Throttle control
spottedtango
PostPosted: 13:35 - 14 Mar 2016    Post subject: Throttle control Reply with quote
I've noticed when you roll on the throttle gradually and quickly , the bike seems to accelerate much better/quicker than opening the throttle without thinking much about it and waiting for the engine to catch up.
I know by rolling the throttle the suspension has time to adapt to the thrust being produced by the engine and allow the bike to provide more grip but is it actually faster does it just feel that way? Is there any benefits like better fuel consumption ect?
B5234FT
PostPosted: 13:59 - 14 Mar 2016    Post subject: Re: Throttle control Reply with quote
Ona carb fed bike I'd imagine opening it up gently allows for much better fuelling through the range than simply whacking it upen at which point the airspeed in the throat drops. The same is true of injection, but less so as the fuelling isn't directly related to airpseed.
PostPosted: 15:29 - 14 Mar 2016    Post subject: Reply with quote
Matches my understanding. At low RPM and large openings you'll get lower velocity airflow though the throttle body. In a carb the fuel takes a moment to catch up, thus the addition of an accelerator pump to actively dump fuel into the air. An injection engine with a throttle position sensor can also spooge more fuel in, but neither system is going to keep it bang on if you're rapidly changing the throttle position.
Blip a throttle from idle on a carb without an accelerator pump (hello Amal Concentric) and you can stall out your engine as it takes a big gulp of nothing.
If anyone's got a more scientological explanation, I'm sitting comfortably.
TheArchitect
PostPosted: 16:11 - 14 Mar 2016    Post subject: Reply with quote
I agree, rolling on the throttle does make my bike feel like it's accelerating quicker than WOT.
Either that or it's a false impression. A very non-scientific explanation below..
So when you go WOT, you consciously do it and hence you brace yourself harder to counter the pull of the acceleration. But when you roll on the throttle gradually, you're not expecting that much acceleration because you don't think it's there, therefore you end up feeling more pull on your body from the acceleration because you haven't braced yourself as much. So the increased acceleration you feel could just be a result of you not being ready for it.
Does I making senses?
GSXR 600 K6 - Stolen
MT09 - Almost stolen
Silver_Fox
PostPosted: 16:46 - 14 Mar 2016    Post subject: Reply with quote
It makes sense but I don't think it's correct Smile
CBR600 F3 FV
CG125
Ariel Badger
PostPosted: 20:24 - 14 Mar 2016    Post subject: Reply with quote
My throttle is fully open within a half a second of leaving the line, I am getting 60ft times of 2.6 seconds so something is working well.
Albigularis
PostPosted: 20:42 - 14 Mar 2016    Post subject: Reply with quote
The easiest way to check the theory is get the bike in 5th gear, 30mph, pull the throttle open and see how strong it gets whilst winding it further back. I know the Multistrada gets stronger the further you pull it back, and all racers you watch, dyno operators etc all get the throttle as far back as they can...
Bicycle forum is this way.
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
techathy
PostPosted: 21:36 - 14 Mar 2016    Post subject: Reply with quote
If you snap the throttle open the engine will be a little behind what you're expecting - instant full power. This will make you think you're not accelerating as quickly. If you feed the throttle in you'll be expecting a liner response but what you'll actually get is maybe 60-70% maximum acceleration from 50% throttle, so the engine will be a bit ahead of your expectations. This will colour your perception and make you think you're accelerating faster.
Ariel Badger
PostPosted: 22:30 - 14 Mar 2016    Post subject: Reply with quote
Ignoring what the Muppet said.... I should have a 3 plain acceleration data logger in the next couple of weeks and will take some readings at different throttle settings.
sickpup
Old Timer
PostPosted: 22:55 - 14 Mar 2016    Post subject: Reply with quote
All depends on the carbs, way too many variables to make a generalisation.
Flat slides may bog whereas CV's wont as they need matching to the engine speed.
Fit a set of 36mm CV's to a GSXR1100M and snapping the throttle open it will accelerate VERY quickly, refit the original 40MM CV's and do the same it will accelerate slower, all down to air speed through the carbs.
Kaya75
PostPosted: 23:36 - 14 Mar 2016    Post subject: Reply with quote
Too many holes in original question..
Is the op talking stationary, tick over, 2 k rpm to redline or 6 k to red? In which gear?
If I'm at 2k in 5th, I can go WOT, and I'll exponentially increase acceleration to peak but it'll be easy going until I get past 6k, but if I'm sitting at 6k in 2nd Awaiting a overtake opportunity and a go WOT I'll get more G then if i control the roll.. But then I'm on a bandit 600, could you actually go WOT in second gear sitting just below the powerband range on a R1 and keep the wheel down? I really don't know..
But stands to reason if I set off WOT in third gear, acceleration is gonna be slower then if I roll on quick like while in 1st gear - or am I talking bollox? Again I'm not too sure Shocked
ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2.
Wonko The Sane
PostPosted: 23:37 - 14 Mar 2016    Post subject: Reply with quote
I know when I had restrictors in my ZZR it could be a bit asthmatic if I opened the throttle too quickly compared with now
PostPosted: 00:34 - 15 Mar 2016    Post subject: Reply with quote
Oh, c'mon; give him some slack - he's actually just beating the fastest runners in the world!
Razz
(2.87 or there about, apparently.)
spottedtango
PostPosted: 01:01 - 15 Mar 2016    Post subject: Reply with quote
See I didn't realise that the type of carburators was important hence why my original answer was quite vague. I had the general idea that all carburators acted similarly when the throttle was opened even though some of them are constructed differently.
talkToTheHat
PostPosted: 06:40 - 15 Mar 2016    Post subject: Reply with quote
98 R1, Mikuni downdraft CV carbs IIRC, front comes up in third. This is what happens when getting off an XV535 (also with mikuni downdraft carbs) and taking an r1 for a spin.
600cc bandits have Kekhin CV carbs. CVK32 I think. Broadly similar in operation to the mikunis but crossdraft.
CV carbs have a throttle butterfly you control and a slide (that acts as a secondary throttle) attatched to a diaphram that lifts as vacuum increases. At idle and steady state closed throttle the slide is all the way down. Whacking the throttle open here will cause the mixture to run lean until the slide starts lifting. At 4000rpm the slide is floating and fast throttle openings should be moderated by the slide action. Carb tuning kits often contain a drill bit for enlarging an air hole to improve silde response time.
Other carbs have the throttle directly connected to the slide and no additional butterfly. Unless an accelerator pump is also fitted, throttle roll ons must be very smooth to avoid leaning out the mixture.
With EFI the ideal mixture is calculated for the throttle position so hoon away. Ride by wire throttle contols put a computer in charge of your throttle opening and the amount of twist is just a torque demad imput. Least upset by going to WOT like an on/off switch.
With cold engines and at very low rpm, expect better response from gentle throttle inputs. However a cv carb that feels like this all the time could have a sticking slide or it's indicative of a mixture problem.
Bandit. does. everything.
PostPosted: 10:40 - 15 Mar 2016    Post subject: Reply with quote
Aren't you burning some form of triple-distilled unicorn blood though?
Carbs, much voodoo in there. I have a throttle slide with a smaller cutaway to try in my Amal at some point to try and ameliorate the slight tendency to bog when, uh, "nailing" it.
Silver_Fox
PostPosted: 11:45 - 15 Mar 2016    Post subject: Reply with quote
I have a slight lag when I pin the CBR. I just assumed the carbs were gummed up a tad
CBR600 F3 FV
CG125
techathy
PostPosted: 19:23 - 15 Mar 2016    Post subject: Reply with quote
I hope you're talking about Albigularis Evil or Very Mad
Ariel Badger
PostPosted: 21:42 - 15 Mar 2016    Post subject: Reply with quote
[quote="techathy"]
I was and I would like him to give his 60 foot times to compare.
Kaya75
PostPosted: 21:45 - 15 Mar 2016    Post subject: Reply with quote
CV carbs have a throttle butterfly you control and a slide (that acts as a secondary throttle) attatched to a diaphram that lifts as vacuum increases. At idle and steady state closed throttle the slide is all the way down. Whacking the throttle open here will cause the mixture to run lean until the slide starts lifting. At 4000rpm the slide is floating and fast throttle openings should be moderated by the slide action. Carb tuning kits often contain a drill bit for enlarging an air hole to improve silde response time..
cool, id never paid much thought to the carb set up tbh I haven't got that deep with the old bandit yet. I'm running a pair of FRD36 Dell's in the bus, but I just pulled the chokes out and rejetted them for the engine..
Interesting intro to carb voodoo, nice one:up:
Watch me light up the workshop forum with "my carbs won't fit bk together / bits left over from carb rebuild. Bandit 600..." Sometime around Easter! Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 22:45 - 15 Mar 2016    Post subject: Reply with quote
What, the time it takes putting on the 60 shoes?
Triumph Sprint ST 1050
The last post was made 10 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.35 - MySQL Queries: 13 - Page Size: 115.42 Kb
