non speedo
blahheed
PostPosted: 15:33 - 05 Mar 2016    Post subject: non speedo Reply with quote
cbf500 04 reg,
non abs,
speedo is not working,
where should the sensor be?
Big
Vincent 2
PostPosted: 16:23 - 05 Mar 2016    Post subject: Reply with quote
Got this it might be of some help, red ,green and black wires, i think
blahheed
PostPosted: 16:38 - 05 Mar 2016    Post subject: Reply with quote
found it thanks,
seems sensor is going into gearbox behind front sprocket,
just got to find a way of testing the sensor and clocks
Big
Vincent 2
PostPosted: 17:02 - 05 Mar 2016    Post subject: Reply with quote
Have a look at the PCB board connected to the clocks sometimes they get a bit rusty
blahheed
PostPosted: 17:50 - 05 Mar 2016    Post subject: Reply with quote
all looks ok,
wiggled wires and still no speed,
everything else works on clocks
Big
Vincent 2
PostPosted: 18:11 - 05 Mar 2016    Post subject: Reply with quote
take a look at this for a 3 wire test
www.youtube.com/watch?v=G1XzwZE6n8M
blahheed
PostPosted: 12:33 - 08 Mar 2016    Post subject: Reply with quote
its a different type unit to that video,
sensor is in a sealed unit into the engine
Big
Vincent 2
PostPosted: 14:02 - 08 Mar 2016    Post subject: Reply with quote
Hi matey , yes you can still do the test like the video with the sensor still in the engine , just unplug the connector , and test in the sensor connector end you should get some resistance , also as you see in the video with the open ended sensor in the engine , you can get over this by lifting the back end off the ground and moving the wheel slightly as opposed to spinning the sensor end
blahheed
PostPosted: 07:23 - 09 Mar 2016    Post subject: Reply with quote
tried that and nothing
Big
Vincent 2
PostPosted: 07:26 - 09 Mar 2016    Post subject: Reply with quote
Hi , there is nothing at all on the multi meter, or is the sensor useless. Try this test its a more elaborate test but at least it gives readings to and from the sensor, although its a different bike same method applies.
www.youtube.com/watch?v=H7d9fukFccY
Worth another test before you splash out on another sensor
The last post was made 9 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 60.05 Kb
