Broken stud extractor - how to remove.
PostPosted: 15:21 - 10 Apr 2016    Post subject: Broken stud extractor - how to remove. Reply with quote
I helped a guy today who had a broken-off stud extractor stuck in an exhaust stud. These are too hard to drill so I used an old machinist's trick for removing busted centre drill ends.
I took a 11mm diameter centre drill with a broken end and ground it as shown below. I also made a drilling guide to keep it aligned central over the broken stud.
PostPosted: 15:25 - 10 Apr 2016    Post subject: Reply with quote
Used the tool to drill over the top of the stud extractor which was sheared off below surface. I cut as much of the ally out from around the stud as I could, even hit the stud with my welder to melt the top down a bit to gain a bit of extra depth.
Once it was cored out as far as I could I built the top of the stud up with weld.
PostPosted: 15:28 - 10 Apr 2016    Post subject: Reply with quote
Once the weld was high enough I welded a nut to it and with all the heat involved it screwed out easily with a spanner.
The drilling guide did a great job and there was plenty of thread left so I just made an extended stud to go into the original thread.
Done start to finish in about 2.5hrs.
ondabike
PostPosted: 15:31 - 10 Apr 2016    Post subject: Reply with quote
Excellent demo Pete, will try that if I have to Thumbs Up
zzpza
PostPosted: 15:50 - 10 Apr 2016    Post subject: Reply with quote
Impressive work, not sure I have the skill to manage that!
I've been waiting for an opportunity (hopefully on none of my bikes) to try this method:
https://www.youtube.com/watch?v=fqZYgReuywM
Islander
PostPosted: 16:18 - 10 Apr 2016    Post subject: Reply with quote
It's an old watch/clockmakers trick and it does work. It's a lot slower than Pete's method though Very Happy
PostPosted: 17:00 - 10 Apr 2016    Post subject: Reply with quote
Also couldn't be done in place. The guy had already removed the cylinder head but I could have done it in place though it would have been a lot more awkward.
The best bit about this was I didn't have to use a lathe or mill, just an angle grinder, battery drill and welder so it's possible for anyone with those tools, all you have to do is get hold of a centre drill which are pretty cheap.
The last post was made 9 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 4.54 - MySQL Queries: 13 - Page Size: 54.81 Kb
