Lever sleeves
M.C
PostPosted: 09:02 - 30 Mar 2016    Post subject: Lever sleeves Reply with quote
Anyone use these, and do they help with cold fingers? Also any DIY solutions being used?
yen_powell
PostPosted: 09:16 - 30 Mar 2016    Post subject: Re: Lever sleeves Reply with quote
I used to have one fitted to my clutch lever on my Africa Twin to stop the metal pulling heat out of my fingers when riding round town and the clutch was in constant use. Made a big difference to me anyway.
Bought some recently for my Versys for the same reason but the thing just tore when trying to get it over the lever ball end. I will try again with the remainder of the pair, perhaps after warming it up thoroughly this time.
XT1200Z and a DR350 in bits
Nexus Icon
PostPosted: 13:45 - 30 Mar 2016    Post subject: Re: Lever sleeves Reply with quote
How about a length of heat-shrink from Maplins (or work, if you're fortunate)?
Greetings from Shitsville!
M.C
PostPosted: 21:12 - 30 Mar 2016    Post subject: Reply with quote
We just wrap everything in electrical tape at work. Was thinking of wrapping the levers in tape but thought it might not be that effective.
If it's the same sort of temps early next week (about 5 degrees) I'll order some, as I've started getting a tingling in my fingers which lasts the day Confused
Fin
PostPosted: 21:38 - 30 Mar 2016    Post subject: Reply with quote
God.i wrote:
Never heard of them. I'm hardcore I rode all winter without heated grips or muffs.
The same as half the people (if not more) who ride through winter, haven't seen any muffs or heated grips at college.
Fin
PostPosted: 21:44 - 30 Mar 2016    Post subject: Reply with quote
God.i wrote:
Try 60 odd miles over the pennines daily in all weathers.
You get mountains on your commute!?
Lucky fuck
hellkat
PostPosted: 22:04 - 30 Mar 2016    Post subject: Reply with quote
Ghey.
Sable
PostPosted: 22:10 - 30 Mar 2016    Post subject: Reply with quote
I manage fine through the North London mountain range all winter, snow every day, even in summer and up hill both ways.
M.C
PostPosted: 17:09 - 31 Mar 2016    Post subject: Reply with quote
Then pi$$ on your hands to warm them up?
MCN
PostPosted: 17:20 - 31 Mar 2016    Post subject: Reply with quote
Don't hold your piggies on the tewibwee cold levers and your handypops won't cool down so much.
Fiziks init.
talkToTheHat
PostPosted: 01:07 - 02 Apr 2016    Post subject: Reply with quote
Electrical tape will likely ooze adhesive and unwind itself. Heatshrink stays put but you'll need a few layers. Foam sleeves like grip puppies feel horrible and are fatiguing to use. Silicone sleeves are least shit if you can find them.
My sister found me some randomly, perhaps intended for pedal iron. Probably from a belgian market stall. I see these from time to time on ebay whikst searching other items, perhaps m&p or wemoto also helpful.
Bandit. does. everything.
PostPosted: 01:41 - 02 Apr 2016    Post subject: Reply with quote
So, you wrapped eleventy layers of duct tape round them, and this didn't achieve the intended result because... ?
talkToTheHat
PostPosted: 03:01 - 03 Apr 2016    Post subject: Reply with quote
Oooh, look, the adverts on the thread have the answer. https://www.ebay.co.uk/itm/Motorcycle-Black-Silicone-Lever-Sleeves-Brake-Clutch-Lever-Grips-Pair-/400988223006?_trksid=p2141725.m3641.l6368
M.C
PostPosted: 14:52 - 04 Apr 2016    Post subject: Reply with quote
Do these interfere with the clutch lever, I'm guessing you adjust your clutch cable once fitted?
The last post was made 10 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 92.75 Kb
