| Simple |
 Simple World Chat Champion
| P.addy |
 P.addy Red Rocket
| Simple |
| Pjay |
 Pjay World Chat Champion
| Simple |
 Posted: 11:44 - 31 Mar 2016 Post subject: |
Yes, thanks, done that, all fuses happy and non related to brake system.  ____________________ Insta - FemFeral |
| Pjay |
| Simple |
 Posted: 11:50 - 31 Mar 2016 Post subject: |
Indicators are working perfectly so if it did, the fuse would be sound and we've already tested the lights, the switches, the wiring so short of bad voodoo the lights should work  ____________________ Insta - FemFeral |
| Pjay |
| Simple |
 Posted: 11:54 - 31 Mar 2016 Post subject: |
all checked, this makes no f**king sense  ____________________ Insta - FemFeral |
| Pjay |
| Simple |
| Pjay |
| P.addy |
 P.addy Red Rocket
| Simple |
| P.addy |
 P.addy Red Rocket
 Posted: 12:58 - 31 Mar 2016 Post subject: |
I hate electrics Not much help I know. Feeding it 12v directly from a battery doesn't illuminate it, as in physically removing the battery and cluster, giving it 12v? |
| Simple |
| P.addy |
 P.addy Red Rocket
| J.M. |
 J.M. World Chat Champion
 Posted: 19:27 - 31 Mar 2016 Post subject: |
| Simple wrote: | Just tested the light cluster and that works, it has also made me realise that the brake light is on all the time, I have already removed the front brake switch and bypassed it, I removed the bypass and the rear light remained on brake light function, so whilst I have been checking for power to everything I have not checked the rear brake switch is turning off. duh, fingers crossed after lunch that is what it is.
...seriously hoping it is not something wrong with the ECU! |
The tail light is on all the time on this model. The brake light shouldn't be. Are you sure the brake light is on and not the tail light?
The tail light belongs to the headlight fuse, not the indicator fuse, and the fuse can be confirmed to be working correctly if your dash is lighting up and your tail light/side lights come on.
The brake light belongs to the indicator fuse, as from the indicator fuse 12v is supplied to both of the brake switches. If you remove the indicator fuse, the tail light should still function.
The front and rear brake light switches are not linked, and receive a separate 12v input each. When either switch is closed, the 12v passes through a shared yellow wire. So if either of these switches is faulty and causing your brake light to turn on, this single yellow wire will have 12v passing through. Otherwise, when the brakes are not being used, this yellow wire will be dead.
The yellow wire connects directly to a 3-pin connector block for the rear tail/brake light.
If you apply 12v to the blue (or is it purple? I am colour blind) wire directly to the tail light assembly, and connect up the earth, your tail light should come on. If you then additionally supply 12v to the yellow wire, your brake light should also come on.
Your ECU doesn't play any role in this circuit. ____________________ 2004 R1 & 2018 XSR900 |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 19:32 - 31 Mar 2016 Post subject: |
Top nerding that man. ^  ____________________ My Flickr |
| P.addy |
 P.addy Red Rocket
| Simple |
The last post was made 10 years, 227 days ago. Instead of replying here, would creating a new thread be more useful? |
