can somebody explain this indicator wiring to me please
Sean.S
PostPosted: 20:28 - 06 Apr 2016    Post subject: can somebody explain this indicator wiring to me please Reply with quote
the plan is to wire in some indicators to a 25 year old dirt bike but this is what i fail to understand... behind the headlight i have an earth wire, and one single wire for each of the front indicators. with indicators having two wires each, i can't see how i can connect any up. wiring to my knowlege is original....
https://i1218.photobucket.com/albums/dd404/SeanS91/My%20Motorbikes/IMG_4068_zpsezpawthk.jpg
on the rear its the same wiring but without the earth, orange wire left indicator, blue for the right
https://i1218.photobucket.com/albums/dd404/SeanS91/My%20Motorbikes/IMG_4070_zpslapsmsul.jpg
i really dont know much about electrics and in all the how to videos on youtube, none of the bikes used have this wiring. so please lay it out for me in layman's Wink
cheers
Ichy
PostPosted: 20:52 - 06 Apr 2016    Post subject: Reply with quote
For the front both indicators share the earth, that is why it has two 'holes' for bullet connectors, then one wire for each side.
Rear. One wire to each indicator then find an earth point on the frame and connect a wire to it that then feeds the earth on the indicators.
mauzo
PostPosted: 22:23 - 06 Apr 2016    Post subject: Reply with quote
You might also find that the tail/brake light ground connector has room for the rear indicator grounds.
'04 CG125, '07 CBF500
Sean.S
PostPosted: 07:40 - 07 Apr 2016    Post subject: Reply with quote
Thanks for clearing that up for me, tbh i knew that might turn out to be a noob question Smile
Sean
Sean.S
PostPosted: 16:44 - 08 Apr 2016    Post subject: Reply with quote
Okay so i have another noob question for yoy guys... If an indicator has a yellow and a black wire, which is the earth?
Cheers sean
PostPosted: 16:59 - 08 Apr 2016    Post subject: Reply with quote
Black should be the earth, but if you really wanted us to help you might want to tell us the make and model of the bike. Just sayin'.
PostPosted: 17:50 - 08 Apr 2016    Post subject: Reply with quote
Just try it both ways. It's an indicator and isn't going to explode or break. It will light up or it won't. Switch wires round if latter.
Ichy
PostPosted: 18:36 - 08 Apr 2016    Post subject: Reply with quote
Cheers sean
Honestly?
You are seriously out of your depth. Black has been earth since forever.
Go read. then read some more.
https://www.ktm950.info/how/Electrical%20Shop/Wiring/Basics/Basic_wiring.html
Sean.S
PostPosted: 19:23 - 08 Apr 2016    Post subject: Reply with quote
Yes, seriously... My knowlege of bike electrics is vague, so yes maybe i was a little Laughing
Earth to me is yellow/green
Thanks guys
Islander
PostPosted: 19:57 - 08 Apr 2016    Post subject: Reply with quote
If it's a lamp based indicator then it doesn't matter a fig which way round you wire it. Traditionally though, the wire that connects to the centre pin is wired to the feed and the wire that connects to the shell of the lamp is wired to earth. Thumbs Up
The last post was made 10 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 64.09 Kb
