Background process affecting laptop... help needed
Bubbs
PostPosted: 20:09 - 30 Mar 2016    Post subject: Background process affecting laptop... help needed Reply with quote
Evening all,
Just hoping for a little help. Computer started acting up. When starting up it acts like it's working on some process in the background which affects typing by missing letters.
It also affects the mouse, where it moves normally then stammers then continues to move.
Around 5mins after start up the problem disappears and all goes back to normal... it's doing my head in. The task manager shows normal CPU usage, no processes are hogging power. The laptop has had a fresh install of Win7 from totally formatted drive so not much actually on the system.
Laptop is Asus N55s with i5-2410M @2.3 ghz with 8gb ram so power isn't an issue.
I'm thinking this is a hardware issue, hard drive failing? But not clued up enough to know for certain.
Anyone able to help me trouble shoot?
Thanks.
Bubbs
UncleFester
PostPosted: 20:17 - 30 Mar 2016    Post subject: Reply with quote
Disable Superfetch in system services, also check what the indexing service is actually indexing.
may also be worth checking win updates are up to date and that it 's not trying to download Win10 in the background ...
Only other things from memory, DotNet optimisation stuff post service pack install and / or maybe the built in Windows security thing scanning away in the background.
Failing that - run Malwarebytes through it.
2017 Z1000SX
Bubbs
PostPosted: 21:54 - 30 Mar 2016    Post subject: Reply with quote
disabling super fetch seems to have fixed it... what is that for?
CaNsA
PostPosted: 22:02 - 30 Mar 2016    Post subject: Reply with quote
Superfetch is Indexing.
Windows thinks its a good idea to keep an updated list of the location of all files on the hard drive.
andym
PostPosted: 22:29 - 30 Mar 2016    Post subject: Reply with quote
What about running msconfig and Disable All in the Startup tab.... everything just loves getting in on that startup
CaNsA
PostPosted: 23:23 - 30 Mar 2016    Post subject: Reply with quote
Services are not shown in msconfig.
Loui5D
PostPosted: 11:58 - 31 Mar 2016    Post subject: Reply with quote
They are Win 7 upwards.
CaNsA
PostPosted: 12:03 - 31 Mar 2016    Post subject: Reply with quote
OK, to be specific...
They are not shown in the startup tab of msconfig.
andym
PostPosted: 13:05 - 31 Mar 2016    Post subject: Reply with quote
But there is a Services tab in there, I just mentioned the Startup tab as I usually go in there and disable everything after a clean install (that and I've never really had to mess around in the Services tab)
Bubbs
PostPosted: 21:54 - 04 Apr 2016    Post subject: Reply with quote
spoke too soon, the stutter is back
UncleFester
PostPosted: 07:55 - 05 Apr 2016    Post subject: Reply with quote
How much system memory do you have?
If it's > 8gb you can try turning off the pagefile.
Also check that update cleanups aren't still running or that it isn't trying to download Windows10 in the background.
MS spyware scanner / cleaner thing can be a pig whilst it runs.
2017 Z1000SX
linuxyeti
PostPosted: 09:26 - 05 Apr 2016    Post subject: Reply with quote
Replace windows with Linux
Beware what photos you upload, or link to on here, especially if you have family members on them
sickpup
Old Timer
PostPosted: 10:53 - 05 Apr 2016    Post subject: Re: Background process affecting laptop... help needed Reply with quote
Windows update?
From a fresh install there are over 150 updates to do. I have found that unless you do them manually, 10 updates at a time you run into performance issues as the system cannot handle the amount.
Bubbs
PostPosted: 12:52 - 09 Apr 2016    Post subject: Re: Background process affecting laptop... help needed Reply with quote
sickpup wrote:
Windows update?
Ah, i did them all in one go... Maybe a factory restore is in order
panrider_uk
PostPosted: 08:53 - 10 Apr 2016    Post subject: Re: Background process affecting laptop... help needed Reply with quote
Bubbs wrote:
sickpup wrote:
Windows update?
Click on Start then type Windows Update and run it.
It'll tell you if there are any outstanding.
Bubbs
PostPosted: 11:10 - 14 Apr 2016    Post subject: Reply with quote
Found the cause = battery has died and it was causing issues with performance. Removed it and voila
/thread
The last post was made 10 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 90.43 Kb
