| Paul2129 |
 Paul2129 Nova Slayer
 Posted: 23:38 - 03 Apr 2016 Post subject: Gearing a 125 for motorways |
Hi guys, I'm looking for some feedback from someone who's done what I'm suggesting, I have a CG125 which I'm using for motorway work. I have no problems with the actual bike, actually I really like it, and I have no intention to replace it for anything bigger to do the same job. I do also realise that there are limitations here, there is only so much power, and in this respect it's very different to asking the same question of something without the same limitation of power and top speed... Actually I don't want to go faster, I want to maintain roughly 62mph. It seems to have little problem with this... But it revs it's little nuts off. Clearly, it had 5 gears, but I wondered if it could be re-geared so that 4th 'felt' to the bike like 5th, ie it was similar gearing, giving me a final gear for flat motorways at slightly less revs. I'm not worried about acceleration, or having to change from 5th to 4th on inclines, more that on the level, on motorways, that I could use 5th (as a sort-of 6th) for slightly less frantic 62mph.... If it'll pull it (on the flat)
Does anyone have any experience of this on a similar bike, and can they tell me the sprocket sizes ? I know that Mr Honda was smart, and I know that when I've ridden the bike on motorways, I sometimes change my mind and agree that things can't be improved, I just wondered
Paul |
| Ste |
 Ste Not Work Safe
 Posted: 23:53 - 03 Apr 2016 Post subject: |
Why the 125?
If you change the gearing in order to make it slightly quieter, you'll still only be doing 62mph and you'll still be getting in everyone elses way.  |
| stevo as b4 |
| MCN |
 MCN Super Spammer
 Posted: 23:55 - 03 Apr 2016 Post subject: |
The limit is the power output.
You are near the peak power at 55. Possibly over.
The front sprocket may be able to be changed for a tooth less. but since there is very little margin of power you would then struggle on hills.
BIGGER BIKE.
Or suck it up.
60 odd is fine on a CG125.
Edit: 1 tooth less on the front sprocket is not a toothless sprocket. You only get that with abuse.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 00:06 - 04 Apr 2016 Post subject: |
Speed = power = torque x revs.
You're limited by power and you need revs for that. There's no magical solution to get the same speed out of lower revs without adding more capacity.
Fit a 150cc kit, gangsta. ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
 Posted: 00:10 - 04 Apr 2016 Post subject: |
If you gear it taller, you'll land up constantly changing between 4th and 5th and probably spending more time in 4th with the revs higher than they were before every time you come to a hill.
One thing that would probably help, but which would be very difficult to do without a whole lot of very technical stuff, would be to make the top couple of gears a closer ratio THEN up the gearing. This would make the gap between 4th and 5th smaller so you'd be shifting up into a more powerful part of the rev range and stand more chance of pulling that gear (how many times do you go for 5th to find it wont actually pull it).
Trouble is, you'd need to fit different gear clusters to achieve this. I'm not saying they aren't out there (honda made a lot of bikes and many parts will fit other models) but you'd be looking at totally dismantling your engine and fitting gearing out of another bike which you'd first have to identify. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Paul2129 |
 Posted: 00:20 - 04 Apr 2016 Post subject: |
That's really great advice. It seems to have little trouble maintaining 62mph. I went to Hamburg Germany last year, and, being (honestly) an experienced biker, I don't expect too much, or particularly push it too hard, but as the journey went on, my cruising speed of 55ish went up to 62 or more. I didn't feel any lack of power, genuinely, until I was back in the UK, heading home from the ferry, and was on the climb from Dover, I couldn't get past the wagons despite slipstreaming them thinking that I could shoot past.
I know these things are tough, but would you expect that constant high speeds on a 125 will cause any damage, there's a 1250 mile 2 day ride planned for this year. Part of the fun (yes, honestly, this is the kind of thing I do for fun) for me, is seeing if this tiny bike can make it to the places I point it at. It's super light, ludicrously frugal, and has a 275 mile fuel range. It makes not a half bad little tourer (perhaps in a 'rather you than me sense) than some more 'made for the job' machinery that I have in my garage.
Can I continue that 62mph torture, and assume that it won't explode ? |
| Paul2129 |
| stinkwheel |
| Paul2129 |
| Rogerborg |
 Rogerborg nimbA
| Paul2129 |
 Posted: 00:36 - 04 Apr 2016 Post subject: |
There has been some pretty beautiful cafe racers made from CG125's, with very low riding positions, weirdly these 'racers' (we can use the term loosely) never seemed to report any increase in top speed, unless they were mainly interested in the cosmetic look of their machines... Which, doing this to a 125 is likely.
I'm tending to use the pillion pegs for my feet when on the motorway, I'm wondering if changing the handlebars would be worth it. I'll have a quick look at fairings, but this is our secret  |
| stinkwheel |
| Paul2129 |
 Posted: 00:40 - 04 Apr 2016 Post subject: |
I think that so many cans of soup would be beyond the loading capacity, unless I was to start eating the soup on the way, problem is, I don't like soup  |
| Paul2129 |
 Posted: 00:46 - 04 Apr 2016 Post subject: |
It's not a good look riding a CG, and it's hard to contemplate what being caught by someone you know with a 'slippery fairing' attached. If Honda were to actually design something, and for people to use it for this purpose, I think there are bikes such as the Yamaha YZF125 which can crack fairly close to 75 or 80mph, that's slippery, with more power.... And probably the price of a small car !
As it is, I'm gonna enjoy my next bit of touring, and probably set off 10 minutes earlier  |
| stinkwheel |
| Paul2129 |
| Paul2129 |
 Posted: 00:54 - 04 Apr 2016 Post subject: |
Thanks for the chat, really enjoyed it
Paul |
| MCN |
 MCN Super Spammer
 Posted: 01:37 - 04 Apr 2016 Post subject: |
I took a CG125 from Bradford to Hull along the M62. I recorded 72.3MPH on my GPS with my big head and vast posterior tucked in behind the speedo. The prone position makes a hoorova/massive difference and you can nap in that position too on longer runs.
60 MPH on a CG will do no longterm harm. It is not going to melt the piston to the barrel like an Aprila 50.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| talkToTheHat |
 talkToTheHat World Chat Champion
| MCN |
 MCN Super Spammer
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
| woo |
 woo World Chat Champion
| Alpineandy |
 Alpineandy World Chat Champion
| woo |
The last post was made 10 years, 196 days ago. Instead of replying here, would creating a new thread be more useful? |
