Cooling system shorting electrics
rk8479
PostPosted: 07:35 - 07 Mar 2016    Post subject: Cooling system shorting electrics Reply with quote
Bike failed on me last week when turning ignition on electrics won't come on at all, initially thought it was the fan so I replaced the fan still the same problem then I checked for continuity in the loom which pointed to the loom not having continuity between fan wire and fan fuse box so I replaced the entire wiring loom yesterday and when I went to turn it on nothing happened but waiting 20-30 seconds the instrument cluster comes on however the ignition light is dim and when using the indicators instead of the indicators coming on the instrument cluster just all flashes on and off.
Used a wire in the fan fuse box straight to battery positive and all the electrics work perfectly so I'm not sure what could be going wrong?
Any help would be appreciated thanks
rk8479
PostPosted: 07:52 - 07 Mar 2016    Post subject: Reply with quote
Bike is a varadero 125 2001
PostPosted: 10:35 - 07 Mar 2016    Post subject: Reply with quote
Sounds like the battery is low, if it isn't you'll need to go through all the connectors.
The last post was made 9 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 35.49 Kb
