Over heating? Help??
Fazzer1996
PostPosted: 00:23 - 21 Mar 2016    Post subject: Over heating? Help?? Reply with quote
Hi there I have a Derbi senda drd 125 and recently when I ride for more than 5 minutes my bike gets really hot comes up on the dash flashing as its gone over the tempture and really hot also I can see bubbles in the expansion tank , I have put coolant in my radiator filled to the top, I have water in the expansion tank does that need coolant too or would water be okay?
S.farrow
RhynoCZ
PostPosted: 00:29 - 21 Mar 2016    Post subject: Reply with quote
It could be:
a) Very lean mixture (not likely),
b) Stuck thermostat (I bet my money on the thermostat),
c) Faulty coolant pump,
d) Blown head gasket.
Fazzer1996
PostPosted: 00:32 - 21 Mar 2016    Post subject: Reply with quote
RhynoCZ wrote:
a) Lean mixture,
c) Faulty water pump,
hi i put premixed coolant in the rad, and I have normal water in the expansion tank could this course a problem? Also I have had a new water pump put on as it was leaking water and overheating and then it was fine for a day after fresh coolant,oil and then the next day it started again
S.farrow
RhynoCZ
PostPosted: 00:39 - 21 Mar 2016    Post subject: Reply with quote
Is the thermostat working? The cooling system would work with nearly any fluid that contains water, even urine, if you were in need. So if the coolant pump is working, then it must be the thermostat.
Even if there was air trapped in the cooling system, it would still work. Now, there are 2 cooling circuit, if the engine is cold, the thermostat is shut and you only use the close circuit, then when the engine gets hot, the thermostat opens and lets the coolant through the radiator. If it stays stuck shut, then it's like if there was no radiator and your engine will overheat.
EDIT: The thermostat would be under a lid, that say ''NEVER OPEN WHEN HOT'' or something like that. Thumbs Up
Fazzer1996
PostPosted: 00:42 - 21 Mar 2016    Post subject: Reply with quote
I'm not sure where the thermostat is I was planning on taking it to the garage just wondered if it would cost a lot if it was the thermo is it a hard job?
S.farrow
RhynoCZ
PostPosted: 00:45 - 21 Mar 2016    Post subject: Reply with quote
It's a simple job. Just swapping one part for another. It's also a cheap part (it should be around £15 to £20). Thumbs Up
EDIT: The thermostat would be under a lid/cap, that says ''NEVER OPEN WHEN HOT'' or something like that. Thumbs Up
https://www.adrenalin-pedstop.co.uk/upload/images/329c6-777_copy.jpg
Fazzer1996
PostPosted: 00:53 - 21 Mar 2016    Post subject: Reply with quote
where abouts roughly would it be next too? The rad?
S.farrow
RhynoCZ
PostPosted: 01:00 - 21 Mar 2016    Post subject: Reply with quote
The Internet suggests this could be the thermostat housing:
https://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/bvwAAOSwjVVVrOJS/$_35.JPG
https://www.ebay.co.uk/itm/2012-DERBI-125-4V-WC-TERRA-GPR-MULHACEN-SENDA-THERMOSTAT-HOUSING-COVER-AOK-/261974513934
Fazzer1996
PostPosted: 01:06 - 21 Mar 2016    Post subject: Reply with quote
RhynoCZ wrote:
I think it might be on the side of the engine, possibly a pipe going to it from the rad so I'm thinking that's it I will double check in the morning would it be simple to remove it? And I should replace with a new one
S.farrow
RhynoCZ
PostPosted: 01:15 - 21 Mar 2016    Post subject: Reply with quote
No need to replace the housing, be careful not to damage the seal under the housing (if you do damage the seal, then change the seal). Very simple to take it off, just 2 bolts and the hoses. Or at least that's what I get from the picture. Thumbs Up
I'm not very familiar with your motorcycle.
It looks like the only seal that's there is a rubber O ring. So make sure you don't rip it apart, if you do, then buy a new seal (generic).
Fazzer1996
PostPosted: 01:22 - 21 Mar 2016    Post subject: Reply with quote
I will take it off in the morning then I will order a new thermostat and replace it then I will get back to you if it Carrys on over heating thank you very much for your help Smile
S.farrow
bladerunner
PostPosted: 01:43 - 21 Mar 2016    Post subject: Reply with quote
if there is air in the water pump it wont be pumping water either ...check if its got a bleed point on it. the thermostat can generally be removed and the housing replaced ( quick way to check!!) and finally if its not air in the pump or stuck thermostat then its shot headgasket etc.....possibly caused by previous over heating. This assumes its a coolant system fault rather than fuel or ignition etc
Fazzer1996
PostPosted: 09:42 - 21 Mar 2016    Post subject: Reply with quote
it possibly be air in the system as when it gets hot the expansion tank starts to bubble at the bottom right by the hose also where would the bleeder be?
S.farrow
Nemo
PostPosted: 09:56 - 21 Mar 2016    Post subject: Reply with quote
Does the fan come on? If not check the fuse
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Fazzer1996
PostPosted: 09:58 - 21 Mar 2016    Post subject: Reply with quote
saying that the fan has stopped coming on when I have stopped where is the fuse located?
S.farrow
The last post was made 10 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 89.51 Kb
