| ScaredyCat |
 ScaredyCat World Chat Champion
 Posted: 12:36 - 19 Mar 2016 Post subject: Chain Adjustment |
Hot on the heels of my "You fukin' n00b" never adjusted a chain before thread, I went out and bought myself a Sealy torque wrench, 27mm socket and some spanners and have now attempted the chain tightening for the first time. Everything seems ok except for one thing that's niggling me.
The rear plate, pictured below, on one side is no longer tightly fitting against the rear of the swingarm:
https://dl.dropboxusercontent.com/u/188253/_bcf/saplate.png
It's by no means flapping about, it's just not snug and has a little movement. Is this normal? Have I done goofed?
I've used measurements from the rear of that plate to the end of the adjusting nut on both sides and the distance is the same. ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 12:45 - 19 Mar 2016 Post subject: |
Once you're done with setting the adjusters, knock the rear wheel forwards, until the chain is tight/lose enough and those plates are firmly on the swingarm. This is a typical Noob mistake, they fiddle with the adjusters and not with the wheel. Also, do both sides simultaneously and the axle will move as you tighten the axle nut.
| ScaredyCat wrote: | Is this normal? Have I done goofed? |
No, and yes. The adjuster is pulling on the plate, so it should hold there firmly enough.
EDIT: Just so you understand, you have to knock the wheel forward with any ''slide to adjust'' adjusters. In the picture below, if you didn't do that, you'd leave a gap (that's what you did) between the adjuster bolt and the sliding (blue) part. Your adjuster is not pushing into the swingarm, as it's hollow, so it pulls on the plate.
https://cdn-0.psndealer.com/e2/dealersite/images/tricountyhonda/chain%20adjustment%201.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| ScaredyCat |
| Fizzer Thou |
| mauzo |
 mauzo Nova Slayer
The last post was made 10 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
