| bcroninuk |
 bcroninuk L Plate Warrior
| Itchy |
 Itchy Super Spammer
 Posted: 21:37 - 12 Mar 2016 Post subject: |
Tyres it depends as UV light makes them perish and crack. I left my old CBR in storage for years and the tyres were ok as it was kept in the dark.
Oil change is a must as the additives separate from the oil, water may have got into it causing mayonnaise engine.
Fuel tank? Fuel will be burn but it'll run like a bag of nails. Also the carbs/FI will have gummed up as the petrol in them will have evaporated leaving behind a layer which will block them.
Brake fluid may have absorbed water.
Also to think about is:
Wheel bearings.
Coolant as this too separate so you have blue/green gunk at the bottom of the water expansion bottle and just plain old water inside the system. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| bcroninuk |
| Itchy |
 Itchy Super Spammer
| Rogerborg |
 Rogerborg nimbA
| andym |
 andym World Chat Champion
| P.addy |
 P.addy Red Rocket
| Robby |
 Robby Dirty Old Man
| Islander |
 Islander World Chat Champion
 Posted: 14:35 - 13 Mar 2016 Post subject: |
Yep, as above I'd cast an eye over the usual stuff, stick a fresh battery on if needed or charge the old one, put some fresh fuel in and start it up. Check tyre pressures, lube and adjust chain if needed and then hop on and ride it. Don't forget to allow for the brakes bedding in and scrubbing rust off of disk surfaces. Maybe an oil and filter change on return while it's still nice and warm.
Any real problems will soon surface and can be dealt with as necessary but I'll bet there aren't many.  |
| waffles |
 waffles World Chat Champion
| talkToTheHat |
 talkToTheHat World Chat Champion
The last post was made 10 years, 214 days ago. Instead of replying here, would creating a new thread be more useful? |
