panniers, realistic weight?
mysterious_rider
PostPosted: 18:51 - 07 Apr 2016    Post subject: panniers, realistic weight? Reply with quote
Hello guys. Im wondering what you lot think of this.
I have my military panniers (that say on them they can carry 37kg of ammo).
My enfield, which has a few spots that I can bolt brackets to.
What weight can I put in them? I have this massive chain and lock that I was hoping to bring with me on my travels. the chain is 14kg and 2m long. Worst case I have to cut the chain in half and put half in each pannier, and get another squire lock to join them.
It sounds silly but Im taking this bike abroad and I need it safe.
ive sort of bodge painted my idea of a 3mm-4mm bracket, I'd put another at the bottom of the pannier too, and have them bolt up to the ringed bolts on the bike.
and at the rear of the pannier Id have some U bolts with rubber mounts.
I feel fairly confident the enfield frame can handle the weight, I just want other experienced users ideas about the strength of the brackets. I wouldnt want to overload and snap anything.
https://i270.photobucket.com/albums/jj88/mysterious_rider/IMG_20160404_182234_zpsmxwtfvpz.jpg~original
https://i270.photobucket.com/albums/jj88/mysterious_rider/IMG_20160407_174648_zpsl47tvega.jpg~original
https://i270.photobucket.com/albums/jj88/mysterious_rider/IMG_20160327_133729_zpsa0hllx06.jpg~original
KAWASAKIIIII
R1stu
Shrek!
PostPosted: 22:20 - 07 Apr 2016    Post subject: Reply with quote
I think the Specs for my pans luggage state 40k a side, so you should be alright.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
bamt
PostPosted: 22:29 - 07 Apr 2016    Post subject: Reply with quote
The Pan 1300 is 20lbs (9kg) per side not 40kg, though these are plastic so that may well be the limiting factor.
For total load, as long as it is less than a pillion passenger the bike should be OK - though you'd want to make sure that the mounting points can take the weight and ideally have it evenly loaded.
MCN
PostPosted: 23:37 - 07 Apr 2016    Post subject: Reply with quote
DO what the Motorcycle Police who ride Pans do. Have a very serious speed wobble at motorway speeds. Shocked
You have to consider the same bike will have two up. So two folks 180Kg. It will still be a handful with two up.
You must be carrying a lot of bullets.
NJD
PostPosted: 23:53 - 07 Apr 2016    Post subject: Reply with quote
With such weight of the chain have you taken what cornering would be like with that + the panniers applied into consideration?
I'm not sure how much of this applies in your situation but the advice I got when I inquired about carrying any given Almax or Pragmasis chain around in soft panniers was that it would be better to keep the weight central in either a tailbag or topbox bolted directly to the subframe.
haroman666
PostPosted: 23:58 - 07 Apr 2016    Post subject: Reply with quote
If it were me, I would carry the chain in a well-strapped-down kriega (or similar) bag on the rear seat and then leave your panniers for lighter items.
Are you taking pillion?
J.M.
PostPosted: 00:11 - 08 Apr 2016    Post subject: Reply with quote
So long as your mounts are strong enough, shouldn't really matter so long as they're balanced.
I agree with comments about keeping the chain central. Also, that'll make it more convenient to access in order to chain the bike up. Chains on the rear seat can end up quite flat if you pack it carefully, so you can easily put another bag on top too.
2004 R1 & 2018 XSR900
mysterious_rider
PostPosted: 07:00 - 08 Apr 2016    Post subject: Reply with quote
Theres a chance of pillion yes.
Thanks for the info. Im think 20kg a box should be ok even with pillion.
I would like to build a rack across both boxes, above the rear light cluster and curl it up there. That way at least its spreading the weight. If not ill place on seat with a cargo net.
Shame it cant bolt onto rear of seat.
I dont think handling applies much. Its a slow enfield. She barely sees 65mph.
KAWASAKIIIII
mysterious_rider
PostPosted: 07:02 - 08 Apr 2016    Post subject: Reply with quote
KAWASAKIIIII
davebike
PostPosted: 08:06 - 08 Apr 2016    Post subject: Reply with quote
Loading limits from manufactures are very conservative but you need to be sensible if heavily loaded until you know how it affect handling !
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 08:10 - 08 Apr 2016    Post subject: Reply with quote
Tank bag, or remove the pillion seat (if chance of pillion doesn't materialise) and bolt a square of wood + some sort of bag or box on there.
R1stu
Shrek!
PostPosted: 08:56 - 08 Apr 2016    Post subject: Reply with quote
40lb total then almost right lol!
Robby
Dirty Old Man
PostPosted: 09:22 - 08 Apr 2016    Post subject: Reply with quote
I wouldn't worry about the bike frame taking it. It can take a 100kg rider + 100kg pillion with no trouble. Thing things to consider are the strength of the frame you build to hold the panniers, and vibration.
From the pannier frame, angle or box section is much less likely to bend than flat bar. Rubber washers and nyloc nuts to absorb and mitigate vibration.
PostPosted: 09:56 - 08 Apr 2016    Post subject: Reply with quote
I've used ammo box panniers before.
The trouble with ammo boxes is that the sides tend to split so just bolting them through the sides is a no-go.
You can use repair washers on the inside but I've even had heavily loaded ones split round the periphery of the washer.
Best bet is to either put a piece of ply on the inside of the box the same size as the inner wall or make your mounting with a piece of L-section along the bottom supporting the majority of the weight.
Your bike is designed to carry a pillion who could be over 100kg and sits higher on the bike than a set of ammo boxes.
The rear sub-frame of your bike looks the exact same deal as the pre-unit bullets. RE make racks for their military model bikes to take a pair of metal boxes. The racks are very robust and will take an ammo box across the top too. Get your arse on ebay India and check them out. Be aware "high quality" is in the eye of the beholder. Expect to have to bend them about to get them to fit and to give them a coat of decent paint.
Here's my touring setup on my 350 bullet. The racks are heavy but versatile. You can put other stuff in/on them.
https://i48.photobucket.com/albums/f216/stinkwheel/rbr/DSCN0718.png
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0695.png
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0694.png
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0693.png
The wooden shelf is very useful as a table if you're camping.
davebike
PostPosted: 11:19 - 08 Apr 2016    Post subject: Reply with quote
Friends bike and pictures
This is how you do it !! Note good solid rack mostly Welded and boxes solidly mounted
https://i78.photobucket.com/albums/j97/davebike500/Bikes/Image11.jpg
https://i78.photobucket.com/albums/j97/davebike500/Bikes/Image15.jpg
Images from his trip to Cape town both Sudan I think
Dave
[email protected]
MCN
PostPosted: 12:07 - 08 Apr 2016    Post subject: Reply with quote
Nice Halftrack Sir. Smile
Off topic meander:
Your seat springs:
I modificated my BSA C12 double saddle to a single sprung type unit. The issue was the springs are not supplied by Draganfly which was a phaph. When I eventually got my arse in gear to fit the new single saddle I found springs sold by a Hardly Dae-anything type ebay-shop. Cheap as chips and twice as comfy.
Moral of the story: It is all out there you just have to know where to look/ask.
Plenty of info on the Net
https://www.youtube.com/watch?v=clHa6MJy0yI
mysterious_rider
PostPosted: 14:31 - 08 Apr 2016    Post subject: Reply with quote
Hm. Ill line the inside with some ply or sheet metal then. I have pannier racks but they wont fit these boxes.
Also i looked at the india ones and the boxes are quite small. As in would fit enough for a trip for two. Yours are 15cm wide whereas mine is about 21.
I will fit a rack in between both and fit another rack for the chain. Thatll spread the weight.
Thanks for the pics gents. All helpful.
KAWASAKIIIII
The last post was made 10 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 104.18 Kb
