Fairing Repair
Davo
Davo To The Rescue!
PostPosted: 22:47 - 15 Feb 2005    Post subject: Fairing Repair Reply with quote
Hey
Can anybody recommend a place where I can get my hayabusa's fairing repaired? Just a couple of light scratchs that I want to get rid of.
Diehard
PostPosted: 23:21 - 15 Feb 2005    Post subject: Reply with quote
Yeah I'll fix it for ya... (I'm building a busa and need parts Wink ). Honestly I'd do it yourself mate. Get a good project pack of sandpaper / wet 'n' dry from halfords and get cracking. I'll have a guess it's the right hand panel that is damaged? Usually it is. Also colour match isn't a big problem, take the panel to them (halfords) and they'll give you a tin the same. Just make sure you lacure it well and polish it back after-wards.
Hope that helps,
Diehard
If I Die... I Die!
nick.h
PostPosted: 23:31 - 15 Feb 2005    Post subject: Reply with quote
On a similar subject, is there anything i can use to strengthen my fairing. After my recent incident, repairing the fairing with glue wasnt sufficient enough, and it cracked again while riding. This may be because my knee touches it while riding.
Cheers Nick
sorry for hijacking the thread
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
Jrod
Page 3 Girl
PostPosted: 23:54 - 15 Feb 2005    Post subject: Reply with quote
Plastic welding, use cable ties as welding rod's
(do a serach on here to get better instructions)
Claud 14.7 to 1
PostPosted: 23:58 - 15 Feb 2005    Post subject: Reply with quote
I've found clear Araldite to be good/the best for fixing cracks. The only time the cracks ever come apart is when the bike goes down again. Sturdy stuff. Superglue is no good compared: just flakes off and the crack will open up again soon if bothered.
Scratches: light sanding to get a smooth surface, prepare and spray/touch up.
Johnny GSX-R
PostPosted: 00:13 - 16 Feb 2005    Post subject: Reply with quote
Cable ties aren't much cop,, try and find a bit of broken fairing from a crashed bike, in fact i could send you some in the post at a pinch as its ABS plastic. Some coat hangers are created from the same stuff but identifying them is another matter. You'll need to create a 'V' where the crack is and fill it with molten plastic by using a soldering iron or similar.
bonehead
PostPosted: 00:30 - 16 Feb 2005    Post subject: Reply with quote
You can buy "plastiweld" chemical from modelmaking shops, works fine on abs.
Scotsman37
PostPosted: 00:40 - 16 Feb 2005    Post subject: Reply with quote
The Ride magazine had a novel idea;
Get hold of a soldering iron
With the broken fairing removed
Line the two pieces together and glue the two broken edges together again and spot weld it together with superglue on the back of it.
Using the soldering iron run along the break and melt the two pieces back together but watch out you don't melt the paint on the other side. This will make it a stronger fix.
PostPosted: 14:16 - 16 Feb 2005    Post subject: Reply with quote
If you don't want to do it yourself - give PlasTech in reading a call. They repaired my fairing from some quite severe damage, and you wouldn't know the difference. They charged £200 to respray a whole panel, including repairing three seperate lage cracks, and a hole - also they cut holes in both fairing panels and fitted my crash mushrooms for me - which is why it sounds expensive.
Their number is usually in the back of performance bikes, but I can dig it out if you need me to. Smile
tintin
PostPosted: 14:39 - 16 Feb 2005    Post subject: Reply with quote
Not sure where you are, but these guys in Surrey were recommended to me:
https://www.finishlinemc.co.uk/index.htm
The older I get the better I was
The last post was made 21 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 64.48 Kb
