TV/Media room setup advice
techathy
PostPosted: 14:45 - 03 Apr 2016    Post subject: TV/Media room setup advice Reply with quote
I want to convert what is currently an unused study/bedroom into a small media room. I know the room is too small to be ideal but after reading several speaker manuals I've come up with the setup below. Obviously the sub's position is subject to getting the room setup and finding out where sounds best.
https://cdn.bcf.44bytes.net/files/room_plan.png
From what I can tell going for a centre speaker in such a small room is pointless but what about the rear speakers?
PostPosted: 16:00 - 03 Apr 2016    Post subject: Reply with quote
1) Put the sub IN the sofa. Twisted Evil
2) Consider a projector for epic win. Especially if you can get some good light control in there.
My projector is mounted 3m back and fully zoomed in is giving me a 140cm x 80 image on my chimney breast. But it'll go out (optically) to 200cm x 112. That's the equivalent of a 90" TV.
Just saying...
Jayy
Mr. Ponzi
PostPosted: 17:30 - 03 Apr 2016    Post subject: Reply with quote
2nd the projector idea, why would you even bother with a TV in a dedicated media room?
I'd have both. Faux wall 1ft from the wall at the back, mount the TV inside the wall so it's flush, put the subs and equipment below and make the speakers /subs flush with the TV.
Electronic screen above that comes down over the TV.
Or just settle for the projector on its own, ceiling mounted.
t121anf
PostPosted: 17:36 - 03 Apr 2016    Post subject: Reply with quote
Not enough speakers
https://www.dolby.com/in/en/guide/surround-sound-speaker-setup/9-1-setup.html
Jayy
Mr. Ponzi
PostPosted: 18:25 - 03 Apr 2016    Post subject: Reply with quote
https://i.imgur.com/1d8hSaZ.jpg
Something like this
techathy
PostPosted: 20:49 - 04 Apr 2016    Post subject: Reply with quote
Longer term a projector is an option but first I just want to get the audio sorted out.
PostPosted: 08:43 - 05 Apr 2016    Post subject: Reply with quote
The sub location should be irrelevant, the bass is such a pure tone that it's hard to distinguish where it is coming from anyway.
ferrisio
PostPosted: 10:11 - 05 Apr 2016    Post subject: Reply with quote
This only applies if it's a true LFE (i.e. low frequency effects) setup. If the sub is doing bass management as well (putting some of the main L R signal through it to compensate for small left/right speakers) then it will become noticeable.
Also consider getting at least an LCR setup, the centre speaker will lock the dialogue into position coming from the screen and will sound a lot more cinema-like than having a phantom centre from your Left/Right speakers.
BMW R1100R
techathy
PostPosted: 16:48 - 05 Apr 2016    Post subject: Reply with quote
Every time I've setup speaks I've found that bad sub placement can lead to certain frequencies booming or disappearing, this generally is more of a problem in smaller rooms.
I was told that unless the speakers are more than 1.5 meters apart a centre speaker was pointless. You're saying this is untrue?
CaNsA
PostPosted: 16:53 - 05 Apr 2016    Post subject: Reply with quote
I can tell the difference.
About the sub... chuck it in the corner of the room behind the sofa.
I don't know if your AVR has a similar feature but, I can plug in a small mic and the AVR will configure the sound settings for each speaker to ensure sound is delivered to the ear at the same time.
PostPosted: 12:11 - 06 Apr 2016    Post subject: Reply with quote
It puts the sub IN the sofa.
The last post was made 10 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 68.77 Kb
