Street Triples, Power Commanders, remaps and stuff.
chickenstrip
PostPosted: 13:18 - 01 Mar 2016    Post subject: Street Triples, Power Commanders, remaps and stuff. Reply with quote
So I have this Striple, on an 11 plate (refer to as 2010 Striple?) and it has a PCV fitted. It is my first FI bike since my Kwak Turbo, and I know less than FA about all this. It seems to run sweetly, no complaints there, but I'm shortly going to replace the can (aftermarket, single), and was wondering if I'm likely to have to remap? I also read somewhere that this model of Striple shouldn't have needed a PC, as maps are available online for the original Triumph set-up, which was changed on later models so you couldn't do that anymore? Enlightenment welcome Smile
PostPosted: 14:37 - 01 Mar 2016    Post subject: Reply with quote
I mapped my own with a cable.
I'd just change it mate, its likely been fiddled before.
PostPosted: 14:52 - 01 Mar 2016    Post subject: Reply with quote
I thought it was only the latest that were locked down and could not be remapped? A Power Commander is a waste of money if so. What shape lights does yours have?
chickenstrip
PostPosted: 15:13 - 01 Mar 2016    Post subject: Reply with quote
It's a round-eye. The PC was on it when I bought the bike, only discovered it on removing the battery to pop it on charge. I was afterwards led to believe there was no point in having it on this model/year - something to do with maps being available online that download straight to the Triumph ECU or some such?
Pigeon
PostPosted: 21:07 - 01 Mar 2016    Post subject: Reply with quote
I know nothing about either PC or TuneECU (I did use TuneECU to balance throttle bodies but on my version of the ST, the ECU is 90% locked, so that's all I could do).
Does Power Commander come with software to help you make a map?
Does TuneECU allow you to make/tweak maps or just upload them?
Could be a previous owner didn't realise that a PC wasn't needed, or it gave them more options maybe.
EDIT:
In response to the question about cans and maps. Generally, if it's just a can and you are leaving the baffle in, you can probably run it on the stock map.
If you run baffle out, or use a full system, then a remap is definitely needed.
I got mine mapped by Triumph to their Arrow can map and noticed.....nothing.
chickenstrip
PostPosted: 21:51 - 01 Mar 2016    Post subject: Reply with quote
I know nothing.
The PC sits there under the seat. There is nothing in amongst the bike's documents about it.
I'll swap the cans when the new one arrives and see how it runs. But would be nice to start learning a bit about this stuff. I do have a clue as to what remaps can do/are used for, but no in depth knowledge.
PostPosted: 08:02 - 02 Mar 2016    Post subject: Reply with quote
Power commander still list a model for the 2015 street (with no notes)? The PC doesn't directly fiddle with the ECU as I'm sure you know, it applies a correction to it......so the ECU wouldn't know it was there.
PostPosted: 08:03 - 02 Mar 2016    Post subject: Reply with quote
chickenstrip wrote:
I know nothing.
https://www.powercommander.com/powercommander/powercommander_maps_installs_product_buy_options.aspx?mdlyrid=21-004&make=37&model=133&make-n=Triumph&model-n=Street%20Triple%20675&year=2011&mk=37&mdl=133&yr=2069
Some maps here should get you in the ball park.
PostPosted: 08:07 - 02 Mar 2016    Post subject: Reply with quote
Not trying to teach anyone to suck eggs on this. Tune ECU and Power Commander are doing two different things.
Tune ECU is remapping the ECU directly.
Power Commander is a piggyback module that applies a correction to ECU's fuelling value on the fly. You can rip the PC off and it'll be instantly returned to stock.
Unless I'm misunderstanding Tune ECU.
As an aside, does your Power Commander have the auto tune module, or has your o2 sensor been eliminated?
chickenstrip
PostPosted: 11:22 - 02 Mar 2016    Post subject: Reply with quote
Teach away! I have the most limited idea of what it all does and how it does it, so anything I can learn has to be a good thing.
I don't know about whether it has an auto tune module or whether the o2 sensor has been eliminated. Don't even know what I'm looking for to check Rolling Eyes
Edit:Oh, ok, I see the auto tune module on the website - haven't seen one on the bike, certainly not under the seat with the PC itself.
stevo as b4
PostPosted: 18:51 - 02 Mar 2016    Post subject: Reply with quote
Id still be wary of any off the shelf map for exhaust or filter changes being 100% perfect.
If it were me, I would change the exhaust to the one that you want, and then pop it on a dyno for a run to check if it's rich/lean anywhere in the load/rev range before tweaking the PC or downloading a new map to the factory ECU as appropriate?
Auto tuning from what I have read can only get you so far too. As all ECU's ignore closed loop inputs at WOT and high rpms, and use the factory programed look up tables.
Also having read about self mapping and auto learn functions with ECU's, out on the road you can never tell the difference between 1-2bhp etc when small corrections are made. Many decent automotive ECU mapping experts would agree that the only way to map an engine to get the absolute most performance at every speed/load is to run it on a dyno and take stabilised power readings at every load site.
PostPosted: 20:40 - 02 Mar 2016    Post subject: Reply with quote
The map off of the site won't be 100% perfect, however it'll be ball park, and probably better than how the bike left the factory with it's standard ham strung settings. It left the factory maybe 60% perfect, so a generic map from the PC site might take it to 80% for example.
And it depends on the re-fuelling module used. There are some that can map the bike constantly. Just because the ECU ignores the reading from the O2 sensor at WOT, doesn't mean that the module has to. I can't speak for PCV, but there are modules out there that can and will autotune. Mapping on a dyno is one way of doing it, but it's far from perfect. What if you map at sea level and live on top of a mountain? What if you map in winter? What if the dyno cell has crap ventilation or air flow? So many variables, so it's very difficult to get the fulling 100% on all of the time for every situation.
My personal opinion would be get your exhaust on, download the closest map. If you're feeling really anal, get a power run down and see how close it is (on a variety of loads) then make the call on if it's worth going for a full custom map or not.
PostPosted: 20:43 - 02 Mar 2016    Post subject: Reply with quote
From a thirty second google it would seem that your O2 sensor should live just beneath your brake side footrest. It's a bung with a wire coming out of it. If it's been removed you'll just have a blanking plate there.
stevo as b4
PostPosted: 23:58 - 02 Mar 2016    Post subject: Reply with quote
I agree that a good factory developed map or an aftermarket product manufacturers worked out map should be close enough to get like you say pretty decent performance and drivability and often better these days than std emissions and noise friendly compromised std factory maps.
I do agree that mapping ECU's even on a rolling road is open to variables and isn't perfect. Auto tuning is possible with aftermarket units, but it's only as good as the parameters you tell it to use. For example all engines are different and you or I would not know what amount of ignition advance or air fuel ratio will give the highest possible power output, and if we changed it a few degrees either way and found 3-4bhp, we couldnt or wouldn't feel it or know what setting was giving max
Bhp.
I'm having aftermarket management fitted to my car this year and am looking forward to watching it be live mapped on the dyno and see how they go about it and arrive at the best settings via monitoring o2 sensors, knock sensors and being able to use interpolation between points and cells.
At the end of the day if the bike with whatever pipe fitted pulls smoothly through the Rev range without flat spots, black smoke or hesitation, and does not pop and bang on the overrun it's probably a good enough map anyway.
chickenstrip
PostPosted: 00:31 - 03 Mar 2016    Post subject: Reply with quote
Ok, ok, no need to rub it in Laughing
This is me. So it'll be try the can swap; if it all runs sweet, good enough. Was just curious though, having discovered the box of mysterious magic that is fitted. Thanks for your replies folks, I feel a little more enlightened Thumbs Up
bladerunner
PostPosted: 13:43 - 03 Mar 2016    Post subject: Reply with quote
get your PC hooked up to a laptop via the free PC software. itll back up the map you currently have stored so worst case you can put it back to where it is now. i doubt someone would have gone to the cost of a PC5 without another mod having been done. I've only had the PC3 on an old 929 and whilst plenty of different maps online for just a race can type mod (they are all 50mm straight thru baffles) I had to get full exhaust replacement maps loaded before things actually started to get faster rather than just nicer to ride!!
PostPosted: 20:04 - 05 Mar 2016    Post subject: Reply with quote
Bhp.
No,no,no it NEEDS to pop and bang on the overrun because it sounds cool. Razz
The last post was made 10 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 114.33 Kb
