XV 950 making a horrible noise on accleration
bamster950
PostPosted: 16:06 - 03 Apr 2016    Post subject: XV 950 making a horrible noise on accleration Reply with quote
Hi people, first posting, please follow the link https://youtu.be/kob0ZYUlSGs
You may wish to use headphones if the volume on your PC is a bit iffy. I get a squealing noise on acceleration. At the beginning of the clip it is just audible, but further into the clip as I accelerate it's quite obvious. Particularly when you see me filtering up to a set of lights. Its been into a certain dealership twice, whose name I wont reveal, but they claim not to be able to hear anything. The customer services co-ordinator at your caring sharing Yamaha UK was as much use as a chocolate handbag, and the Vice Pres. of Yamaha Motors UK didn't bother responding to my email. So much for customer service. Anyhow, back to this damn noise. If anybody can identify where this noise is coming from I'd appreciate it. I've other clips available which may make it easier to hear if they're required, its driving me round the bend. Rolling Eyes
[/b]
mysterious_rider
PostPosted: 16:12 - 03 Apr 2016    Post subject: Reply with quote
Inaudible. Must try harder.
KAWASAKIIIII
TheSmiler
PostPosted: 16:16 - 03 Apr 2016    Post subject: Reply with quote
Random guess could it be the start of your cam chain tensioner having problems how long have you had your noise ?
bamster950
PostPosted: 16:18 - 03 Apr 2016    Post subject: Reply with quote
I can hear it fine. Right at the beginning as I pull away from the r/about with the black Corsa on my right, and further into the clip. Really need to listen when I am going slow and then accelerating. Try the whole ciip its unmissable.
talkToTheHat
PostPosted: 02:12 - 04 Apr 2016    Post subject: Reply with quote
How quiet is that bike? Is it like the quietest and thus most pointless air cooled twin ever?
I can hear the squealing and it sounds bad. Like squeaky trolley wheel bad.
Check it's not part kf tbe airbox whistling, by old xv did similar when the o-ring on the air filter failed, but the design was totally different with the airbox forming the frame over the engine.
Bandit. does. everything.
growler
PostPosted: 15:50 - 04 Apr 2016    Post subject: Reply with quote
would I be correct in thinking it is belt drive?
If it is you need to check you swing arm bearings asap
I had a similar issue and found the belt hadn't been tension-ed properly so it ate the rear sprocket and destroyed the belt side bearing
DILLIGAF
The last post was made 9 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 48 Kb
