push bike speedo.......
billy_27
PostPosted: 07:18 - 09 Mar 2016    Post subject: push bike speedo....... Reply with quote
as anyone ever fitted a push bike speedo on there motorbikes. im just wanting one that will read ok up to 30mph 40mph and possibly 50mph anything above them speeds il guess and take my chance SmileI once bought a vapor clock for my fireblade and had nothing but problems so cant c the point in spending so much again. advice much appreciated
bamt
PostPosted: 08:19 - 09 Mar 2016    Post subject: Reply with quote
Not fitted one, but any of the big brands should be OK to those speeds as long as you can mount the magnet close enough to the sensor (yes, I've done 50mph on a push bike fairly regularly). Wireless may be problematic in the electrically noisy environment of a bike, and constant illumination at night is an uncommon feature if that matters to you.
Parson
PostPosted: 18:45 - 09 Mar 2016    Post subject: Reply with quote
Why would you want to? What's up with the bike speedo? If in doubt, wouldn't it be easier and more accurate to use a GPS?
Then gsx650F - Now VFR800F
PostPosted: 18:59 - 09 Mar 2016    Post subject: Re: push bike speedo....... Reply with quote
First off; get a wired one.
My Cat's eye one was fine up to triple digits (at Snetterton, of course!) on my zx9.
The cheap Tesco one started to go to a half and a third speed as the pace upped on my CCM404e - If you were moving at a reasonable pace and it said 25mph, you knew you had to double it, so it wasn't TOO bad.
And yes- you could consider sticking a phone on there and using the dash. Did that on the CCM for a while (well, was a proper bike GPS, but that was some time ago.)
PostPosted: 20:59 - 09 Mar 2016    Post subject: Reply with quote
Vincent wrote:
I'm not sure about this, but if you want one for an full MOT, it may need a backlight Thinking
Doesn't have to be 'back' - can also be illuminated from above etc.
AdamEf
PostPosted: 22:12 - 09 Mar 2016    Post subject: Reply with quote
I used Cateye Velo ones on push bikes a few years ago and they always lost it above 29mph and went to zero. Something to do with the strength of the magnet / sensor.
Have used my garmin GPS and found it more accurate than the inbuilt speedo on my YBR125 and SV650.
mauzo
PostPosted: 23:18 - 09 Mar 2016    Post subject: Reply with quote
A motorbike doesn't need a speedometer at all for an MOT. (The MOT manual makes no mention of one.)
'04 CG125, '07 CBF500
thx1138
PostPosted: 23:24 - 09 Mar 2016    Post subject: Reply with quote
serious?
* does a happy dance around the living room *
I think I might have just about bodged my dirt bike enough to pass then, the speedo stopped appearing on my dash board sometime back
thx1138
PostPosted: 23:25 - 09 Mar 2016    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=144612
like this? Laughing
billy_27
PostPosted: 23:44 - 09 Mar 2016    Post subject: Reply with quote
cheers for the advice Very Happy
billy_27
PostPosted: 23:48 - 09 Mar 2016    Post subject: Reply with quote
. im doing a gs 1000 cafe racer so not using original clocks plus ive got zephyr 750 front/back end fitted
The last post was made 10 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 74.58 Kb
