Micron 2 Stroke Expansion Chamber
gerg
PostPosted: 09:19 - 29 Mar 2016    Post subject: Micron 2 Stroke Expansion Chamber Reply with quote
Anyone have experience with re-packing exhausts? failed its MOT due to "excessive noise and degradation" so I figured I'd repack it. Simple, right? Wrong.
The packing is so charred it won't come out. I tried to get the bottom part off to make it easier for the packing to slide out but it wouldn't come off even after dousing it in WD40 and whacking it with a piece of metal pipe and a hammer from the inside.
The bottom bit I mean is in the picture. Does anybody know if it's supposed to come off or have any other ideas?
RhynoCZ
PostPosted: 09:30 - 29 Mar 2016    Post subject: Reply with quote
Yes, you are going to need a drill, rivet tool, rivets and the insulation wool. Drill out the rivets, take the muffler appart, clean it, stuff in as much as wool as you can, put it back together, use the rivet tool.
Sometimes it is sufficient, when you drill out (open) only one side of the exhaust, but other times it needs to be drilled (opened) on both sides.
*wool = I'm not sure it's called like that in your country.
gerg
PostPosted: 09:31 - 29 Mar 2016    Post subject: Reply with quote
charred packing
gerg
PostPosted: 09:33 - 29 Mar 2016    Post subject: Reply with quote
Hi Rhyno, thanks for the reply
My one doesn't have rivets unfortunately, just the three bolt holes you can see in the picture
RhynoCZ
PostPosted: 09:34 - 29 Mar 2016    Post subject: Reply with quote
Ah, I see, well then get a screwdriver and start digging, I guess. Razz
EDIT: If you don't want to bother, just buy a new silencer. Those are rather cheap.
gerg
PostPosted: 09:36 - 29 Mar 2016    Post subject: Reply with quote
gonna need a big screw driver if it comes to that Crying or Very sad
PostPosted: 09:41 - 29 Mar 2016    Post subject: Reply with quote
Find a friendlier MoT tester or a new exhaust. Thumbs Up
gerg
PostPosted: 11:45 - 29 Mar 2016    Post subject: Reply with quote
would quite like to fix it and put it back on, as it's a after market exhaust for a rxs 100, quite rare apparently
that little ring with the three bolt holes looks like it should just pop out... what do you guys reckon? could be welded on there and I've just spent half an hour whacking it for no reason Laughing
PostPosted: 12:10 - 29 Mar 2016    Post subject: Reply with quote
Put a legal one on for MoT then take it off.
gerg
PostPosted: 12:24 - 29 Mar 2016    Post subject: Reply with quote
I actually have the stock exhaust so that's not a problem. Just wanna get this one sorted Smile
c_dug
PostPosted: 12:27 - 29 Mar 2016    Post subject: Reply with quote
If I failed an MOT for my bike being to loud, they'd lose my custom permanently.
gerg
PostPosted: 13:16 - 29 Mar 2016    Post subject: Reply with quote
It's a funny business getting MOTs. Seems to be a lot of grey areas and dependence on the tester (or his mood that day!)
PostPosted: 13:42 - 29 Mar 2016    Post subject: Reply with quote
My dad calls our MoT tester Stevie Wonder Laughing
The last post was made 10 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 75.25 Kb
