Leaking 2 Stroke Oil
gerg
PostPosted: 10:55 - 23 Mar 2016    Post subject: Leaking 2 Stroke Oil Reply with quote
Noticed my RXS100 started leaking 2 stroke oil. Not sure how severe it actually is, it's going down faster than usual now though. Haven't opened it up yet but it's dripping down from underneath the bit where the clutch is.
Anyone had any experience with this? Where is it most likely to be coming from?
Doovy
PostPosted: 11:05 - 23 Mar 2016    Post subject: Reply with quote
Check the 2 stroke tank (left side of the bike, behind the panel that is easily removable).
That's where I'd start.
PostPosted: 13:43 - 23 Mar 2016    Post subject: Reply with quote
Worst case, it's leaking between the pump and the carb, in which case it may be compromising the oil supply to the engine. Even a leak in the hose from the tank to the pump could be causing it to draw air bubbles.
So it's worth checking out ASAP.
I presume there is still a slight blue haze from the exhaust during normal running?
gerg
PostPosted: 14:50 - 23 Mar 2016    Post subject: Reply with quote
Yeah, I think it's still getting a good oil supply, a "slight haze" is one way of describing what comes out of my exhaust Laughing
I will check these things out, thanks guys.
redeem ouzzer
PostPosted: 16:48 - 23 Mar 2016    Post subject: Reply with quote
Possible the pump itself (or the gasket between the case and pump body), might be lucky as stinkers says and find its a pipe or the bleed nipple.
Be a REAL MAN!
Pjay
PostPosted: 17:39 - 23 Mar 2016    Post subject: Reply with quote
Premix it into the tank and save yourself the worry of a failure.
redeem ouzzer This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
wodge
PostPosted: 21:55 - 23 Mar 2016    Post subject: Reply with quote
The oil pump is behind the round cover on the RHS of the engine. You can take this cover off without draining the gear oil. Inside you will find the pump, it pumps oil from the tank in the left underseat panel to the engine side of the carb. How much it pumps depends on engine speed (the pump is driven from a gear on the end of the crankshaft) and throttle position (i think that controls the stroke of the pump)
It could be that one of the pipes has come loose at the pump or the carb and needs refitting. There is also a bleed screw which could have conceivably fallen out of the pump body leaking oil.
The pump is an easily available part from places like yambits. If you need to replace the pipes consider a clear pipe, it is reassuring to see oil in the pipe.. Smile
nolidge iz pouwur.
Yamaha RXS100 RS100
Pjay
PostPosted: 10:01 - 24 Mar 2016    Post subject: Reply with quote
GT200Fan79 wrote:
Yes cause oil pump failure is common Rolling Eyes
Plus the need to rejet and risk of fouling a plug at low revs.
You sir, are a fucking idiot.
I've never used the oil tank/pump in any 2stroke I've ever owned, quite simply because you can run out or they can fail/leak as the OP's has.
Premixing is a much safer option, you have no need to alter anything, just revving a few times at the lights wont kill you.
2 Stroke bikes went fine for years with no separate tanks for years.
I'm not sure I qualify as a "fucking idiot", when plenty of 2 stroke specific sites recommend this method, if you have any faults in your 2 stroke oil supply.
redeem ouzzer
PostPosted: 11:53 - 24 Mar 2016    Post subject: Reply with quote
You fucking sperg. Of course you need to change carb set up if going to premix. Unless you like lean mixtures cause your putting less fuel through the same jets. Premix is for racing (lightness / less drag) or tuned engines, not standard road bikes. Also compared to my level of 2t experience, yes you probably are a fucking idiot.
Be a REAL MAN!
wodge
PostPosted: 12:23 - 24 Mar 2016    Post subject: Reply with quote
2 stroke racing engines are rarely off the throttle. No throttle, no fuel/oil mix, no lubrication so it makes sense to save weight on a race bike by not fitting extra bits.
Autolube puts oil in the engine even if the throttle is closed, say on a long downhill run and a proportional amount for pretty much any situation. It is sensible on a little commuter like the RXS and on pretty much every road bike, Mr Yamaha didnt fit them cos they are crap, he fitted them because they worked.
Poor maintainance over the years, worn components etc are going to cause problems on a bike that is at least 20yr old and which is probably just suffering from a perished rubber pipe anyhow.
nolidge iz pouwur.
Yamaha RXS100 RS100
Pjay
PostPosted: 15:07 - 24 Mar 2016    Post subject: Reply with quote
GT200Fan79 wrote:
Stuff
Premixing needs very little adjustment to the mixture screw and then you are good to go.
Yes racing engines are more suited to premix, but like i said, premixing has been around since the dawn of 2t so I'm sure his bike will be fine.
If he is having a problem with leaking, then my suggestion of bypassing the system to save a costly repair bill if it fails completely is decent enough free advice for a free fix. If that makes me a 'fucking idiot' in your books, then I can live with that.
I'm not going to call you names, it's quite childish and you are doing a great job of making yourself look stupid without the need for me pointing it out.
redeem ouzzer
PostPosted: 16:53 - 24 Mar 2016    Post subject: Reply with quote
Not the mixture screw you clueless spastic. You need to rejet (change main and also possibly pilot jets). Shows how stupid you are if you think the mixture screw has an effect throughout the Rev range.
Premix isn't a case of mixing oil with the fuel and cracking on. In some cases it even requires modification of the crankcases.
Be a REAL MAN!
Pjay
PostPosted: 17:04 - 24 Mar 2016    Post subject: Reply with quote
You are talking about a tuned engine, he hasn't got this at all.
All he need do is change the mix so that it gives off a slight bluey smoke, then touch it back a slight amount and it will be fine.
Source: over 300k miles on 2t engines, tuned and untuned.
To get the utmost best out of it, sure he can up the jets, but it's not needed on his bike, not at all.
Carry on with your pointless names, you're doing yourself a real turn in the internet warrior stakes. Are you going to up your game to calling me out for a fite?
PostPosted: 20:34 - 24 Mar 2016    Post subject: Reply with quote
The mixture screw only affects the mixture at idle.
If you attempt to run some 2-strokes on premix, you'll kill them. Just try it on a GT500.
An RXS100 isn't one of those and will almost certainly run fine on premix but I don't see the point when there's a perfectly good oil pump in there.
The mixture may be screwed up a little by premixing one but I doubt by much since the punp is drip-feeding the oil directly into the carb just after the venturi anyway. At 50:1, the alteration to the fuel:air ratio is almost certainly negligeable and would fall between jet sizes. You'd need 0.02% more fuel in each charge to cope with part of it being oil.
Of more concern to me than the mixture is what you'd propose to do with the pump which is mechanically attached to the crank and, if it no longer has oil going through it, will eventually seize.
Where you run ito some issues with premixing a road bike is ensuring a good oil supply at idle or on going downhill. One way round this is to set the tickover low so you have to keep blipping the throttle to prevent stalling (this was MZs solution). You would also want to blip the throttle periodically when going downhill, not coast on a closed throttle.
The first three 2-strokes I owned were premix with optional autolube on more expensive models. They had a measuring cup inside the petrol filler cap which held enough for 5 litres of petrol. Slightly over or under filling wioth fuel (and hence over or under-dosing with oil) made no discernable difference. Which tallies with the experience of 70's autolube systems which can be shockingly erratic in the amount of oil they deliver.
Pjay
PostPosted: 22:19 - 24 Mar 2016    Post subject: Reply with quote
My advice was specific to his problem, it wouldn't run with much noticeable difference with premix and the pump is a very simple affair and wont need to be oiled anything past what it will get naturally inside the crankcase. I have in the past run a similar engine for over a year on premix and had no issue. Just the odd clutch in and throttle at low revs and a tweak or two at lights and it works just fine.
He has a leak and it could fail at any time, he said it's getting bad.
Premixing even while he sorts what is causing the leak is sound advice.
Fucking a top end for the sake of a simple fix, even if temporary is not good.
I'm not sure what GT200Fan79 thinks would happen if he premixed, but it wouldn't be catastrophic. Not premixing could be though.
Anyhow, getting the oil supply sorted one way or the other is the best thing to do, as you wont know until it's too late if it fails.
stevo as b4
PostPosted: 11:38 - 25 Mar 2016    Post subject: Reply with quote
Pjay, your advice to op is not a useful fix or possible solution to the leaking oil problem, it's just a personal opinion you are trying to force by saying manufacturers are wrong and you and a few forums have outsmarted all thier R&D for 35 years. Why would op not want to fix the issue without considerable modification to remove the system that's there to help and make the bike run best.
I've got a 2stroke that has been modified to run pre-mix fuel, and I have to say that all the negative points raised by Blue and Stinkwheel are true and it's s pain in many ways to not use the factory set up and keep it serviced properly.
One incorrect fill up/fuel mix can wreak an engine in a few moments, as can not changing your habits regarding how you mix up the fuel before starting and also when riding.
If I had a brand new pump, and all the pipework I'd be using it. The only thing I like better about pre-mix is the slightly lighter throttle action, but that's not worth scrapping a proper lubrication system for generally.
Robby
Dirty Old Man
PostPosted: 11:58 - 25 Mar 2016    Post subject: Reply with quote
The bike has a small oil leak.
Fix the small oil leak.
gerg
PostPosted: 21:59 - 25 Mar 2016    Post subject: Reply with quote
Thanks for your helpful comment
Turns out the 2 stroke oil is leaking underneath the cylinder head and trickling down underneath the clutch case. Must be a 2 stroke oil/fuel mix? I think it's blown head gasket.
The last post was made 10 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 121.3 Kb
