House buying woes - Structural weakness
LustyLew
PostPosted: 16:49 - 18 Mar 2016    Post subject: House buying woes - Structural weakness Reply with quote
Hey all,
So I found a property, nice area, decent train/bus links etc
Internally the property is in good condition, externally it looked OK. The Mortgage Valuation came back clean so I thought I was good, but to be safe, I arranged for a Homebuyers survey to be carried out.
Oh how foolish I was!
Significant cracking, bulging and distortion of external brickwork was noted that are indicative of wall tie deterioration. You are therefore advised to commission a specialist wall tie report, including the rebuilding of the gable wall as necessary.
Areas of defective pointing are in evidence to external walls that are due to the effects of long term weathering and thermal expansion and contraction. We would anticipate the wholesale repointing of affected areas which should be raked out to a depth of 25-30mm and joints and perpends repointed using a mortar in a colour and finish which matches the existing. Recessed or strapped mortar joints should not be used.
The property is freehold with a 50/50 split over maintenance of the structure. Ground floor covers lower half, top floor covers upper.
This work will affect both floors no doubt.
So what should I do?
Walk away and start again? Offer £10k lower than my initial offer and take the risk, or negotiate the work to be carried out by the current owner and the owner above (significantly delaying the process).
Now I fully understand why my parents have moved only once during their 45 years of marriage!
PostPosted: 17:03 - 18 Mar 2016    Post subject: Reply with quote
Walk away.
Then go back and shit in their slippers. Thumbs Up
UnknownStuntm...
PostPosted: 17:17 - 18 Mar 2016    Post subject: Re: House buying woes - Structural weakness Reply with quote
Er, that doesn't sound like the freehold I know of. Is it a flat?
You think the mortgage company would like that much? I reckon they're now an interested party to this information and might very well have it as a condition of sale that the work is carried out
That's the only safe bet to be fair.
You could also combine all the above, get a quote for the work and offer proportionally less. Depends how much you love the place and the area.
B5234FT
PostPosted: 17:17 - 18 Mar 2016    Post subject: Reply with quote
walk away. I've done a a fair amount with houses over the years, but trying to sort that with an adjoining neighbour involved and then get the render to match well enough that it doesnt just look shit isnt quick, nor cheap.
Unless there is a total absence of other suitable houses I wouldnt be for getting into it.
LustyLew
PostPosted: 17:55 - 18 Mar 2016    Post subject: Re: House buying woes - Structural weakness Reply with quote
It's a block of four mainsonettes. I only have the information I have been given.
Interestingly the Mortgage Valuation shows no mention of 'blown walls' or cracks of any kind and was entirely happy to lend based on its current condition.
This survey was commissioned by me after that valuation survey was completed and OK'd.
Think I'll get a structural survel carried out for a second opinion...
PostPosted: 18:01 - 18 Mar 2016    Post subject: Reply with quote
"Think I'll get a structural survel carried out for a second opinion..."
Why?
Either there is significant cracking, bulging and distortion of external brickwork or there isn't.
UnknownStuntm...
PostPosted: 18:12 - 18 Mar 2016    Post subject: Reply with quote
Mortgage valuations are known as 'drive bys' for a reason. If the lender finds out there are structural things you know about and haven't fixed, they might get mardy.
Show us a pic, please!
Also, how much are you currently out of pocket, if you don't mind me asking. And did you take out some form of 'fall through' insurance with the purchasing conveyancers?
PostPosted: 18:17 - 18 Mar 2016    Post subject: Reply with quote
Hopefully OP is using real solicitors rather than conveyancers. Thumbs Up
PostPosted: 18:46 - 18 Mar 2016    Post subject: Reply with quote
Look for something that doesn't resemble a flat. Something is yours. Only yours. Fuck sharing.
PostPosted: 19:02 - 18 Mar 2016    Post subject: Reply with quote
Motorcycle for sale. Unfinished project, non runner. New piston fitted. 95% complete only a little work needed for the MOT. Contact [email protected] for details.
That's what you're looking at.
PostPosted: 20:01 - 18 Mar 2016    Post subject: Re: House buying woes - Structural weakness Reply with quote
LustyLew wrote:
Walk away?
Only if you have some problem that stops you from running.
If you can find anything in the marketing that sounds like a statement about it being in sound condition, I'd also invoice whomever made that statement for the cost of your survey.
LustyLew
PostPosted: 22:35 - 18 Mar 2016    Post subject: Reply with quote
I don't have any pics of the issue in question unfortunately. I'm swinging by the property.
Oh, definitely using a solicitor!
Out of pocket about £800, certainly budgeted to lose this in case of problems.
Here's the listing .
Also fully understand the lender will want to know. I'm a first time buyer and trying to learn this as I go...
angryjonny
PostPosted: 23:09 - 18 Mar 2016    Post subject: Reply with quote
WTF? That corner above the front door looks like it hasn't downloaded properly. Is that actually the state of the wall?
LustyLew
PostPosted: 23:17 - 18 Mar 2016    Post subject: Reply with quote
Ivy. Poisoned at the root. Very much dead. Quite possibly the culprit for the damage I'd guess...
duhawkz
PostPosted: 23:43 - 18 Mar 2016    Post subject: Reply with quote
I doubt Ivy has caused significant structural issues.
and Laughing at london prices, I paid 140K for a 4 bed detached, with detached garage parking for 4 car etc.. up north
wodge
PostPosted: 23:48 - 18 Mar 2016    Post subject: Reply with quote
"Fieldbike" for sale, no keys or docs, Forks bent due to recent crash into back of Mercedes. [email protected]
https://www.bikechatforums.com/viewtopic.php?t=310537&postdays=0&postorder=asc&start=0
nolidge iz pouwur.
Yamaha RXS100 RS100
Chuffin Nora
PostPosted: 05:17 - 19 Mar 2016    Post subject: Reply with quote
But.
Priorities-your-right-get time . . .
What's the garage like?
https://il1.picdn.net/shutterstock/videos/10703789/thumb/10.jpg
There's a fine line between integrity
PostPosted: 08:40 - 19 Mar 2016    Post subject: Reply with quote
245000....In Dartford. Have you suffered a head injury.
I'm looking around that area but not a chance id look at sharing.
https://www.rightmove.co.uk/property-for-sale/find.html?locationIdentifier=REGION%5E1303&insId=1&minPrice=190000&maxPrice=260000&retirement=false&primaryDisplayPropertyType=houses&radius=3.0&googleAnalyticsChannel=buying
Choose anything but your one.
BTTD
PostPosted: 08:49 - 19 Mar 2016    Post subject: Reply with quote
Repointing a wall is easy but dull work that pretty much anyone can do.
As for the wall bulging and needing rebuilding, go and look at it yourself. There may be some small cracks where the building has settled, and if so a surveyor trots out standard arse covering blurb of wall ties bad build new house.
If the wall is actually bulging you will be able to see it clearly.
Look along the length of the wall from the corner. Is the wall flat, or is it clearly bowing out? Look at how the window frames sit, the gutter line etc. Are the spacings even and straight?
andyscooter
PostPosted: 09:36 - 19 Mar 2016    Post subject: Reply with quote
mates just sold his 4 bed house with a canal at the back with a boat mooring for £165,000
quarter of a million quid for a two bedroomed ground floor flat Shocked Shocked
angryjonny
PostPosted: 10:50 - 19 Mar 2016    Post subject: Reply with quote
We'll all retire north in a decade or two. Sell the southern hovel, buy a northern mansion, live off the change. See you soon.
dodsi
Dirty Carny
PostPosted: 14:44 - 19 Mar 2016    Post subject: Reply with quote
I'm from the north originally but live in the south having just bought a 2 bed flat. I got it valued at similar prices we are talking here once I have finished modernising it. The plan is to buy as big as possible down here and pay it off then move north mortgage free into the house I really want. It's not all bad paying silly money for property so long as you cash in at some point and change area.
PostPosted: 19:04 - 19 Mar 2016    Post subject: Reply with quote
A shared-responsibility building with structural issues? You'd have to be mad to think that 10k would cover it. Might cover the scaffolding costs.
Diggs
PostPosted: 19:32 - 19 Mar 2016    Post subject: Reply with quote
If the ties have gone and you pay to have new ones put in you will be left with a tell-tale series of drill holes through the centre of your bricks. When you come to sell, these will put off potential purchasers as they will worry that the remaining ties are knackered. Wall ties failing is a sign that the cavity has been compromised, and you don't want a compromised cavity!!!
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
swampy
PostPosted: 20:00 - 19 Mar 2016    Post subject: Reply with quote
OT: I thought that maisonettes were over two floors.. Usually as part of a bigger building or tower...
Thats a ground floor flat.
The last post was made 10 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 131.42 Kb
