Endless Electrical Problems On Speedfight 2 :/
bmunro21
PostPosted: 15:36 - 16 Mar 2016    Post subject: Endless Electrical Problems On Speedfight 2 :/ Reply with quote
Hello guys, ive been helping my son fix up a moped he bought off of one of his friends and all is good apart from lights. The headlights and brake lights do work however they are very very dim. The bulb brightness increases if the bike is revved but as soon as it is left to idle the light is virtually non-existent. I don't think that its a problem with the battery as it has been sitting in the garden since sunday now as has only been started a couple of times and it still starts first time with electric start.
Help would be appreciated Thumbs Up Thumbs Up
mudcow007
PostPosted: 16:13 - 16 Mar 2016    Post subject: Reply with quote
What voltages are you getting at the battery with the bike off an voltage with the bike running?
bmunro21
PostPosted: 16:19 - 16 Mar 2016    Post subject: Reply with quote
Im not sure because I don't have access to a multimeter :/
Islander
PostPosted: 16:40 - 16 Mar 2016    Post subject: Reply with quote
You can pick one up for about a tenner from Maplins if there's one by you. Thumbs Up
PostPosted: 16:44 - 16 Mar 2016    Post subject: Reply with quote
Yes, get a multimeter. You dont need anything fancy, just volts and ohms. Will save you (and us) a lot of time fault finding.
PostPosted: 16:50 - 16 Mar 2016    Post subject: Reply with quote
Under £5 from eBay or Amazon.
Or you can start randomly replacing parts that will cost you a lot, lot more.
How's the electrolyte level in the battery cells? Free to check, pennies to sort with distilled water.
bmunro21
PostPosted: 17:03 - 16 Mar 2016    Post subject: Reply with quote
Okay i've just borrowed a multimeter from a friend and measured the voltages. With the bike off im getting 12.52v and with the bike running im getting 14.15v
PostPosted: 17:17 - 16 Mar 2016    Post subject: Reply with quote
That sounds tickety boo! What's the voltage when you put your lights on.
mudcow007
PostPosted: 17:23 - 16 Mar 2016    Post subject: Reply with quote
it shows the battery is alive an also shows its charging too
next step see what voltages you are getting at the headlight
bmunro21
PostPosted: 17:27 - 16 Mar 2016    Post subject: Reply with quote
With the bike running and lights on im getting around 13.5, although it did just notice when i started the bike up this time the idle voltage was around 12.8/13v. Think i was revving the bike when i was getting 14v
bmunro21
PostPosted: 17:48 - 16 Mar 2016    Post subject: Reply with quote
Unfortunately ive gone out now so ill have to check headlight voltage tomorrow
PostPosted: 21:21 - 16 Mar 2016    Post subject: Reply with quote
TBH for a small bike that all looks OK.
bmunro21
PostPosted: 21:44 - 16 Mar 2016    Post subject: Reply with quote
I have been doing alot of reading and from what I can find the problem could be the regulator/rectifier. But then ive read conflicting information that suggests the headlights are not connected to the battery and are instead connected to the alternator. I have found a video on youtube of the problem that I am having aswell if that helps?
https://www.youtube.com/watch?v=wSfINuYX0vM
bmunro21
PostPosted: 19:04 - 17 Mar 2016    Post subject: Reply with quote
Okay so i've done a bit more reading and found out that the headlight and brake lights are most probably run off of the stator/alternator. So does this mean I need a new one?
PostPosted: 19:20 - 17 Mar 2016    Post subject: Reply with quote
I wouldn't have thought so, as it is charging the battery.
bmunro21
PostPosted: 19:56 - 17 Mar 2016    Post subject: Reply with quote
So what do you guys reckon the problem could be?
Im very eager to sort this as my son has spent so much sorting out his CBT, Insurance etc and this is the only thing that stopping him from being on the road now Very Happy
bmunro21
PostPosted: 21:32 - 18 Mar 2016    Post subject: Reply with quote
bump?
lukamon
PostPosted: 00:48 - 19 Mar 2016    Post subject: Reply with quote
bad earth maybe? trace the negative battery leads to where it screws to the frame, unbolt, emery cloth the contact patch, reattatch? do the same at the headlight earth point Thumbs Up
killa wrote: Im an ass man myself
PostPosted: 20:36 - 19 Mar 2016    Post subject: Reply with quote
Anyone got a wiring diagram for this because if the battery is charging OK I can't see a reason to have the lights running direct off the alternator which is what it sounds like it is doing.
bmunro21
PostPosted: 20:53 - 20 Mar 2016    Post subject: Reply with quote
That would be a great help
The last post was made 10 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 100.37 Kb
