stator problem
Ibradley
PostPosted: 20:05 - 01 Mar 2016    Post subject: stator problem Reply with quote
hiya folks, been having trouble with getting a spark on the bike, i replaced the plug, coils, cdi but nothing so decided to check the stator with a multimeter, am i right in thinking that to test it you put the black lead on one of the 3 wires and then check the other 2 for a reading with connecting the red meter wire, at the moment only one of the wires is giving a reading, is the stator brown bread or am i doing it wrong
thanks in advance for any help you guys can give
Vincent 2
PostPosted: 20:34 - 01 Mar 2016    Post subject: stator Reply with quote
check this out
www.youtube.com/watch?v=pk9Ni-rj4dg
RhynoCZ
PostPosted: 22:37 - 01 Mar 2016    Post subject: Reply with quote
Even with burned stator and reg/req you'd still get spark. I did 40 miles with no charging whatsoever. Thumbs Up
What motorcycle are we talking about?
Ibradley
PostPosted: 00:09 - 02 Mar 2016    Post subject: Reply with quote
its one of these cheap chinese bikes, a lifan earth dragon, i believe its engine is a copy of the old honda cg
Ibradley
PostPosted: 00:23 - 02 Mar 2016    Post subject: Re: stator Reply with quote
bilybob wrote:
ahh bugger, was doing it wrong, il try again in the morning
mauzo
PostPosted: 02:53 - 02 Mar 2016    Post subject: Reply with quote
That depends on the bike. The older CGs ran the spark directly off the generator; the battery just did the lights (and starter, if any). The spark ran off one coil on the generator, and the other two went into the reg/rec, so if one of the coils was dead, you could easily get charging but no spark.
I've no idea what the Chinese copies do; try tracing the wiring. Normal CG wiring either has three yellow wires going from generator to reg/rec (the newer ones) or a yellow to r/r plus lights, a white to r/r only, and a black/red or black/white to the ignition unit.
'04 CG125, '07 CBF500
Ibradley
PostPosted: 06:05 - 05 Mar 2016    Post subject: Reply with quote
cheers fellas, thanks for youre help, its very much apretiated, all sorted now
The last post was made 10 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 51.31 Kb
