Car problem, scraping noise when turning left, at speed
RhynoCZ
PostPosted: 18:16 - 25 Mar 2016    Post subject: Car problem, scraping noise when turning left, at speed Reply with quote
Hello, my father's indestructible '00 Seat Toledo 1.9TDi, seems to have developed an issue, that I can't seem to find the culprit of. The noise seems to come from the front left wheel. When you go straight it's quiet, but the moment you slightly turn the wheel left, the noise starts. There is no vibration and the noise is a constant hum/scraping noise (me engrish no well again).
It doesn't do the sound when stationary, turing the wheel left or right, so it's not the power steering pump, although we checked the level of the fluid, just in case. Took the front left wheel off, to see if anything became lose or any grind markings anywhere, and we found nothing.
Also, as the issue does not show when vehicle is stationary, I don't suspect the serpentine belt, and/or the pulleys and tensioners.
The wheel bearing seems to be alright and the issue does not emit the typical whining sound of a worn bearing.
A friend of mine implied it could be the tyre making the noise, but why now and how? Mechanic saw the car and found nothing as well. Thinking
Any thoughts?
mrbox
Wonderwall
PostPosted: 18:45 - 25 Mar 2016    Post subject: Reply with quote
is the wear on the front discs similar on both sides?
I ask because the mondeo I did recently squealed on right handers at low speed turned out to be a knackered caliper.
the discs were wearing uneven which was the tell tale for me.
Current bikes: RE Himalayan, Bandit 12, MZ250ES
MCN
PostPosted: 19:03 - 25 Mar 2016    Post subject: Reply with quote
Mudflap, body moulding etc. fouling the tyre when steering.
CV joint on the road out.
bugeye_bob
PostPosted: 19:39 - 25 Mar 2016    Post subject: Reply with quote
If it only happens when you turn then it is your wheel bearing Im afraid,
wheel off and 32mm socket, I bet you manage a tighten, then replace asap before the bearing does collapse,.
swampy
PostPosted: 21:13 - 25 Mar 2016    Post subject: Reply with quote
CV joint has those symptoms in my experience.
I've always found wheel bearings to make a more constant grumble regardless of steering position...
mysterious_rider
PostPosted: 22:21 - 25 Mar 2016    Post subject: Reply with quote
Jack it up. Shake the wheels at 9 and 3 o clock. And again at 6 and 12. Should be no play. Spin the wheels by hand and listen for a rumble.
Shake the cv shafts. Up and down. Helps diagnose slack/ worn joints.
Other than that its rotational. So usual things apply. Brake calipers mounts and discs. Abs rings and etc. Plastic touching stuff can sound loud when magnified by a car chassis. Inner arches come loose sometimes.
Other option is gearbox. Check fluid level. Differential could be shot maybe. Explains why straight is fine. Could just need fluid.Look under and see if bottom of gearbox is wet.
KAWASAKIIIII
andyscooter
PostPosted: 23:20 - 25 Mar 2016    Post subject: Reply with quote
CV joint is first suspect
Or whole shaft if fixed joint
Diggs
PostPosted: 02:48 - 26 Mar 2016    Post subject: Reply with quote
May sound daft, but check the opposite wheel bearing and the opposite coil spring. What you see may well surprise you...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
PostPosted: 00:47 - 29 Mar 2016    Post subject: Reply with quote
Migrants in the wheel arches mate - obvious innit. Wink
Triumph Trophy Launch Edition
RhynoCZ
PostPosted: 12:51 - 31 Mar 2016    Post subject: Reply with quote
So, it could be all of the above, as you all have suspected (not the migrants). My mechanic says I/my father should drive it more, so the noise gets more noticeable, so he can tell where it is coming from. He says he could just change the bearings, but he's not 100% sure it would solve the problem. So more kilometers to be done, in order to determine what the culprit is. Thumbs Up
Just got back from a 600km trip, the car drives and sounds the same.
MCN
PostPosted: 17:37 - 31 Mar 2016    Post subject: Reply with quote
Power Steering Doofur. Relief Valve for left steer blowing off. May sound like scraping.
Grasping at Straws now.
The last post was made 10 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 68.78 Kb
