| Ross1992 |
 Ross1992 Derestricted Danger
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 19:11 - 08 Mar 2016 Post subject: |
How did it run before or did it ever run alright after the mods? This could be anything from water in the fuel, faulty valve, runing too rich (now the plug is fecked) and so on, even the leaky exhaust.
By the way, use a proper exhaust sealant, not the red stuff you rub on your engine covers instead of a proper paper seal.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Kickstart |
 Kickstart The Oracle
 Posted: 19:41 - 08 Mar 2016 Post subject: |
Rotax / Aprilia list to use high temp silicone sealant to seal the exhaust to the barrel stub.
As to how the bike runs, is there any pattern to it? Does it play up at certain rpm? At a certain temp? After a certain time running? Is it better or worse at certain temps?
The cdi mod (assuming this is a mid shape RS - from ~1998 to ~2005) only affects from 4750rpm to 6000rpm. It does nothing outside this rev range. It works by breaking a bridge on the circuit board to trigger the unit to use a different ignition timing map. But it is possible to damage the cdi when doing the mod with odd effects. However most of the time I would expect it to either work or not work.
Can be lots of odd problems. A problem at certain throttle openings / rev range combinations would suggest a problem with a jet; possibly just the wrong size. If the bike cuts out after running for a while (maybe a bit longer if taking it easy, quicker if thrashed) then it suggests an issue getting sufficient fuel to the carb (possibly a blocked fuel filter, blocked fuel tank breather, etc)
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Pjay |
 Pjay World Chat Champion
| saikouslx |
 saikouslx Renault 5 Driver
| Ross1992 |
| stevo as b4 |
| Ross1992 |
| RhynoCZ |
| Ross1992 |
| Pjay |
| stevo as b4 |
| iooi |
 iooi Super Spammer
| Ross1992 |
The last post was made 9 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
