Clean up a master cylinder?
owl10
PostPosted: 21:08 - 05 Apr 2016    Post subject: Clean up a master cylinder? Reply with quote
Hi,
I've got a pre-radial type master cylinder on my zx6r j1 (2000) which looks pretty rusty on the inside.
Currently no fluid in the cylinder.
I plan to refurb, and was wondering what is the best way to clean it up?
Simply fill the reservoir with brake fluid for a week? Kurust?
Any advice appreciated.
DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that"
PostPosted: 23:18 - 05 Apr 2016    Post subject: Re: Clean up a master cylinder? Reply with quote
owl10 wrote:
Hi,
Get a new seal kit then you can completely strip it down and use pretty well whatever you like to clean it. I have a cheapy small ultrasonic cleaner I love to bits for that sort of work.
MCN
PostPosted: 23:46 - 05 Apr 2016    Post subject: Reply with quote
Krust only works on rust. (Iron Oxide).
If the cylinder is aluminium then it will be aluminium oxide.
It can normally only be removed by polishing. Elbow Grease. Unless you can find some chemical that will dissolve it. But the same chemical will possibly attack the good metal too.
If it is 'rusted' inside i.e. the piston bore, then a seal kit will only provide a temporary fix as that part must be very smooth for a perfect seal.
You can get one ebay for about £30.
PostPosted: 11:18 - 06 Apr 2016    Post subject: Reply with quote
It'll most likely be crystalised brake fluid deposits rather than heavy alloy corrosion. The brake fluid tends to absorb any moisture in the system which makes corrosion less likely to occurr in a big way.
Strip it, wash it in the sink with hot soapy water and a non-stick pan type cleaning pad, rinse it in hot water (I pour the kettle over it) then dry and clean through with brake cleaner solvent.
Or put it through an ultrasonic cleaner if you have one.
The reservoir part is just that, a reservoir so some stable alloy corrosion in there isn't going to be a big issue (by stable, I mean firmly stuck to the metal, not coming loose). If there is a lot of corrosion/pitting on the bore where the piston sits, it might be better replacing it. If the bore is clean, fit a rebuild kit and crack on.
The last post was made 10 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 41.03 Kb
