DVR config
mudcow007
PostPosted: 08:45 - 31 Mar 2016    Post subject: DVR config Reply with quote
morning all
Been a spate of thieveries by me recent so bought a couple of cameras and dvr (H.264?)
Anyone had any experience of setting them up?
Cameras are connected using Cat5 an baluns.
Can see them image in the DVR, but god knows if its being recorded, also cant connect to it via my network in the house although i can ping the box etc
ws4936
PostPosted: 12:42 - 02 Apr 2016    Post subject: Reply with quote
What system are you using?
And you mean an NVR?
Edit:
Does this help?
If everything seems under control, you're just not going fast enough.
mudcow007
PostPosted: 19:59 - 04 Apr 2016    Post subject: Reply with quote
Err if i'm honest I haven't got a clue what model it is, will see if there is written on the board..
when i try to log into the web interface, i can get in but nothing works. if I select a video feed, I get a dialogue complaining I haven't got quick time installed
So, installed quick time an still says its missing do i want to install it, clicking on the install link it provides takes me to a dead apple page
tried with Firefox an IE11 (activex is enabled etc)
sickpup
Old Timer
PostPosted: 12:56 - 05 Apr 2016    Post subject: Reply with quote
Can you post a picture of the DVR, front and rear connections and tell me what its IP address is on your network?
Does it have a hard drive fitted, many are supplied without?
Also is it connected directly to a TV or monitor?
mudcow007
PostPosted: 14:23 - 05 Apr 2016    Post subject: Reply with quote
https://i25.photobucket.com/albums/c81/mudcow007/20160405_141225_zpsuzvtkpcg.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20160405_141236_zpswwnbprix.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20160405_141434_zpsxxxz7lhm.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20160405_141441_zps7duoei4l.jpg
I have set it up in my office in work, connected a mouse to it an monitor via a vga cable. DVR came without a hdd so ihave fitted one my self (a 1TB)
It must have two logons, as if i connect to it via its local ip address, i can log on as admin but can do bugger all once im in there.
connecting via a mouse etc gives me more options but im unable to log on as admin (errors with incorrect password) even tried a password generator but thats didnt work
CaNsA
PostPosted: 14:25 - 05 Apr 2016    Post subject: Reply with quote
How close to Litherland are you?
lihp
PostPosted: 14:27 - 05 Apr 2016    Post subject: Reply with quote
Got a new DVR in work that we can't log in to!
Looks similar to that, what was your default Admin password?
mudcow007
PostPosted: 14:28 - 05 Apr 2016    Post subject: Reply with quote
I work in Aintree so not a million miles away
default password is Admin/123456 I think
CaNsA
PostPosted: 14:29 - 05 Apr 2016    Post subject: Reply with quote
You can bring it round here if you want.
Spend a bit of time fucking about and working it all out.
Hold each other in a warm embrace.
mudcow007
PostPosted: 14:32 - 05 Apr 2016    Post subject: Reply with quote
cheers dude, I might take you up on that even if its just for the warm embrace.... Shocked
just downloaded some password generators that use the date or some other snizzle so will try them
there isnt even any jumpers to reset the password grr
lihp
PostPosted: 14:43 - 05 Apr 2016    Post subject: Reply with quote
Thanks Thumbs Up
It worked
sickpup
Old Timer
PostPosted: 14:57 - 05 Apr 2016    Post subject: Reply with quote
First off all the set up can only be done when the DVR is connected direct to a TV or monitor.
When connected via the network you have to use IE and it will require downloading an ActiveX widgit, without that it won't work. Once downloaded and restarted you should be able to see the output from your cameras, something like this...
https://i945.photobucket.com/albums/ad297/750RK/Odds%20and%20ends/cctv2.jpg
In network mode you can only do things like playback or magnify an individual cameras view.
There are no passwords except those that you put on it or the distributor did if they are being annoying. All units have the user name of Admin until changed by you.
Assuming you haven't changed the HTTP port you should be able to connect over the network but you will either bneed to set a static IP on the unit or a reserved IP on the router. If you change the HTTP port to 443 or 8080 as I had to do for external access then you may need to tag these on the end of the IP eg :443 :8080 to get full access.
mudcow007
PostPosted: 15:44 - 05 Apr 2016    Post subject: Reply with quote
cheers sickpup
any idea of the widget i need to install?
I have even dug out an old XP laptop thinking the IE version on my Win7 (IE11) was too new for it
but old IE didnt work either
sickpup
Old Timer
PostPosted: 16:12 - 05 Apr 2016    Post subject: Reply with quote
Log into the DVR via IE11 and it should offer you the option to install it.
The last post was made 10 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 81.07 Kb
