No space beetween brake pads to fit into brake disk????
Bandit6
PostPosted: 15:16 - 07 Apr 2016    Post subject: No space beetween brake pads to fit into brake disk???? Reply with quote
No space beetween front brake pads to fit the brake disk. There is small hump in callipers that cause trouble. So all I can do is grind it off or grind right brake pad. I have tried 3 kind of brake pads, but they are all same thick. Problem is that I need correct brake pad, but which one I need? Its honda anf 125. Its really annoying. Thank you for help, excuse my english grammer, its not my first language.
tom_e
PostPosted: 15:25 - 07 Apr 2016    Post subject: Reply with quote
You have pushed the pistons back in haven't you?
MCN
PostPosted: 15:26 - 07 Apr 2016    Post subject: Reply with quote
Make sure everything is spotlessly clean.
Clean the side of the caliper that the pads 'react' against. Rust ans shit builds up in there which makes the pads and shims difficult to fit.
If the factory can get new pads with shims in then no reason why anyone can't.
Unless you don't have the correct match for the caliper.
Bodging brakes is a bad place to be. Pale
pepperami
PostPosted: 15:43 - 07 Apr 2016    Post subject: Reply with quote
This Shocked !
PostPosted: 15:58 - 07 Apr 2016    Post subject: Reply with quote
I think we need to see pictures of this humped caliper and pads.
Or it could be that the caliper and pads are fine and some genius fitted a new too-thick disc with worn pads.
The more you tell us, the more useful we can be.
RhynoCZ
PostPosted: 16:02 - 07 Apr 2016    Post subject: Reply with quote
OP, it needs a bit of skill, push the post back into the caliper, as far as you can, then try it again. When I was fitting the calipers with brand new pads onto my 320mm discs, I was swearing so much, the neighbors started giving me the evil look everytime they saw me. Wink
If you're not sure, use a caliper (measuring device) and measure the gap between the pads and the disc. Thumbs Up
Bandit6
PostPosted: 16:04 - 07 Apr 2016    Post subject: bump in calliper intervene, take space Reply with quote
That little bump in calliper is the problem, intervene. Its there to hold that metal strip in callipers. If nobody advise me what to do, I have to remove that callipers and take it to motorcycle shop and ask to sell me pad that will fit. That bump is size of wart, its all about it.
RhynoCZ
PostPosted: 16:08 - 07 Apr 2016    Post subject: Reply with quote
What bump? Pictures please. Thumbs Up
Bandit6
PostPosted: 16:32 - 07 Apr 2016    Post subject: photo later Reply with quote
I got stupid ordinary nokia phones, so I have to borrow phone. I am not phone obsessive.
Bandit6
PostPosted: 16:33 - 07 Apr 2016    Post subject: photo later Reply with quote
skatefreak
PostPosted: 16:39 - 07 Apr 2016    Post subject: Reply with quote
Is this the caliper?
https://makinaparts.com/3841-8072-thickbox/45133ma3006-boot-b-brake-caliper-honda-cb-600-cbf-600-1000-cbr-xl-600v-650v-700v-transalp-xl-1000v-varadero-.jpg
Bandit6
PostPosted: 16:48 - 07 Apr 2016    Post subject: Reply with quote
Yes, of course.
PostPosted: 16:58 - 07 Apr 2016    Post subject: Re: photo later Reply with quote
You must be, cameras take pictures yet you immediately jump to needing a phone for it Laughing
PostPosted: 17:01 - 07 Apr 2016    Post subject: Reply with quote
Are they definitely the right pads? The rear pads in my TDM are identical in shape to a FJR, however the FJR ones are about 4mm thicker and don't fit.
PostPosted: 17:28 - 07 Apr 2016    Post subject: Reply with quote
When did you get a TDM?
Islander
PostPosted: 17:49 - 07 Apr 2016    Post subject: Re: bump in calliper intervene, take space Reply with quote
If you have:
    Pushed the pistons flushback into the caliper body
    Cleaned all of the crap out of the caliper bodies that could interfere with the correct fitting and operation of the pads
    Bought the right pads for the caliper
Then the pads should fit and slide over the disc.
If you don't know what you're doing then for the sake of safety you should probably get someone who does to show you how.
RhynoCZ
PostPosted: 18:21 - 07 Apr 2016    Post subject: Reply with quote
If there's excessive amount of brake fluid when you start pushing the pots back in, suck some of it out of the reservoir, as it is beyond your capabilities to compress liquid. Thumbs Up
It mostly happens when people bleed brakes with worn pads, they always pour in fluid up to the top notch of the reservoir.
iooi
PostPosted: 18:23 - 07 Apr 2016    Post subject: Re: bump in calliper intervene, take space Reply with quote
I dread to think that if you cant get pads to fit, then the thought of having to bleed the system....... Shocked
Can't you just put the old pads back in and ride to the garage for them to look at.
Bandit6
PostPosted: 16:10 - 08 Apr 2016    Post subject: Re: No space beetween brake pads to fit into brake disk???? Reply with quote
Bandit6
PostPosted: 16:12 - 08 Apr 2016    Post subject: Re: No space beetween brake pads to fit into brake disk???? Reply with quote
Bandit6
PostPosted: 16:13 - 08 Apr 2016    Post subject: Re: No space beetween brake pads to fit into brake disk???? Reply with quote
Bandit6
Bandit6
PostPosted: 16:16 - 08 Apr 2016    Post subject: Re: No space beetween brake pads to fit into brake disk???? Reply with quote
Bandit6
PostPosted: 16:21 - 08 Apr 2016    Post subject: Re: No space beetween brake pads to fit into brake disk???? Reply with quote
Now some explanation. Some logical would be prefered
PostPosted: 16:43 - 08 Apr 2016    Post subject: Reply with quote
Dosn't look like you have the calliper pushed fully down onto the pins (parts 11 and 12 on skatefreaks parts diagram).
On this image, push the black bit down and the silver bit to up.
https://cdn.bcf.44bytes.net/files/img_1178.jpg
The last post was made 9 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 126.74 Kb
