Leaking forks 6 months after seals replaced
Andy9934
PostPosted: 16:42 - 13 Mar 2016    Post subject: Leaking forks 6 months after seals replaced Reply with quote
I got my Honda Varadero 125 last August and sent it in for a full service. There was a bit of oil on the front mudguard, rusty chain etc so requested it be given the works so it'd be good for me to nip about on.
It's done about 1000 miles since then (600 miles since 1st Oct) and been in the garage when not in use but the fork has started leaking pretty badly again (see photos), and I think this is only since a journey through london.
(This involved around a million speed bumps, that might be relevant?)
The MOT is due next month, and I'm guessing the seals need replacing again, but I am pretty sure they are supposed to last more than 6 months! Can anyone hazard a guess about what might have caused this fast failure and the cost/method to prevent it reoccurring?
Surrey
Honda Varadero XL125
PostPosted: 16:56 - 13 Mar 2016    Post subject: Reply with quote
Why were they leaking in the first place?
Stanchions are pitted, bushes are worn and/or they never actually replaced the seals, just packed some grease in.
Islander
PostPosted: 17:12 - 13 Mar 2016    Post subject: Reply with quote
Did they check/replace the bushes? If they're worn then the sliders won't run true to the stanchions.
Could also be cheap pattern seals - they've been known to fail fairly quickly.
PostPosted: 17:28 - 13 Mar 2016    Post subject: Reply with quote
Pattern seals likely.
CaNsA
PostPosted: 17:38 - 13 Mar 2016    Post subject: Reply with quote
Leaking fork seals...
Posts pics of front mud guard...
Brick Wall
PostPosted: 17:57 - 13 Mar 2016    Post subject: Reply with quote
But, but, that's where the oil's gone.
Andy9934
PostPosted: 17:59 - 13 Mar 2016    Post subject: Reply with quote
The reason I didn't think to post the forks is that I can't see anything untoward on them anywhere. I've attached pics to this post. The right fork is the offending one. For comparison, the left is not leaking. No signs of rust or pitting, just some grease at the top of the travel.
I am pretty sure if he said he replaced the seals then he did, just an independent mechanic and seems as trustworthy as one can tell without a knowledge of mechanics.
The service receipt just says seals and oil so I'm guessing they didn't do the bushes.
Surrey
CaNsA
PostPosted: 18:05 - 13 Mar 2016    Post subject: Reply with quote
They both look a bit buggered IMO.
Drop the forks, replace the seals and bushes yourself with OEM parts.
PostPosted: 18:12 - 13 Mar 2016    Post subject: Reply with quote
Wouldn't be holding off too long. Grab some genuine seals and bushes. Don't get tempted with pattern. They are terrible.
Andy9934
PostPosted: 19:25 - 14 Mar 2016    Post subject: Reply with quote
What makes you say they both look buggered? To me they both look nice, straight and undamaged?
Definitely not something I have the time, tools or expertise for, unfortunately.
Surrey
CaNsA
PostPosted: 19:34 - 14 Mar 2016    Post subject: Reply with quote
Andy, let's not make this simple problem into a fucking drama.
1. always replace for seals in pairs.
2. i can see fluid, that i assume is fork oil, on both forks.
3. buy OEM parts and ask a mechanic to fit them.
Andy9934
PostPosted: 23:39 - 14 Mar 2016    Post subject: Reply with quote
I... wasn't trying to? Just trying to hopefully learn a bit more about how to spot damage on future bikes as I can't see anything but the problem has been there since I bought it.
The pair were replaced last time.
Surrey
PostPosted: 10:16 - 15 Mar 2016    Post subject: Reply with quote
Were they though?
Just out of interest, if you pop the dust seals off, are they packed out with grease between the dust and oil seals?
Robby
Dirty Old Man
PostPosted: 21:59 - 15 Mar 2016    Post subject: Reply with quote
Pattern seals. I've never had a set of them last a year. I stopped using them altogether 10 years ago.
If you want to do the job fairly cheaply in a way that will probably work, fit new genuine seals. If you want to do it really well, also replace the bushes.
Commuter_Tim
PostPosted: 22:09 - 15 Mar 2016    Post subject: Reply with quote
...and then get gaiters.
I sewed my own from spare neoprene.
They look like shit but even my already pitted stanchion has failed to rust or gather dirt under them. (I did ACF under there too)
Typical Scouse, always looking for a fite.
What's the matter, you not got a fork leg you can fite me wi... oh shit. Pale
I ride a Bandit 600... badly.
Islander
PostPosted: 22:23 - 15 Mar 2016    Post subject: Reply with quote
He'll just rob yours Razz
orac
PostPosted: 22:47 - 15 Mar 2016    Post subject: Reply with quote
the pattern seals in the 400 have gone 4 years and more than 30,000km. cant remember the brand off hand, forks a little pitted too. Fitted myself worked them in gently with a round ended allen key, used original bush too.
quality after market is fine, I will try and get a name in the next day or so. its very much a case of don't skimp and you wont pay twice.
Andy9934
PostPosted: 18:48 - 19 Mar 2016    Post subject: Reply with quote
Nope, they look pretty clean under the dust seals, just some clear (and pretty fresh looking) leaked oil.
See attachments for pics that hopefully show what I mean.
Surrey
The last post was made 10 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 101 Kb
