| HRC1krr |
 HRC1krr L Plate Warrior
| bladerunner |
 Posted: 01:20 - 29 Mar 2016 Post subject: |
If he only added a small amount then I expect you'd be ok. the expansion tank will be open to normal air pressure and thus can drain whats in the expansion tank if you park your bike under a truck/ upside down in the hedge etc but the main system should be sealed by your radiator cap, only bleeding off enough coolant to prevent to much pressure in the rad etc during normal operation, once that pressure is normal it'll seal the coolant system again preventing loss to the outside world ......also if you have no coolant in the system then the coolant temp gauge is usually sitting in air and reads...not a lot!! the fact it was reading normally is kinda good  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| spottedtango |
 spottedtango Trackday Trickster
| Jmh600 |
 Jmh600 Nova Slayer
| HRC1krr |
 Posted: 15:27 - 29 Mar 2016 Post subject: |
Thanks for the feedback all.
https://i787.photobucket.com/albums/yy151/redlinernyc/Untitled_zpsaopi3xgj.jpg
I drew a white line showing the connection of the reservoir hose to the radiator cap and radiator. So basically this path is blocked before the radiator cap opens up? So if I turned my bike upside down (hypothetically speaking) coolant would be blocked from flowing into the radiator from the reservoir and vice versa?
Again, radiator was near full, so I think it's fine. |
| Jmh600 |
 Jmh600 Nova Slayer
 Posted: 17:03 - 29 Mar 2016 Post subject: |
That's right! There's a pair of valves in the cap. One opens under positive pressure (when the coolant heats up) and allows it to flow to the expansion tank, and the other opens under negative pressure (when cooling) and allows any coolant the rad requires back in  ____________________ Jmhmotorcycles |
 Posted: 19:33 - 29 Mar 2016 Post subject: |
You won't have caused any harm doing what you say you did, so you can stop worrying. ____________________ a.k.a 'Geri'
| HRC1krr |
| Ariel Badger |
 Ariel Badger Super Spammer
| HRC1krr |
| Jmh600 |
 Jmh600 Nova Slayer
| Lone-Wolf |
 Lone-Wolf World Chat Champion
 Posted: 01:22 - 31 Mar 2016 Post subject: |
Wotcha.
Like they all say - no harm done.
I've currently got no radiator at all on my Ford engined trike . . . and I start and run that 'cos the bugger's too heavy to push in and out of the garage. ____________________ Cheers.
L.W. - www.moonshiners.org.uk |
| HRC1krr |
The last post was made 10 years, 210 days ago. Instead of replying here, would creating a new thread be more useful? |
