aprilia RS 125 overheating straight away after top rebuid
leafy1986
PostPosted: 18:07 - 21 Mar 2016    Post subject: aprilia RS 125 overheating straight away after top rebuid Reply with quote
ive just done a top enginge rebuild, changed coolant, transmission oil, and 2stroke and as soon as I start the bike she sounds a bit tight in the cylinder and as soon as I drive to the end of the street and back the temp is like 60 PLSSSS any help?
PostPosted: 18:11 - 21 Mar 2016    Post subject: Reply with quote
Head gasket? Have you torqued the head down properly? Are you sure there's no air lock in the cooling system?
Jmh600
PostPosted: 18:30 - 21 Mar 2016    Post subject: Reply with quote
Sounds like a typical airlock to me. Did you run the bike (briefly!) with the radiation cap off to release any trapped air?
How much coolant did you put in?
Joe
Jmhmotorcycles
leafy1986
PostPosted: 19:21 - 22 Mar 2016    Post subject: Reply with quote
I didn't do them to torque (stupid I know) and im hoping its an air lock a mechanic has told me today to just fill her up with tap water and see if she is ok as SORRY I didnt mention before I first filled her with neat cooland as I thought it was pre mixed but then yesterday drained her again then put 50% distilled water and 50% coolant and it may have been to thick and clogged the pump is any of this true?
stirlinggaz
PostPosted: 19:30 - 22 Mar 2016    Post subject: Reply with quote
hi,
rs has a drain bolt for coolant (5mm hex key iirc).
empty it & start again.
mix up your coolant/water & fill it up.
remember to bleed air out, especially at the wee bleed screw where hoses join together (you can see it by lifting fuel tank iirc).
cheers,
GAZ
leafy1986
PostPosted: 19:43 - 22 Mar 2016    Post subject: Reply with quote
Joe
oh and sorry what do you mean by run her with the radiation cap off? I just started her with the coolant cap off and it didn't go down . do you mean ride her or just start her and with the coolant cap off or the radiator bleed screw?
leafy1986
PostPosted: 19:45 - 22 Mar 2016    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
I filled it till it came out the radiator bleed hole but then I think I put the pipe bleed screw back in so I need to open the pipe bleed screw and start her? or just keep filling
leafy1986
PostPosted: 19:34 - 24 Mar 2016    Post subject: Reply with quote
any more help no?
Pjay
PostPosted: 21:32 - 24 Mar 2016    Post subject: Reply with quote
leafy1986 wrote:
any more help no?
Have you checked the thermostat is working correctly?
If it doesn't let the coolant flow, it will get pretty hot, pretty fast.
Robby
Dirty Old Man
PostPosted: 11:13 - 25 Mar 2016    Post subject: Reply with quote
Usual process for filling coolant after draining.
1. Pour in coolant until it stops going down.
2. Open bleed hole. Close it when coolant is coming out with no bubbles. Repeat for all bleed holes.
3. Rinse off any coolant that has splattered on the bike with hose. Coolant attacks paint.
4. With the rad cap open, start the bike and let it warm up on tickover. When the thermostat opens, expect to see the coolant level drop.
5. Turn the engine off. Walk off and have a cup of tea. Let it cool down for at least half an hour.
6. Top up the coolant. Put the rad cap back on. Take it for a short test drive.
7. After a few hours, check/top up the level again.
If it is overheating after this, you have a problem. The thermostat is the most common point of failure, you can test it in a pan of hot water on the stove. It should open around 70-80 degrees, or when the water is first showing some small bubbles.
The last post was made 9 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 64.92 Kb
