| Hahadumball |
 Hahadumball World Chat Champion
| Old Git Racing |
 Old Git Racing World Chat Champion
| stevo as b4 |
 Posted: 01:00 - 02 Apr 2016 Post subject: |
People have quite successfully turbocharged most. Things including singles, so there's no reason or disadvantage to blowing into a twin. People have a pre conception that only an IL4 can be any good for turbocharging, as it's all most people have ever seen, even with cars too.
Fabrication of hot side. Pipework and manifolds would be the biggest expense I would say if not doing it yourself. You need to think about what you want from the project too, and expectations, as it gets expensive to re do things or change engine spec during or after the build.
Pete, Chri5, and little red machine are the ones to ask about the specifics, and hardware specs etc, along with materials specs and all the supporting changes and ancillaries required.
The T15 turbo sounds way too small for a single unit though, as you need something that can keep up with the engines airflow capability at 9500rpm as a minimum if not exceed it, and you'd need to size the turbo to be efficient and give useable characteristics too.
Packaging on a transverse V-twin engine could be a bit of a challenge depending on what compromises you want to make.
There's no reason with the time and money not to do it, but it won't be a simple hook up a few pipes to a scrapyard turbo and be sorted job either. |
| sickpup |
 sickpup Old Timer
| stevo as b4 |
| MCN |
 MCN Super Spammer
 Posted: 09:55 - 02 Apr 2016 Post subject: |
Unless you can make the turbocharger less introosif
 ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Pete. |
 Pete. Super Spammer
 Posted: 12:18 - 02 Apr 2016 Post subject: |
You can do it. You have to be careful with detonation so keep the boost levels sane but there are plenty of examples about. Turbos supply torque which a v-twin isn't short of in the first place so there's no real need for mental boost to make a mental bike. ____________________ a.k.a 'Geri'
| talkToTheHat |
 talkToTheHat World Chat Champion
The last post was made 10 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
