Poor start
Smythy
PostPosted: 17:17 - 07 Mar 2016    Post subject: Poor start Reply with quote
Hi folks
Need help for my 2010 busa
7500 miles on clock
After taking it out for a spin,When I go to start up,It sounds like I've a flat battery even when battery showing 12.60 volts
If I get a jump start,It fires up straight away
The battery has only covered 1000 miles so think I can rule that out
Any ideas please?
Many thanks folks.
oscar777
PostPosted: 17:37 - 07 Mar 2016    Post subject: Reply with quote
Is the starter motor turning it over? Or is it just clicking when you try to start?
Push bike with a 80cc jerry rigged 2 stroke---> CBR125R ---> GSXR600 ---> Ducati 1098SF
wristjob
PostPosted: 17:58 - 07 Mar 2016    Post subject: Reply with quote
is the battery a 1000 mile old this month
or was it a 1000 mile old when it was put away last year?
how often is it ridden?
you say it wont start after a ride,did it start ok from cold?
does it live in a garage on a charger?
has it got an alarm that could be draining it?
if it sounds like you have a flat battery then usually it is a flat battery.
the important bit is why is it flat.
Nemo
PostPosted: 21:06 - 07 Mar 2016    Post subject: Reply with quote
What does the voltage drop to when you press the start button?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
PostPosted: 21:24 - 07 Mar 2016    Post subject: Reply with quote
Volts and available cranking amps aren't necessarily the same thing.
As above, looks like the bike does just over 1,000 miles a year. You could land up needing a new battery every year at that rate depending on how it's stored.
Check the terminals on the battery and solenoid are tight and free from corrosion.
The last post was made 9 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 46.75 Kb
