| davidtheduke |
 davidtheduke L Plate Warrior
| mudcow007 |
 mudcow007 World Chat Champion
| ZX-7R |
 ZX-7R Banned
| skatefreak |
| davidtheduke |
| ZX-7R |
 ZX-7R Banned
| Keir |
 Keir World Chat Champion
 Posted: 17:24 - 04 Apr 2016 Post subject: |
how much was the service?
Its likely that you put the bike in for a service so it got an oil and filter change. You mentioned squeeky brakes and a dodgy clutch so they cleaned the caliper and rear drum with an air line and adjusted your clutch cable within that service cost.
If it turns out that your caliper is seized or something then you will need to pay the £100 or whatever for a rebuild. ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 18:13 - 04 Apr 2016 Post subject: |
Wouldn't be surprised if they simply slid the calliper off the disc, pumped out the piston, squeezed the piston back in and re-attached it to the fork. 5 mins spent. Problem fixed sir.
Except the problem may well be crud behind a seal, or crud around the sliding pin, which means stripped calliper, clean, new seals most likely, new brake fluid, bleeding brakes. Probably 30mins.
If the piston itself is rusty / damaged. Then it's some time with wet+dry, or more likely a new piston (if the garage is doing it). Either way, another £50 on top of the strip+clean price. |
The last post was made 9 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
