Tarting up a corroded engine
Silver_Fox
PostPosted: 12:56 - 05 Apr 2016    Post subject: Tarting up a corroded engine Reply with quote
I bought an ex training school bike rather than a shiny one for my partner to learn on. Having got it I now have the urge to make it as nice as possible for her (within reason). The engine block looks a little worse for wear, dull and tarnished and spoils what is a solid bike.
I don't want to spend too long on it really, so can I just mask it up and spray this on it?
https://www.amazon.co.uk/Hammerite-5084785-Metal-Paint-Aerosol/dp/B004Z4UMDW/ref=sr_1_1?ie=UTF8&qid=1459856017&sr=8-1&keywords=hammerite+smooth+silver
https://i1.adis.ws/i/washford/328658?$pd_main_v2$
CBR600 F3 FV
CG125
PostPosted: 13:09 - 05 Apr 2016    Post subject: Reply with quote
I'd be more inclined to use
https://www.autosessive.com/products/80291/simoniz-aluminium-engine-enamel-paint-500ml?gclid=Cj0KEQjwxI24BRDqqN3f-97N6egBEiQAGv37hMsMTcOkDuDHHyLijcD_xkEOTpd94rsPdtF48MYMS0caAoPi8P8HAQ#fo_c=1195&fo_k=f4311ef9992b5c58a7abd70193f4067f&fo_s=gplauk
PostPosted: 14:38 - 05 Apr 2016    Post subject: Reply with quote
I'd also replace the engine bolts with stainless after you have done it, it is a cheap easy way of making a bodge engine spray job look better. If you take them out one and a time and replace them it is nice and easy.
Ebay may do a kit for your bike, failing that take one out measure the diameter and thread and get an assortment.
If you mask well, prep well, and put in fresh bolts it can look like a big improvement. Thumbs Up
Silver_Fox
PostPosted: 14:44 - 05 Apr 2016    Post subject: Reply with quote
To be honest I just want it to look better, not perfect, just so your eye isn't drawn towards it. It's not worth spending loads of time on Thumbs Up
CBR600 F3 FV
CG125
PostPosted: 14:49 - 05 Apr 2016    Post subject: Reply with quote
It's one of those things you could do it in 5 minutes and it would look gash, do it in 1-2 hours and it would look good.
Silver_Fox
PostPosted: 15:05 - 05 Apr 2016    Post subject: Reply with quote
How gash? Mr. Green
CBR600 F3 FV
CG125
PostPosted: 15:06 - 05 Apr 2016    Post subject: Reply with quote
Silver_Fox wrote:
How gash? Mr. Green
It looked better before hand gash. Laughing
Silver_Fox
PostPosted: 15:32 - 05 Apr 2016    Post subject: Reply with quote
I've read on here about using bathroom type limescale cleaner...
CBR600 F3 FV
CG125
PostPosted: 16:15 - 05 Apr 2016    Post subject: Reply with quote
I'd just degrease thoroughly and get rid of anything flaking with a wire brush.
Snodvan
PostPosted: 20:08 - 05 Apr 2016    Post subject: Reply with quote
What I did on a BMW - well known for engine corrosion - was
1. Degrease with sugar soap (cheap but very effective) and lots hot water from a pump up garden spray
2. Remove all the loose paint with a blunt screwdriver and a Dremel thing
3. "Sandblasted" all over with sodium bicarbonate - NOT anything more gritty. This will make sound old paint and the metal body well keyed to accept new paint. Wash off the bicarb with water. Easy.
4. Apply LOTS of thin coats of Hammerite smooth. I bought a cheapo airbrush (Machine Mart) rather than use a rattle can because I could then dilute the paint to give nice thin coats (about 8).
I found aluminium cooking foil then masking tape ideal for masking off all the pipes, wires etc around the engine, and stuffed screwed up bits in the bolt head sockets
The sodablasting can be done at minimal cost (so long as you can access a compressor of course). See https://www.youtube.com/watch?v=5vuENNhOMQs
Oriental supermarkets sell 2-5kg bags of bicarbonate. I used about 1.5kg
https://i64.tinypic.com/w98ls2.jpg
https://i66.tinypic.com/ayonly.jpg
https://i64.tinypic.com/2qxp0d0.jpg
https://i63.tinypic.com/2yori9e.jpg
4 years later the paint is still sound
Snod[/img]
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
Silver_Fox
PostPosted: 20:11 - 05 Apr 2016    Post subject: Reply with quote
Thanks Snod, it was actually your original post I found in the search before I posted this topic Smile
CBR600 F3 FV
CG125
PostPosted: 23:13 - 05 Apr 2016    Post subject: Reply with quote
Jesus wept. I'd be screaming the walls down at my dealer if my Trophy engine looked like that BMW, however old it was.
That is disgusting. Thumbs Down
The last post was made 10 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 73.34 Kb
