heated grips
lee8040
PostPosted: 18:52 - 31 Mar 2016    Post subject: heated grips Reply with quote
What are your recommendation s please? I wantto get some fitted on my next bike for the cold mornings. I had the Oxford ones which were good but notice a few different makes. Has anyone found other makes betterthan oxford?
Thanks
lee8040
PostPosted: 18:56 - 31 Mar 2016    Post subject: Reply with quote
I start early and some mornings it's nice to have the on plus I wanted to get them fitted and all sorted before I get the bike
PostPosted: 19:09 - 31 Mar 2016    Post subject: Reply with quote
I have symtec heated grips which are a heating element that sticks onto the handlebar under a set of standard grips.
Not as hot as some but very simple and unobtrusive, just feels like the normal grips to ride with, only hotter. High and low settings with a three position switch.
notbike
PostPosted: 19:12 - 31 Mar 2016    Post subject: Reply with quote
I used Oxford ones too. I'd recommend heated gloves instead. Its what I'm getting for my next bike. Heated grips don't get the backs of your hands warm. Easier to set up and less faffing around too. Leave charging cable tucked under a fairing/zip tied to the headstock and plug your gloves in when you get on the bike. Removing old grips and putting new ones on isn't as easy as wiring a single cable to your battery and strapping it down.
PostPosted: 19:49 - 31 Mar 2016    Post subject: Reply with quote
I'm more of a muff fan than grips but grip wise Roxter ones, they are either I feel some warmth or fuck dat hot. Well worth it.
Nobby the Bastard
Harley Gaydar
oxfords, but go for the tourer ones.
The sports ones are too soft and wear off, leaving the wires on the surface within a couple of years..
Triumph Sprint ST 1050
Nobby the Bastard
Harley Gaydar
PostPosted: 19:50 - 31 Mar 2016    Post subject: Reply with quote
insert obligatory muff joke here.
Vracktal
PostPosted: 21:12 - 31 Mar 2016    Post subject: Reply with quote
Oxfords on my KLE are still holding up great after 6 years fitting, get roasty hot and barely any wear. Remember to get a relay too since they still don't come with one in the box.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
steve__b
PostPosted: 08:50 - 01 Apr 2016    Post subject: Reply with quote
I'm considering heated grips for my next bike. Do they warm up finger tips as well as hands ??
Riding 2001 BMW F650 Funduro. 1st bike Yamaha YBR 125. CBT Aug 2014. Theory Oct 2014. Mod 1 Passed Sept 2015. Mod 2 passed Dec 2015. Wish I'd started biking 20+ years ago...luv it Smile
BTTD
PostPosted: 09:40 - 01 Apr 2016    Post subject: Reply with quote
Yes if you keep your fingers wrapped around the bars, no if you're covering the brake or using the clutch.
steve__b
PostPosted: 09:46 - 01 Apr 2016    Post subject: Reply with quote
My fingers wrapped around bars...motorway commuter ☺👍
inline4
PostPosted: 11:01 - 01 Apr 2016    Post subject: Reply with quote
God.i wrote:
Summer gloves + tucano urbano muffs r361 + heated grips = toasty hands.
What he said Smile
conker
PostPosted: 11:25 - 01 Apr 2016    Post subject: Reply with quote
https://www.twowheeljunkie.co.uk/motopro-snug-heated-grips.html Cheap and do the job, usually on offer there for around £20 to £250. Only 2 settings unlike more expensive ones, but never caused me any issues.
talkToTheHat
PostPosted: 01:30 - 02 Apr 2016    Post subject: Reply with quote
I had some r&g ones. The one button controller with 5 heat settings worked well with gloves on. The grips themselves were really hard, yet wore really fast. The cables on the throttle side failed where they joined the grip. I think they lasted about 15 months.
I've had oxford touring grips for i think twice that. Much more compliant feeling rubber and very little sign of wear. There's a much better moulding where the cable meets the grip. I've heard complaints of the two button control unit failing but mine is yet to fail. If it does i will use the r&g controller. There's a battery saver thing built in so they will switch off after a few minutes and you don't need to mess about witha relay. I have one wired in anyway. I rarely have them on above 3/5. This winter i had muffs as well and felt much more comfortable with the grips on 1/5 or 2/5 wearing relatively thin gloves.
Bandit. does. everything.
c-m
PostPosted: 09:40 - 02 Apr 2016    Post subject: Reply with quote
I'v had a few over the years.
R&G ones were the worst in terms of heat. They never got anything higher than lukewarm, and I had a controller die within months then a grip die.
Oxford ones are bulky with their wires and big controllers, but work better than R&G. The rubber on the Oxford ones goes hard after a while, almost like a hard plastic.
Symtec - These are the best ones I've used. The under grip pads mean you can use any grips you like, and replace them when worn. Only downside is that they require a little more work to fit. On occasion these were so hot my hands red raw.
bamt
PostPosted: 10:06 - 02 Apr 2016    Post subject: Reply with quote
One thing to watch on the Oxford ones is that the Adventure, Tourer, Sport etc. grips are also all different lengths - so if I didn't want to cut down the grips or have a big gap on my Pan I had to get the Sport variant (123mm), whereas the Bandit got Touring grips (120mm), Adventure would have been too long for both (132mm) as would ATV (130mm).
I'm not seeing any appreciable wear on the Sports ones yet, with about 2K miles on them. My Divvy had the old style rotary controller, that failed mechanically (wouldn't push on/off) and I put the newer style on it. That controller did two winters in all weathers and about 40K miles without skipping a beat. I wire them through a relay even though they have auto-off; auto-off doesn't stop them coming on for a while when the button is pressed and your engine is off (though they will then shut down).
I did swap out the Daytona grips that were fitted to my Pan - they simply didn't get warm enough.
Ayrton
PostPosted: 12:20 - 02 Apr 2016    Post subject: Reply with quote
I didnt like my R&G grips either. The cable started pulling out of the grup after a while and they kept turning themselves on when the bike was off.
I accidentally fucked them up completely when i removed them when i sold my bike.
Jmh600
PostPosted: 16:44 - 02 Apr 2016    Post subject: Reply with quote
I've got a pair of the RST heated gloves. They're battery powered X fast to charge and made the last winter a breeze. Best thing I've ever bought for the bike.
Jmhmotorcycles
PostPosted: 17:09 - 02 Apr 2016    Post subject: Reply with quote
I'd never have a bike without heated grips nowadays. even in summer a shower in the evening and your hands can get cold.
My bike came with Triumph heated grips. Only off, low and high but that's enough for me.
On bikes where I've fitted them I've always fitted Oxford, and the sport version since that cam out as they are nice and slim. They get nice and hot as well, some makes are pants for heat. Never had any problems with them as far as I can remember. Thumbs Up
Going
PostPosted: 23:24 - 02 Apr 2016    Post subject: Reply with quote
I had some Oxford ones. Can't remember how long I had them till one of the grips failed the the controller unit itself.
They also felt weird at the beginning as they were double the thickness, then it felt weird when I took them off Smile
Still debating with myself if I should get some for my current bike Thinking
talkToTheHat
PostPosted: 03:48 - 03 Apr 2016    Post subject: Reply with quote
I shall have the adventure ones next then. The touring ones have convinced me i have big hands. I've got 15mm of rubber from another set of grips on each end of the bars, mostly so i dont catch the side of my gloves on the mounting gubbins for the muffs in winter.
The last post was made 10 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 123.34 Kb
