How Sorted Is Your Bike?.
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
HughiusMaximu...
PostPosted: 12:25 - 26 Mar 2016    Post subject: Reply with quote
Thats quite a list... should be ready for next years biking 'season'...
stevo as b4
PostPosted: 12:31 - 26 Mar 2016    Post subject: Reply with quote
I'm in the process of sorting my 125. Cosmetically I'm happy, but a better front brake and firmer forks for road use would be a good move, depending on if my other changes make it much faster or not I spose?
Supermoto_Fan
PostPosted: 12:35 - 26 Mar 2016    Post subject: Reply with quote
I'd like to get some crash bungs, to go with my bar end and fork sliders. Braided lines and then I'd say she's near enough done
thx1138
PostPosted: 12:38 - 26 Mar 2016    Post subject: Re: How Sorted Is Your Bike?. Reply with quote
ZX-7R wrote:
Is it how you want it or is there lots more work to do to get it how you want it?.
Cosmetically my bike is knackered.
Need to replace wheel bearings, want to fit a long range fuel tank.
anthony_r6
PostPosted: 12:45 - 26 Mar 2016    Post subject: Reply with quote
MOT is due, I always get a little paranoid when it comes around, so dread all the things I've been ignoring, no matter how many and eventually set out to fix them.
I've let my chain get a little rusty (On the plates, rollers seem okay) so I'm going to change the sprockets and chain in the next week or so. Also think it's coming due for valve clearance check, which I'm not looking forward to due to having no indoor space to work in. Probably going to need some new tyres soon, too.
Cables could probably do with being lubricated, and there is a hairline crack in the nose that I need to repair/replace the fairing on.
Cosmetically I'd like to buy replacement fairings and tank and change the colour of the bike to orange (Whilst retaining the originals just in case I get bored)
recman
PostPosted: 13:02 - 26 Mar 2016    Post subject: Reply with quote
The only things I've done to really change the look but which also enhances things on a practicality level is to add a belly pan which also gives a little protection and to fit bar end mirrors which look so much better than stock and now I can see behind rather than elbows.
I've been toying with the tail tidy idea but the only real option is from R&G and for what it is and the fact that its purely cosmetic, it's piss take money.
I have the resources to design and fabricate one, even the means to have it electro-dipped and sprayed but by the time I get round to it, I may well have traded in.
redeem ouzzer
PostPosted: 13:04 - 26 Mar 2016    Post subject: Reply with quote
X5 is spot on.
1100 has less than perfect carburetion but is otherwise spot on. New tubes and needles when I can be bothered.
400 just finished, rides well but needs dyno time to perfect.
YR5 probably still works, have Cush drive and tacho drive leak to sort.
Be a REAL MAN!
sjc
PostPosted: 13:14 - 26 Mar 2016    Post subject: Reply with quote
Mechanically its pretty sound nothing needs doing really.
Cosmetically I want to do a lot of work though.
Will get there eventually,
then sell it I expect
chickenstrip
PostPosted: 13:40 - 26 Mar 2016    Post subject: Reply with quote
No more mods to do on the Fazer, although ideally I'd like to shorten the exhaust link pipe for perfection, but that's only a cosmetic thing. Needs a service, tyres and a glitchy low rpm running problem sorting out, booked in for 11th April for all this.
Striple - had a can on order, but after a month, they emailed to say they don't do that one anymore Mad so need to look for another. Thinking about bar end mirrors and a tail tidy, and need to soften the suspension settings a bit but otherwise, all sweet Smile
M.C
To-do list:
- check valve clearances (only 600 miles overdue Embarassed)
- rebuild original forks and replace the rough ones I got off eBay
- vinyl wrap or repaint or replace the tank/air scoop/ maybe headlight brackets as they're scratched
Or sell it as is Laughing
Supermoto_Fan
PostPosted: 14:13 - 26 Mar 2016    Post subject: Reply with quote
ZX-7R wrote:
Crash bungs are essential on a naked IMO.Got R&G ones on my ZX-7R and would fit them to any future purchase i make if they did not have them.
Got R&G everything else on the bike, just overlooked on the frame sliders, Going to dig out the ECU Monday and send that off for a rework... Laughing
andyscooter
PostPosted: 14:20 - 26 Mar 2016    Post subject: Reply with quote
LML is ongoing as keep changing things (cos that's what you do with them)
burger is a work tool gets washed sometimes and runs well
talkToTheHat
PostPosted: 14:23 - 26 Mar 2016    Post subject: Reply with quote
Crash bungs:done
Luggage - done
Renthal 'low' bars - done
Secondary fusebox and acessory relay - done
cheap cat-scarer alarm - fitted
Twin horns driven by relay and accessory circut, pligs straight into existimg horn wiring in case the complicated setup fails -done
Muffs, on for winter, off for spring
Heated grips: done
Mirror extentions: done
Resin stickers (like tankpad) on heel guards to stop boots going grey with aluminium: done.
Osram nightbreakers: done for dip beam, need to do for main.
Hugger: came fitted
front fender extention: removed, cleaned, realigned, refitted
8000 mile service, including valve clearences: done before i hit 9000, done except fuel filter as i have the wrong one.
Fuel tap: removed, cleaned, replaced.
Fork seals: replaced under warranty
Next oil change: reminder set in fuelly.
Usb charger thingy on bars: twice as the first one failed.
Mount for givi satnav/phone holder: done
correct arrangement of overflow pipe: done
Todo: fit bcf/nobcat stickers next time bike is clean. Change fuel filter. Fit scottoiler as frequent chain scrubbings are getting annoying. Braided brake lines can happen soon, probably.
Bike is running well, feels like my bike.
Bandit. does. everything.
pepperami
Put braided lines on all my bikes as a standard thing I do = done Thumbs Up
Stuck a cheapy watch somewhere on the instrument cluster = Thumbs Up
Wired in an auxiliary electrical point into each bike for chargers and sat-nav = done Thumbs Up
All service intervals are up to date Thumbs Up
washed = done Thumbs Up
Apart from that my bikes are almost standard .
Springbok_Rider
PostPosted: 17:19 - 26 Mar 2016    Post subject: Reply with quote
I keep swearing not to mod my bikes after losing money when selling them. However, after purchasing a 2010 Ducati Monster 1100 I've gotten a little carried away:
Already Installed:
Tail Tidy
Termignoni Exhausts
Seat Cowl
Purchased, waiting to Install:
7x5 Number Plate with GB Badge
Bar End Mirrors
Tech Spec Tank Grip Pads
Ducati Performance Seat (lowers 20mm and less sliding about)
CNC Shorty Levers
EvoTech Crash Bobbins
BiTubo Steering Damper
Renthal/Tsubaki Sprocket and Chain Kit (although considering exchanging it to go 4 teeth up in the rear to smooth gearing)
Instrument Cover to Remove Token Bikini Fairing
On the List:
1100 Evo Rear Sets to Replace Stock Silver Chicken Wings
Powder Coat Wheels Black (or purchase new black rims)
Ohlins Rear Shock
Front Suspension Rebuild and Tune
Woodcraft Clip Ons (maybe)
SpeedyMoto Triple Top Clamp
Front/Rear Spindles
Oberon Clutch Slave Cylinder
SpeedyMoto Quiet Dry Clutch Cover (I might be the only one who thinks it sounds like a bag of spanners)
I'm sure even after all that I'll find something else to mod. It's an addiction!
2005 SV650 ---> 2002 CBR 600 FS ---> 2010 Monster 1100 ---> 2006 Yamaha YZ250F ---> 2008 Street Triple 675
PostPosted: 17:29 - 26 Mar 2016    Post subject: Reply with quote
Done:
Race cans
Decat
braided lines
double bubble
Re-Valved suspension
Lithium battery
Race filter
R&Gs
small plate
levers
In Progress:
Re-fuelling module. Still trying to get it to run properly
Front mudguard just bought off of eBay to replace the cracked one.
To Do:
Tidy up bolts
Tidy up fairings(moar carbon?)
Tidy up or replace wheels
Ride it more?
chickenstrip
PostPosted: 17:44 - 26 Mar 2016    Post subject: Reply with quote
Since everyone else is listing what they've already done, here's mine for the Fazer:
2003 R1 front forks with K Tech internals.
R6 rear shock.
Ivan's full monty carb tune with air box mod. and BMC air filter.
Scorpion Red Power carbon can.
HEL braided brake lines.
Carbon hugger.
Carbon hydro-dip side panels, air box covers, frame covers and radiator end covers.
Scottoiler.
Pazzo levers.
Devilsyam/Yamaha tuning fork s/arm pivot covers.
PostPosted: 17:56 - 26 Mar 2016    Post subject: Reply with quote
The Ducati is spot on.
The MV needed a rear hugger, maybe get a radiator guard.
Got 30ltr tailpack and large tankbag so yeah pretty much sorted.
Falco
PostPosted: 18:26 - 26 Mar 2016    Post subject: Reply with quote
Finally manged to get more or less on top of general maintenance, so now its onto "things I really should do but aren't currently affecting the bike":
Replace the exhaust - I suspect some of the rattling to be from a loose baffle or similar in the exhaust, if not...I'll have a spare exhaust!
Replace the clutch cable - Nothing wrong with the old one as far as I can tell, but it's one less thing to fail.
Replace the clutch plates - again nothing wrong, but I want the practice and I have no idea when (or even if) they have been done before
Replace Front Tyre - not urgent but I need to get some weights and figure out a way to spin the wheel for balancing.
New Valves?- Replacing the tappets yesterday, there is still a slight mismatch between one of the valves and the tappet, so I guess its the valve which is a bit worn. When I get to this I guess I might as well do a whole top end rebuild as I will have to take it all apart anyway. Not wild about the idea so I'll put it off till I have a 2nd bike I think.
Replace Spark plug - Must get that correct socket today!
EDIT: Also replace oil in front forks
craigs23
Mr Muscle
PostPosted: 19:41 - 26 Mar 2016    Post subject: Reply with quote
Most of mine are sorted, but I'm always finding things that need doing.
Need a rear shock with some damping for the CBR, new front wheel bearings for one of the Superfours, and a bit of a Easter Bunny resurrection magic applied to the Monument.
Not to mention a lot of riding. Need more sunny riding.
The last post was made 10 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 134.41 Kb
