Calliper maintainence advice please.
trickysax
PostPosted: 22:53 - 12 Mar 2016    Post subject: Calliper maintainence advice please. Reply with quote
I've just got my bike back from the local garage following an MoT and some quite major work needed on my front brakes. I ride day-in-day-out back and forward to work all year round. As a result, my bike gets all the usual dirt and salt over the winter.
What's the best thing to use to keep my brakes clean? The calipers needed new seals and were really filthy. How can I reduce any damage to them in future?
Cheers.
C̶u̶r̶r̶e̶n̶t̶ ̶b̶i̶k̶e̶ ̶-̶ ̶B̶a̶n̶d̶i̶t̶ ̶6̶5̶0̶s̶ ̶ Sad
Its not about the destination, its the journey that counts.
kerr
PostPosted: 22:55 - 12 Mar 2016    Post subject: Reply with quote
This is generally what i do.
https://www.youtube.com/watch?v=FNz00OTRLzM
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
trickysax
PostPosted: 23:08 - 12 Mar 2016    Post subject: Reply with quote
Nice one Kerr! Much appreciated! Karma
PostPosted: 23:12 - 12 Mar 2016    Post subject: Reply with quote
If yours is the older 2 pot sliding calipers then they seize up easily, but they are also pretty easy to strip down and clean up.
The pistons can stick, but the more common issue is the caliper sticking on the pins it slides on.
Keep them clean (tooth brush and a can of brake cleaner), but get used to stripping them and lubing the pins
Katy
trickysax
PostPosted: 23:26 - 12 Mar 2016    Post subject: Reply with quote
Thanks Katy, I'll make it part of my maintenance routine. Thumbs Up Karma
talkToTheHat
PostPosted: 13:10 - 15 Mar 2016    Post subject: Reply with quote
I was going to share the same video. Is on the occaisonal maintenance schedule, i recall delboy suggesting twice a year.
My thereabouts weekly schedule is to give the calipers a gentle blast with a hand-pumped garden spray thing. It's not the high pressure of a jetwash, and doesn't appear to remove copper grease from where it should be. Does remove salt, grit and a bit of brake dust.
Bandit. does. everything.
The last post was made 10 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 49.63 Kb
