worth of labour money at a garage, you could throw that money at the tools you need to do the job for the rest of your riding career.
So, first up is get the wheel out. Calipers may have to come off in order for this to happen. If you get stuck at this point, then go no further. You may as well go and buy a Netflix subscription and spend the rest of your days on the sofa.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_001_zpse4ydymce.jpg
Lever your seals out. Flatblade screwdriver is all you need. If they're particularly shitty, you might have to really give it some, and work your way around the circle, and lever small amounts at a time. If you want to save the seal and re-use it, then just try not to rip any of the rubber. But likelihood is, is that the seal is the reason the bearing is fucked in the first place. So change them.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_003_zpsvwbatnhg.jpg
Tip: Don't lever against the brake disc. Get another screwdriver or something to lever off.
At this point (With both seals out) you can look at the levels of corrosion you're dealing with and whether you need to leave it soaking in some penetrating oil, like Plusgas. Anything over 10mins for it to work it's way in, should be fine.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_010_zpscr54xyli.jpg
Also, check your new bearings are the correct size.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_006_zpsngsk3rwv.jpg
The wheel bearings have a long tubular space between them, and this rests between the inner races (bearing anatomy should be researched if you aren't sure where that is). Paint diagram winning:
https://i1247.photobucket.com/albums/gg630/haroman6661/Epic%20wheel%20bearing%20diagram_zpsrq5ni593.jpg
Note the blue lines showing the wheel casting. One side is tight to the spacer. The other side leaves a small gap. This is important to observe when taking the next step.
The aim of the game here, is to lever/knock that spacer off centre so you can see the inner edge of the inner race when you look through. The spacer will only move off centre on one side of the wheel (See previous diagram and note for clarity). You can lever it with something or give it a gentle bang. You may end up burring the edges or inside of the spacer doing this, so have a round file handy in case. It needs to end up much like this:
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_005_zpsfs6x0p1d.jpg
The dark crescent you see inside is the inner edge, of the inner race of the bearing. Bang that shit. With a long punch and a hammer that matches your personal levels of ham-fistedness:
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_008_zpsdlsnjsfa.jpg
I ground the pointed "chisel" end off of mine, because the corners were chamfered and it slipped with every hit of the hammer.
Be sure to have the wheel supported with either wood or similar (or a kerb like I have done here. Being super SUPER sure the brake disc off the floor so it doesn't end up looking like a floppy tortilla).
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_011_zpseddsi4ev.jpg
BANG BANG BANG POP! Hit the inner edge of the inner bearing race from the opposite side. And be sure to move to different parts of the bearing race so as to not put the bearing on the wonk and get it really really stuck.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_009_zpsukuv5tym.jpg
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_012_zps1sphlk5k.jpg
Now one bearing is out, along with the spacer and you should look inside the wheel and see the back of the other bearing. See how the holes are different sizes as mentioned before...
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_013_zpsn9ojopeh.jpg
Bang that other bearing out, like it tried to hit on your girlfriend.
See the difference between my bearings. One is nice and clean. The other is much rust. Very corrode. Wow.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_015_zps46wjuxxz.jpg
Now. To get the new bearings in, there is some more banging to do (Unless you have a press, in which case there's some pumping to do).
I took one of the old bearings and ground a bit of material off the outer race so that I could use it to drive the new bearing home without this one getting stuck in the wheel recess. You can also use a socket of the same diameter too. but likelihood is, is you haven't got one large enough.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_016_zpsdcyks6ux.jpg
Lube up the bearing recess and the outer edge of the bearing.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_018_zpszyfrf1ve.jpg
All purpose lithium grease is best. DO NOT use copper grease. Not ideal. Nope.
Before you start banging in bearings left right and centre, be sure you put the bearing with the smaller wheel casting hole, in first. This is so when it comes to doing the opposite side, the space can sit upright and central (Picture further down)
Place the new bearing as straight as you can in the recess, so that it doesn't go in wonky. Take the old bearing (wot I ground down) and place it ontop. Going around the outer race, bang this bastard in. Little bit at a time until the note of each bang becomes more of a "solid sound". And you should feel a more noticeable reverberation through the hammer too.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_020_zps3yqtylgh.jpg
I couldn't hold the bearing, hammer and take a picture at the same time. So imagine the hammer!
Stick the spacer in, and let it sit in the hole, up against the inner race of the bearing you just hammered in. (Refer back to the note about which bearing goes in first).
See how the spacer sits upright and central. There's a good little spacer Thumbs Up
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_022_zpsnl2swv7c.jpg
Bang in the other bearing, much like you did with t'other one. But check the spacer is still standing to attention in the correct position.
Aaaaaaaand finally grease and push your NEW seals in. Should be a finger jobby. Or thumbs... Whatever's best for you.
https://i1247.photobucket.com/albums/gg630/haroman6661/WP_20160228_023_zpsf8caycaw.jpg
Refit wheel and calipers. Torque everything correctly. Don't even use the new wheel bearings because you wheelie everywhere cause you're like fuckin Rossi m8.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:52 - 28 Feb 2016    Post subject: Re: How to: Front Wheel bearings - Picture heavy Reply with quote
haroman666 wrote:
Probably the scariest picture I've ever seen. Next time borrow a front paddock stand.
Triumph Sprint ST 1050
andym
PostPosted: 20:08 - 28 Feb 2016    Post subject: Re: How to: Front Wheel bearings - Picture heavy Reply with quote
Nobby the Bastard wrote:
Why?
https://img.photobucket.com/albums/v320/andy36586/VFR_zpsc12mwnct.jpg
Suntan Sid
PostPosted: 20:21 - 28 Feb 2016    Post subject: Re: How to: Front Wheel bearings - Picture heavy Reply with quote
It is a front stand, I inherited one, admittedly it's not a very nice one, but it does work on some bikes, not on others, it depends on the location of the lugs for the callipers and the position of the axle bolt!
-Monty-
PostPosted: 20:24 - 28 Feb 2016    Post subject: Re: How to: Front Wheel bearings - Picture heavy Reply with quote
That is a front paddock stand...?
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
PostPosted: 20:53 - 28 Feb 2016    Post subject: Reply with quote
Worth mentioning that some bikes have a circlip round the outside of the bearing, and potentially a speedo drive casting.
These need to be removed before proceeding with driving the bearing out. If there is a lot of corrosion, the circlip is not always obvious.
Also be aware it can take quite a long time and a lot of battering to get a r3eally tight bearing out.
I personally would not grease the bearing seat area. I'd clean and degrease it. A green pot scourer is good for removing any corrosion off the seat. You shouldn't be making it any easier for the outer race to turn than you need to. In cases where it's loose, you sometimes need to use bearing fit compound which is a kind of glue to stop it spinning up.
Here's a video I did a while back of changing a front wheel bearing. It is deliberately not cut and is essentially 5 minutes of me whaling on it before flipping the wheel over and finding the other one came out much easier. Shows you just sometimes need to be patient.
https://youtu.be/obPQMiQgZv0
Here's fitting the new ones:
https://youtu.be/DMDNjfcVRss
redeem ouzzer
PostPosted: 21:00 - 28 Feb 2016    Post subject: Reply with quote
This is frighteningly "ghetto". Best way of getting the first race out is to spot weld a nut on the inner race to use a drift against. Use a manual press to put the new bearings back in (or make one using threaded rod, nuts and washers / old bearings).
Be a REAL MAN!
techathy
PostPosted: 21:06 - 28 Feb 2016    Post subject: Reply with quote
I found my pushbike headset & wheel bearing press worked well for this job.
PostPosted: 21:24 - 28 Feb 2016    Post subject: Reply with quote
If we're being pedants, the actual correct way is to use a slide-hammer bearing puller. Which can be bought for under £20.
Cheaper and less hazardous than a welder.
haroman666
PostPosted: 21:58 - 28 Feb 2016    Post subject: Reply with quote
The intention was that it was to use most tools any newbie /home mechanic would already have.
I had a threaded rod, washers and large plastic discs that I bought for pressing the headset races on my mountain bike. The plastic discs cracked instantly and I resorted to knocking it in.
Using a hammer is fine, so long as care is taken to not be too zealous with the whacking!
I resent the term ghetto!!! I spent a lot of money on my tools!! Laughing
Pigeon
PostPosted: 23:13 - 28 Feb 2016    Post subject: Reply with quote
I thought this was an excellent effort and great post *. Plenty of pics, good descriptions. Top effort Sir Thumbs Up
* I am 90% moron however, so take with much salt.
Bridgehouse
PostPosted: 23:33 - 28 Feb 2016    Post subject: Reply with quote
I agree. Pop to your local Machine Mart, or even order in the new fangled online way, and pick up a bearing puller. Mine came in a set with slide hammer and 4 different sizes of pullers. Was about £45 I think.
2015 Triumph Street Triple - 2015 Honda CB500F - 1976 CB400 Four (Stripped - and undergoing restoration)
Matt B
PostPosted: 11:18 - 29 Feb 2016    Post subject: Re: How to: Front Wheel bearings - Picture heavy Reply with quote
I too must applaud your bravery in using that stand, just looking at it makes my palms sweat.
Great job Thumbs Up Ignore the correct tool pedants - old seals and bearings came out, new ones in. I would say that is 100% win.
MarkJ
PostPosted: 13:22 - 29 Feb 2016    Post subject: Re: How to: Front Wheel bearings - Picture heavy Reply with quote
Good guide Thumbs Up
Can I also add, on some bikes (my K1 GSXR1000 for example) you drive the new bearing for one side all the way in until the outer race is flush to the casting, but the other side you drive in until the inner races hold the spacer in place enough for it to not move around by gravity, but still allow you to move it with your fingers. If you drive the second bearing all the way home the spacer will be putting a lot of pressure on the inner races and the spacer will be very hard to move by hand. The bearings will wear out very quickly.
PostPosted: 14:17 - 29 Feb 2016    Post subject: Re: How to: Front Wheel bearings - Picture heavy Reply with quote
andym wrote:
Pfffft. Amateurs!
https://i48.photobucket.com/albums/f216/stinkwheel/Image020.jpg
MarkJ
PostPosted: 14:42 - 29 Feb 2016    Post subject: Re: How to: Front Wheel bearings - Picture heavy Reply with quote
stinkwheel wrote:
Pfffft. Amateurs!
Axle stands? Luxury!
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1886Copy.jpg
The last post was made 10 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.64 - MySQL Queries: 15 - Page Size: 111.86 Kb
